Results 1 to 5 of 5
Reload Thread: quick question
    d77543020's Avatar
    d77543020 is offline CarAudio.com Veteran
    Dec 2005
    stockton ca
    2,673
    429 Post(s)
    quick question
    looking at getting a pair of those jbl gto ez amps today because they are pretty cheap on ebay right now but i need help deciding, im looking at the ez 1000 vs the 750 do you think there will be any audible difference between a 750 and a 1000 also will there be any difference between 50x4 vs 80x4
    carlosl34741's Avatar
    carlosl34741 is offline Junior Member
    Apr 2014
    kissimmee
    Re: quick question
    Honestly it depends on what you are going to be running to them. Personally I would say go with the 1000 in the event that you need to have a little more power for your usage. They both have the same frequency response (10-280). Yet I would do the 1000. Hope that helps
    bbeljefe's Avatar
    bbeljefe is offline CarAudio.com Elite
    Jul 2013
    Shreveport, LA
    1,800
    2 Post(s)
    679 Post(s)
    Re: quick question
    If your electrical is good you should notice a difference. Which is pretty much what the above poster meant to say, I think.
    Owner, Audio Anarchy, LLC
    2915 Youree Drive, Shreveport, LA
    318-780-6149
    https://www.facebook.com/AudioAnarchyLLC
    Jeffdachef's Avatar
    Jeffdachef is offline Gunz That Turn on Nunz
    Feb 2013
    South Coast Metro, CA
    15,831
    235 Post(s)
    7701 Post(s)
    Re: quick question
    definitely a difference between 50 and 80 rms for the mids and highs would be a lot more crisp sounding in the midrange and midbass. As for the sub amp, it depends on what subs your running. A sub at full power would sound a lot better then a sub at 75% power. Its more in the line of as long as it reaches its optimal efficiency. This is not counting in those giant subs with lots of motor force and efficiency.
    09 Sienna Subs : Four Team Ascendant 18s......Sub amp: Two Taramps 15k
    Headunit: Pioneer 80PRS................................Mids/Highs amp: CT 500.2, ppi 600.2, ppi 900.4 bridged
    Front stage: Two PWX 10s per door midbass only....... PRV 6MR500 midrange....... Massive CT 2 german tweeters.
    320 amp Singer alt....... 1 group 34 under the hood 6 group31 agms in the back 560 amp hours total.
    d77543020's Avatar
    Dec 2005
    stockton ca
    2,673
    429 Post(s)
    Re: quick question
    just got the 1000 and the 4channel to be a little different cant find anyone running these new jbl amps
  1. quick question bout wiring
    By MikeofTulsa in forum General Discussion
    Last Post: 04-14-2002, 02:09 PM
  2. Quick Question
    By blaupunkt in forum Amplifiers
    Last Post: 03-30-2002, 05:10 PM
  3. Hey Zane have a quick question
    By mr.cableboi in forum Amplifiers
    Last Post: 02-28-2002, 01:34 PM
  4. quick question
    By tacoma02 in forum General Discussion
    Last Post: 01-26-2002, 07:07 AM
  5. A quick question?
    By Greg GTS in forum General Discussion
    Last Post: 01-11-2002, 09:16 PM
