Page 2 of 2 FirstFirst 1 2
Results 16 to 29 of 29
Reload Thread: New to car audio, looking for recommendations.
  1. #16
    bmk6795's Avatar
    bmk6795 is offline CarAudio.com Elite
    Jul 2012
    Spartanburg, SC
    1,275
    268 Post(s)
    Re: New to car audio, looking for recommendations.
    Quote Originally Posted by BlackHawk41042 View Post
    I Listen to literally all kinds of music so I want some subs that would hit a fairly large range of notes. I am pleased with how my 15" sounds but I was thinking about a 12" because I heard they were the best size for hitting highs and lows, but if I were to get 12" subs I think I would get two because I feel my one 15" has trouble hitting multiple notes at once. I am slightly unsure about getting 12's because I like having a 15" overall, do you think a higher quality 15 could hit multiple notes better than my current one or would I have to get 2 subs?
    the way your sub plays notes isn't due to it's size, it's all about your box, if you are using a pre fab box there lies your problem, most pre fabs do not have the proper airspace, port area, and are usually tuned pretty high. in regard to size, 15s can play just as fast/punchy as 10s or 12s.
    Link to Itrader feedback: http://www.caraudio.com/forums/itrader.php?u=1017953
  2. #17
    globalminds_ent's Avatar
    globalminds_ent is offline CarAudio.com Elite
    Dec 2011
    oxford ms
    1,214
    414 Post(s)
    I like how 12s sound but he is right to tho i also like poeted over sealed. Just my thoughts tho
  3. #18
    BlackHawk41042's Avatar
    BlackHawk41042 is offline Junior Member
    Dec 2013
    Cincinnati, OH
    7 Post(s)
    Ok so starting with an amp I was thinking about getting a kenwood kac-9105D. Any opinions on the amp? If it sounds good what would be a good sub/subs (one 15"/two 12")to get with it.
  4. #19
    mylows10's Avatar
    mylows10 is offline B2,singer,ampere rep
    Sep 2009
    monterey , ca
    54
    22,442
    142 Post(s)
    1 Thread(s)
    6016 Post(s)
    Ok guy. A American bass vfl 80.1 an xfl 15 and a custom box will be one of your best band for the buck systems as far as new if you wanna spend a bit more. Obsidian 15 a saz 1500 or dc 1.2 and a custom box. If you want used. Get a used amp. Like the sundown dc. Vfl And a sub like the obsidian. Sa 15 xfl dc lvl 3 or even a fi or tantric. These mainstream brands aren't as good as you think But you'll still need proper wire size to support these amps but you'll be better off getting one of these then maybe a better battery , agm , and definately the big 3
    pioneer avhx 4800 dvd, ampere tfhe 9.0 and 150.4 with arc audio xxd 4080
    4 d3100 and 3 deka 8a31 and d975 ,270 dc power and 320 amp singer alt
    B2 ref mids,Cdt es6 mids cdt es 010 tweets x2 ,es 03 Mids x 2 mx1000 , sky high ,eb flex, and stinger hpm o gauge wires ,also 2 crossfire xsv2 18s in a 4th order no wall box
    NOR CAL DB DRAG JUDGE
    http://www.dcsoundlab.com
  5. #20
    Dec 2013
    Cincinnati, OH
    7 Post(s)
    Thanks a lot you seem to talk pretty highly about this American Bass company so I'll give the amp and sub a try. One last question though, how does one determine how much air space is optimal for a subwoofer?
  6. #21
    AndrewHD's Avatar
    AndrewHD is offline Senior VIP Member
    Oct 2012
    Orange County, CA
    308
    89 Post(s)
    The manufacturer usually will state the recommended airspace needed. A single 12 ported would be good in that car in my opinion and will fit the bill of your budget and listening taste. You don't want to go too big on the subs when going ported just to ensure your enclosure can be made to spec especially in a trunk car. Keep in mind, you also need to allow room for the port which is not included in the net airspace of the box.
