Results 1 to 4 of 4
Reload Thread: Low voltage accessory wire on old Mitsubishi Magna 98
    leo.hyde's Avatar
    leo.hyde is offline Junior Member
    Dec 2012
    Australia
    1 Post(s)
    Hello,
    I am attempting to install a Alpine head unit to a 1998 Mitsubishi Magna Wagon. This is what I have found so far:
    * The yellow acc line is 0.2 V when ignition off and 0.4 v when ignition set to acc.
    * The red power line drops about 0.2 V to 12.1 V when the ignition is set to acc (probably doesn't matter)
    * The conversion wires I was sold swap the red and yellow wires so that acc on the head unit gets constant power (I have swapped these).
    * If I connect the red and yellow wires together the head unit works but then it wont turn off when the ignition is off. Also it will turn itself off when music starts playing as perhaps a safety feature kicks in when too much current is being drawn?
    * I have messed something up now as my dash clock does not work unless the red and yellow wires are crossed.
    Is it normal for older cars to have a low voltage acc?
    Can I damage the head unit by messing around with the wiring?
    Any help would be great
    Cheers, Leo
    ObTechAudio's Avatar
    ObTechAudio is offline Senior VIP Member
    Apr 2014
    Provo, UT
    446
    9 Post(s)
    155 Post(s)
    Re: Low voltage accessory wire on old Mitsubishi Magna 98
    I have a 1997 and I can tell you that low voltage is not "normal." It sounds like the wiring you were sold was shotty and needs to be corrected.
    CrossoverOre's Avatar
    CrossoverOre is offline CarAudio.com Elite
    May 2012
    oregon
    1,041
    205 Post(s)
    run through the fuse panels i bet you have at least one popped.
    Jepalan's Avatar
    Jepalan is offline CarAudio.com Elite
    Jun 2013
    Midwest
    603
    1 Post(s)
    158 Post(s)
    Quote Originally Posted by CrossoverOre View Post
    ^^^ this. In fact, sounds like the ACC (Accessory Power) fuse has popped, or the ACC connection to the radio is open.
  1. low voltage on brand new batt? need some help
    By Deeper_shades in forum Wiring, Electrical and Installation Help
    Last Post: 07-03-2010, 07:48 PM
  2. Voltage in my accessory wire drops when i drive and new deck turns off!!!
    By dmetri_42 in forum Wiring, Electrical and Installation Help
    Last Post: 03-30-2010, 10:54 PM
  3. Input voltage on old as dirt orion with 400 BDG bridging module
    By mcsoul in forum Wiring, Electrical and Installation Help
    Last Post: 05-13-2008, 11:30 AM
  4. remote start accessory turn on wire
    By hemi=22s in forum Car Video, Security and Electronics
    Last Post: 10-16-2007, 10:56 PM
  5. Low voltage at Remote out - Amp won't turn on
    By swifty in forum Wiring, Electrical and Installation Help
    Last Post: 08-27-2006, 01:54 PM
Tags for this Thread
