Results 1 to 10 of 10
Reload Thread: 3-way system Problem
    acdcrocks0323's Avatar
    acdcrocks0323 is offline Junior Member
    Jul 2013
    ohio
    4 Post(s)
    Hi guys,
    My girlfriend's 2006 Hyundai Santa Fe w/ Monsoon sound system (after market HU installed) had a farty bass sound out of the passenger side woofer. I figured the midwoofer was ripped or just plain bad so I picked up some replacement 6.5 speakers (Silver Flutes) . I assumed it was a 2 way system with a midwoofer and tweeter. I take the door panel off and find that there is a 6.5 subwoofer, 2 inch midrange, and tweeter. This is all crossed over at the Monsoon amp. As far as I know there is no way to adjust the crossover range.
    Here lies the big problem: I want the new speakers to play the range that the "sub" and midrange played. Getting a new amp is not an option at this point. So I am wondering if there is a way to "combine channels" so to speak? Is there any way to have the new speakers play the bass and mids with the existing system? Thanks for any help.
    Edit: Would it be as easy as hooking up both sets of wires (the low and mid source) to the new speaker or would that cause problems?
    Jul 2013
    ohio
    4 Post(s)
    Re: 3-way system Problem
    Nobody has a possible solution?
    gstokes's Avatar
    gstokes is offline FÜKENGRUVEN
    Apr 2014
    Beaverton, Oregon
    58
    534
    160 Post(s)
    Quote Originally Posted by acdcrocks0323 View Post
    Patience young Jedi, a solution it will come..
    Whip: 1992 Ford E150 Custom
    H/U: Sony MEX-GS810BH
    Amplifier: PPI Black Ice BA2200.5
    Tweeters: NVX XSPTW
    Midbass: CDT Audio CL-5
    Subwoofers: 2 x NVX NSW122V2
    Enclosure: 3.2 cu ft Vented
    Jul 2013
    ohio
    4 Post(s)
    I figured hundreds of views would bring a relevant answer. It's too bad you don't know....
    Cheers
    trumpet's Avatar
    trumpet is offline CarAudio.com Veteran
    Jan 2011
    Grafton, ND
    37
    6,792
    43 Post(s)
    1859 Post(s)
    What you're asking for will require a separate amplifier. You can't just combine two pairs of speaker wires off the Monsoon amplifier. It will not work correctly, and you will be worse off than you started. Get a factory replacement speaker from eBay and put it back to stock until you can afford the right upgrades.
    Rubyserv - I believe I can delivery joy every time you drive by the power of an incredible sound system. Barry Schanz, Owner
    Authorized dealer for CDT Audio - Shop With Us Now.
    FB | Rubyservsales
    IG | Rubyserv
  6. Likes Jeffdachef liked this post
  7. #6
    Jul 2013
    ohio
    4 Post(s)
    I sort of figured that out through meddling with it. I think until my girl can get an amp, I'll just run it from the head unit and just bypass the monsoon amp.
  8. #7
    trumpet's Avatar
    Jan 2011
    Grafton, ND
    37
    6,792
    43 Post(s)
    1859 Post(s)
    Still a bad idea, but let us know if she likes how that sounds.
    FB | Rubyservsales
    IG | Rubyserv
  9. #8
    Jul 2013
    ohio
    4 Post(s)
    Pardon my ignorance, but why is it a bad idea? The HU has low and high pass filters and I can adjust the fader so the woofers and tweeters blend well. Is there anything wrong with that until I have a different amp? Besides the fact that the HU is only pushing 18 watts.
  10. #9
    trumpet's Avatar
    Jan 2011
    Grafton, ND
    37
    6,792
    43 Post(s)
    1859 Post(s)
    I typed up a response and deleted it because it's a bunch of theory. It may or may not work for you, but I really can't think of why it could cause damage. At worst it might sound bad, but that's assuming your girlfriend will even care. I'm not saying that as an insult, most people just want their radio to work.
    FB | Rubyservsales
    IG | Rubyserv
  11. #10
    negolien's Avatar
    negolien is offline CarAudio.com Elite
    May 2014
    Sacramento,CA
    1,185
    3 Post(s)
    412 Post(s)
    You can replace the head unit on a monsoon system and be fine if you run everything else stock. In order to replace the speakers you must bypass or pull the monsoon amp or use special bi-amplified speakers. If you bypass the monsoon amp you must have a different head unit as the factory one is meant to work with the monsoon amp and special speakers iirc.
  1. Bi amping a 3 way system
    By jmenace13 in forum Wiring, Electrical and Installation Help
    Last Post: 04-19-2005, 10:37 PM
  2. system problem
    By keto3124 in forum General Discussion
    Last Post: 07-07-2004, 01:10 PM
  3. 94 Deville System Problems
    By dukethekat in forum Subwoofers
    Last Post: 01-27-2004, 08:15 PM
  4. Replies: 5
    Last Post: 05-24-2003, 03:44 PM
  5. Car Audio system Problem..
    By talerico in forum Wiring, Electrical and Installation Help
    Last Post: 03-03-2002, 07:23 PM
Tags for this Thread