    2005 Impala
    DC Power 300 amp alt
    XS Power D3400 under hood
    Big 3 Rockford 1/0 gauge
    Eclipse AVN 726E
    Rockford T3 6.5 component set
    Rockford 1000.4-ADCP
    Rockford 2500.1-BDCP
    FI Q 15 Sealed 2.5 cu. ft
  7. #22
    Dec 2013
    Cincinnati, OH
    7 Post(s)
    My friend is now letting me borrow his sealed 15" enclosure and I definitely prefer sealed over ported. I feel like I would rather have two 12" subs in a sealed box rather than one 15"
  8. #23
    brian84corvette's Avatar
    brian84corvette is offline CarAudio.com Elite
    Feb 2008
    coral springs FL.
    1,540
    1 Post(s)
    195 Post(s)
    i bet you could fool around with the gear you currently have , build or have built for you a better box, and play with placment in the trunk , and tune your system in. and be pretty pleased with the results.
    buying new gear seems like the eaziest thing to do , but tuning it in is all part of the process. you have to learn yourself what works vs doesnt work.
    i recomend
    down loading a box building program. and searching the small specs on your current subwoofer to help you design a box to its specific requirments.
    once you get messing with all this information for a bit it sinks in.
    brians ghetto burb of amazing and cheap and loud build log
    http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/604559-get-loud-cheap-ghetto-blaster-burb.html
  9. #24
    Jeffdachef's Avatar
    Jeffdachef is online now Gunz That Turn on Nunz
    Feb 2013
    South Coast Metro, CA
    15,943
    240 Post(s)
    7770 Post(s)
    thats because you probably only heard subs in piece of junk ported boxes. Ported outdoes sealed in almost every way IMO. However if you go ported, it cannot be a box you buy from the internet or some local shop. You say you dont like ported, well judging from your experience its most likely because you bought a piece of **** box and its tuning is conflicting with your cabin gain of your vehicle along with poor design.
    I'm not sure how the mtx 6000 sounds since i havent heard it in real life, but if its a decent sub, you can model an enclosure design so it would hit a wide range of notes loudly from 30-80hz with winISD(look for a tutorial on youtube, its a free program).
    09 Sienna Subs : Four Team Ascendant 18s......Sub amp: Two Taramps 15k
    Headunit: Pioneer 80PRS................................Mids/Highs amp: CT 500.2, ppi 600.2, ppi 900.4 bridged
    Front stage: Two PWX 10s per door midbass only....... PRV 6MR500 midrange....... Massive CT 2 german tweeters.
    320 amp Singer alt....... 1 group 34 under the hood 6 group31 agms in the back 560 amp hours total.
  10. #25
    Dec 2013
    Cincinnati, OH
    7 Post(s)
    My friend just pointed out to me earlier that my power cable running from my battery to my amp is only 6 guage. If I were to upgrade to a 0 guage wire would I have to get a new battery
  11. #26
    Dec 2011
    oxford ms
    1,214
    414 Post(s)
    I say big 3 and run 0 even if u don't change your battery even though u should, but runnin 0 won't hurt imo.
  12. #27
    Feb 2008
    coral springs FL.
    1,540
    1 Post(s)
    195 Post(s)
    this is not true. i have no idea why he would tell you that.
  13. #28
    Dec 2013
    Cincinnati, OH
    7 Post(s)
    He didn't tell me that it would require me to get a new battery that was just something I was curious about. He has 4 guage wire in his car and I asked him about if I changed my power and ground to 0 guage and he said 0 guage is something you would use more for a competition grade system. So I thought it would drain your battery faster if you didn't get a new one.
  14. #29
    Dec 2013
    Cincinnati, OH
    7 Post(s)
    Also instead of an xfl 15 I think I'm leaning more towards two xfl 12's
  1. New to Car audio looking to upgrade
    By AxTR in forum General Discussion
    Last Post: 05-03-2013, 08:56 AM
  2. Replies: 4
    Last Post: 01-06-2011, 01:49 PM
  3. new to car audio! looking to buy a system
    By bquinn33 in forum General Discussion
    Last Post: 03-08-2010, 07:34 PM
  4. Replies: 5
    Last Post: 11-28-2008, 10:14 PM
  5. New to Car Audio - Lookin for right amp
    By LiNeL1041 in forum Amplifiers
    Last Post: 07-17-2006, 03:59 PM
