Page 2 of 2 FirstFirst 1 2
Results 16 to 20 of 20
Reload Thread: 2008 350Z - Budget install - need ideas.
  1. #16
    Chromatic's Avatar
    Chromatic is offline Senior VIP Member
    Dec 2013
    B'ham, AL
    330
    92 Post(s)
    Re: 2008 350Z - Budget install - need ideas.
    Quote Originally Posted by calebkhill View Post
    Well, yes. the location is what I'm most concerned about. If you had tweets up front, but t wanted to keep the c set, then I'd cross the coax higher at about 10khz, to allow the coax to play the majority of the spectrum, and using the up front tweets just fur staging, imaging, envelope purposes.
    Ok here's where you are WAY above my head in understanding.. We're in the same state, we might just do this together (me paying you of course)... You can explain that in person if we end up doing that. I'm 34 btw.. (just in case you are wondering if you are talking to a kid, or old man, etc.)
    i believe you
    lol! Gee thanks.
    Right, I'm no expert, but it is a basic concept. I'd try my best to make sure the sub matches the enclosure.
    I'd really, really like to put that sub in the factory spot -- but I keep reading it really REALLY reduces the quality of the sub firing out at the back of the seat.. I bet a JL 8" sub would fit in that box I linked with airspace..
    But.. Now that I"m thinking about it,.. when I start this stuff,.. I ALWAYS end up doing more than I started off thinking. So I'm gonna say 10" JL Audio Sub and in a PROPER sized box facing rear. This box will work.. as they will customize the boxes "air space" if you give them the specs of your sub.
    Zenclosures 350Z 1 10" Type 2 Sub Subwoofer Box New | eBay
    IE: Going with this JL Sub.. 10Wv3-4 - Car Audio - Subwoofer Drivers - Wv3 - JL Audio ($100)
    And JL provides a good explanation of RMS power for the sub:
    Looks like "Optimum" RMS power for that sub is 200-250watts.
    So here's an Alpine 250watt Mono Amp for $109 -- Alpine MRV-M250 (mrvm250) 250W Mono Block V-Power Subwoofer
    Anything wrong with that brand/amp? For that sub?
    At moderate volume levels, 75 watts s be enough.
    Trust me, I'm not going at anything beyond "moderate".. really.. I have no need to show it off.. and my ears don't want to hear music at 100dB's+..
    So Apparently you say we can run the MB Quarts and have TWO sets of tweeters going (one on the Quartz, and one on the tweeter components I buy for the a-pillars) -- So let's say I bought these "mid range" tweeters..
    Rockford Fosgate Prime R1T-S 1" Mylar balanced dome tweeters at Crutchfield.com
    Now,.. I need a second amp to run 75x2 for MB Quarts and the ability to run 40-50wattsx2 for the Tweeters.. (can you dial down amp channels to less wattage? Probably hard to find a 4 channel amp that's 75 on two channels and 40-50 on two other channels..)
    Man this amp would ALMOST work.. for the upper tweeters,.. and the MB Quart coaxials.. Pioneer GM-A6604 (gma6604) 360W RMS 4-Channel GM Series
    It's 60 watts x 4 Channels.. Really, it "would" work.. as you can run slightly under the rated RMS.. it would be 20 watts over the tweeters RMS rating and 10 watts under the MB Quarts RMS rating.
    Almost seems like with tweeters you are going to need 3 amps. I'm seeing a pattern.. each set of speakers you add (be it one or two..) = Another amp.
    Amps need to come with a little more variety.
    Or at least say make a 4 channel amp at 4 ohms that pushes say 100 watts x 4 -- be "adjustable" where you could make channels 1 and 2 run at 75% power.. aka: 75 watts.. and Channels 3 and 4 run at 40 or 50% power.. for the tweeters. (I don't suppose you can "adjust" amps to lower RMS power per channel?
    A single sub on each channel, each channel will see 4 ohms.
    A single sub bridged, the amp will see 4 ohms bridged.
    2 subs bridged , the amp will see 4 ohms.
    It also depends if the sub is svc or dvc, and how you wire then...
