Page 3 of 3 FirstFirst 1 2 3
Results 31 to 36 of 36
Reload Thread: Has anyone tried a DSO Nano?
  1. #31
    Pyrofan's Avatar
    Pyrofan is offline CarAudio.com Elite
    Aug 2013
    Ga
    608
    233 Post(s)
    Re: Has anyone tried a DSO Nano?
    Well, it turns out you can NOT upgrade V3.29D to lastest BenF. So that means any amp bigger then about 1800 becomes useless cause it goes off the screen.
  2. #32
    maylar's Avatar
    maylar is offline Electrical Weenie
    Jan 2002
    Connecticut
    66
    3,498
    2 Post(s)
    399 Post(s)
    Quote Originally Posted by Pyrofan View Post
    Im setting gains on my amp and the wave gets to big for me to see. I have no vert pan
    You need to set the vertical sensitivity to match the signal voltage of what you're measuring. The top menu item "VD" is volts per division. Pressing the left or right arrows will change the sensitivity.
    Be aware that the scope displays peak-to-peak, which is 2.82 times the RMS voltage. There is also a X1/X10 switch on the probe - the X10 position will lower the amplitude by a factor of 10.
    So if you are trying to measure 40 VRMS it will show about 113 v peak-peak. For the waveform to fit on the screen you need to set the X10 switch on the probe and the vertical sensitivity to 20V per division.
    dave
    1999 Buick Park Ave Ultra
    Head Unit: JVC KWHDR720
    EQ: Audiocontrol EQL
    Front Stage: Hybrid Audio Technologies Imagine 5.25 mids, Morel Maximo tweets
    Sub Stage: Boston G3 10", 0.5 cu ft sealed
    Amp: PPI Phantom 900.4
    Rear Fill: Boston SE953 6X9's
  3. #33
    akillj's Avatar
    akillj is offline Senior VIP Member
    Sep 2012
    CA
    311
    118 Post(s)
    Did you not read what I said? If the waveform is so large that the DSO cant handle it on it's own(High voltage/High Current applications), you'll need an x10 probe. It will have a "1x / 10x" setting, which will put a resistor in-line with the signal, which the DSO will be able to display.
    I'd try what maylar said, if you still cant see the waveform due to its size, you'll need an x10 probe. I'm not sure if the DSO v3 comes with one, but my V2 didn't. In which case you'll need to buy/make one like I mentioned earlier.
  4. #34
    Pyrofan's Avatar
    Aug 2013
    Ga
    608
    233 Post(s)
    Quote Originally Posted by akillj View Post
    Mine came with one and I used it. Ill try what Maylar said next time I set it.
  5. #35
    akillj's Avatar
    Sep 2012
    CA
    311
    118 Post(s)
    Yeah if it came with one then it's more than likely user error. Hook it up to a signal and switch between x1 and x10, you'll notice the signal gets larger / smaller on the display.
  6. #36
    FUKAZ28's Avatar
    FUKAZ28 is offline Member
    Oct 2013
    southern, Va
    79
    19 Post(s)
  1. has anyone tried eDead
    By jaco in forum Wiring, Electrical and Installation Help
    Last Post: 05-10-2007, 07:35 PM
  2. Replies: 5
    Last Post: 02-10-2007, 06:38 PM
  3. has anyone tried those??
    By serg18 in forum Car Video, Security and Electronics
    Last Post: 03-04-2004, 10:29 PM
  4. has anyone tried the PG octane R
    By mrburner in forum Amplifiers
    Last Post: 03-04-2004, 05:17 PM
  5. Replies: 3
    Last Post: 12-04-2003, 01:12 AM