    Not an issue here -- I'm going one sub.. period. Not 2, not 3.. not 0.. but 1 -- It shall be a 10" it seems,.. as 8" seems around the same price range, and it seems a little silly to spend roughly the same money for an 8, when you can do the same with a 10" which is still small enough to have the recoil/reaction time to play fast music/rock music (unlike say 15's.. and even 12's aren't as responsive as 10's and smaller)..
    Oh, and I remember when I added a crossover (just a cheap one.. I see them out there with a "bass knob" now for $60 -- We could run that bass knob up near the cupholders and empty switches where the higher 350z's have buttons (but mine has blank spots lol) -- and flush mount it in one of those for an on the fly "bass" level. OR, not go to the hassle, and just put the Crossover in an accessible location to adjust as needed. I like crossovers cause it lets you fine tune your speakers to really get them into the right levels.
    While headunits are nice ,.. Cross-overs let you fine tune much more accurately and precisely and aren't extremely expensive.
    So you getting the picture in your head of what this thing is going to look like yet?
    Here's the car btw if you've wondered lol..
    however much headroom you can afford, the better.
    Hrmm.. well that makes amps with WAY more power RMS than the speaker needs a "good" thing ? Meaning I can run a 100 watt channel on a 70watt speaker and it won't damage it? Fill me in!
    You live in Alabama, maybe you'd want a side job for some cash
    Thanks
    Maybe we could work something out
    If your willing.. and you seem to have experience installing -- I'm sure we could work something out where you install,.. I am your "helper" essentially.. and we get it done in an afternoon (depending on how fast we are)
    If we do this.. then I can expand to get all of the above mentioned items (though we'll refine the amps) -- and Then you can tell me what wiring "kit" and fuse box etc to order and I throw it all in the hatch.. and we get it done.
    An install like this would take you (us).. like what 4-6 hours maybe? I guess it all depends on how familiar you are with car stereo installs and how many 'tricks' you have up your sleeve for getting the time consuming part of the task done.. which I assume is probably running wires through tight places?
  2. #17
    momofx's Avatar
    momofx is offline CarAudio.com Elite
    Oct 2012
    IL, USA
    567
    142 Post(s)
    Nice 350Z buuuuut man I just have to do this.... last night I was reading this thread and then I ...........
    j/k bud I thought that pic was hillarious considering the ummmm long posts :p
  3. Likes Chromatic liked this post
  4. #18
    calebkhill's Avatar
    calebkhill is offline CarAudio.com Elite
    Dec 2012
    Phenix City, Alabama
    1,101
    326 Post(s)
    Quote Originally Posted by Chromatic View Post
    lol! Gee thanks.
    pM me, we should text instead
    "When I listen to a stereo loudspeaker playback in my room and an auditory scene has formed in my mind, how would I know that what I hear is an accurate replica of an auditory scene that could be had at the recording venue? Or more generally, that this is an auditory scene that could have existed at all?"
  5. Thanks Chromatic thanked for this post
  6. #19
    calebkhill's Avatar
    Dec 2012
    1,101
    326 Post(s)
    Quote Originally Posted by momofx View Post
    Dam, didn't realize that lol
  7. #20
    Chromatic's Avatar
    Dec 2013
    B'ham, AL
    330
    92 Post(s)
    ROFL.. Yeah, I'm notoriously long winded in text.. not so much when talking though. Sorry so long.. plenty of TLDR's I'm sure.
  1. Need ideas for Audi A6 install
    By sandbags in forum Enclosure Design & Construction Help
    Last Post: 11-28-2008, 10:53 AM
  2. Need Ideas for budget setup
    By RI-Matt in forum General Discussion
    Last Post: 09-14-2006, 07:30 PM
  3. Need ideas for my install....
    By cjj2d in forum General Discussion
    Last Post: 06-02-2006, 02:20 AM
  4. Need Ideas/Pics For Mustang Amp/Sub Install... PLEASE!
    By Slody4Futbol in forum Enclosure Design & Construction Help
    Last Post: 07-01-2004, 01:29 PM
  5. mustang install plus i need ideas for a system
    By fosgate SVT in forum General Discussion
    Last Post: 04-28-2002, 12:04 AM
Tags for this Thread
