Results 1 to 14 of 14
Reload Thread: 67' Camaro sound system. Help
    jiggernaut's Avatar
    jiggernaut is offline 67 camaro am radio
    Nov 2013
    Louisiana
    18
    1 Post(s)
    Hi,
    Noob here.
    I'm reaching the car audio point in my camaro build. My camaro's original head unit was a GM am radio it had one 5x7 speaker in the package tray and one speaker under the front dash. I would like to upgrade and I'm bewildered in the plathora of audio equipment available. Please, Help.
    Currently, I purchased a Retrosound Model 2 head unit. The replica-head units aren't known for their sound quality but, I'm keeping the car period correct. The Model 2 looks the part.
    The typical set up that doesn't require too much sheet metal work is 6.5 components in the kick panels or doors, two 6x9 speakers in the package tray, and one 10"sub in the trunk. My car has a big block, cam, and 3" exhaust. The engine/exhaust is pretty loud. So, I don't really see any added value in top shelf SQ speakers. I have dynamat and foam sheeting on the ready for sound deadening.
    I found a craigslist deal on two Memphis audio amps, MR4.480 and MR1.1200 for 300$. Good amps? Too much wattage? good deal? any thoughts let me know!
    Same goes for the speakers, a friend of mine recommends Focal access line. I've bought and have been satistfied with 6.5 Memphis Audio components in my truck. Sonicelectronic has good reviews on some low end kicker speakers. But, I don't really know. I want to keep the speaker/amp investment <$1000 but I can stretch to 1500$ if need be.
    Trunk space is limited. The spare tire is in the trunk. One 10 or 12 sub and box will fit easily. Two will be a squeeze.
    Thanks in advance, Landon
    Side Show's Avatar
    Side Show is offline Bringin The Noise
    Aug 2007
    Australia
    3,337
    457 Post(s)
    Re: 67' Camaro sound system. Help
    6.5"splits in the kick panels, two way coax in the rear shelf 6", and prob a 12"sub if you can fit it. (custom ported box)
    I am yet to listen to a system that has 6x9's and a sub that sounds half decent.
  3. Thanks jiggernaut thanked for this post
  4. #3
    CerwinVega_Fan's Avatar
    CerwinVega_Fan is offline Coolest Member
    Apr 2009
    Dallas,TX
    4,395
    3 Post(s)
    773 Post(s)
    Pics!?
  5. #4
    hispls's Avatar
    hispls is online now CarAudio.com Veteran
    Sep 2009
    Cape Cod, Massachusetts
    9,963
    15
    36 Post(s)
    4052 Post(s)
    Quote Originally Posted by CerwinVega_Fan View Post
    Pics!?
    Definitely need pics of this car!
    I'd say having some custom kickpanels made would be ideal. You could reserve your factory panels to return to OEM condition if you ever sell it and kickpanel is just a good location for components.
    I find speakers on the dash is an acoustic nightmare and would avoid at all costs. A good set of components in the kicks and a single woofer in a good ported box would do you nicely. The Memphis products are pretty good. Probably better than entry level Kicker IMO, though Kicker makes some decent stuff.
    One thing you may want to consider is a lot of old cars have rather anemic charging systems, you might want to consider how big your alternator is and plan for a high quality AGM battery under the hood to help keep up with music. If it's a really weak alternator you may want to either bump down to lower power, or get the 1200W amp and run at higher impedance... you'll gain a good bit of efficiency at the expense of some output, but if you're buying a bigger amp than you really need it's a fair tradeoff.
  6. Thanks jiggernaut thanked for this post
    Likes blobb454 liked this post
  7. #5
    jiggernaut's Avatar
    Nov 2013
    Louisiana
    18
    1 Post(s)
    Pics! I have!
    The stance is a work in progress. The front will be lowered. Please, disregard the awful rims. Those will be changed.
    The grill in the center of the dash is where the original speaker went. The left speaker hole in the package tray was cut out by a previous owner to accommodate another speaker. The right hole is the original.
    Attached Thumbnails Attached Thumbnails 67' Camaro sound system. Help-20131106_121910.jpg   67' Camaro sound system. Help-20131106_121543.jpg   67' Camaro sound system. Help-20131106_121832.jpg   67' Camaro sound system. Help-enginecompartment.jpg   67' Camaro sound system. Help-20131106_124629.jpg
    67' Camaro sound system. Help-20131106_124622.jpg   67' Camaro sound system. Help-20131106_122402.jpg   67' Camaro sound system. Help-20131106_121933.jpg
  8. #6
    jiggernaut's Avatar
    Nov 2013
    Louisiana
    18
    1 Post(s)
    I've been looking at these. They look good I'm pretty sure I'll get a pair, unless someone contests them.
    Nothing in the package tray?
    I'm on top of the charging system. I upgraded the alternator to a 120 amp and I also have an AGM battery relocated to the trunk with 1/0 DLO battery cable.
  9. #7
    Freeman's Avatar
    Freeman is offline I TrY
    May 2013
    Watertown, SD
    834
    310 Post(s)
    Make a build log!
    1986 Nissan hardbody
    Hu:Kenwood Kmm-100u
    front:1 Cheep Kenwood speaker.
    Rear:the 3in of room behind my seat where my amp sits
    Sub:soon
    Amp:polk pa330
    Wiring:1/0 knu kca to 4gauge distribution block and 1/0 kca big 3
  10. #8
    jiggernaut's Avatar
    Nov 2013
    Louisiana
    18
    1 Post(s)
    Bump
    Image Dynamics seems to get high reviews in my price range. Does anyone see anyting wrong with going with a full ID system?
    5 channel i5800
    Pair of CTX-69
    Pair of CTX-6.5cs
    One ID12 D4 V.3 sub.
  11. #9
    Side Show's Avatar
    Aug 2007
    Australia
    3,337
    457 Post(s)
    i'd recommend 2-way coaxils for the rear shelf if anything.
  12. Thanks jiggernaut thanked for this post
  13. #10
    jiggernaut's Avatar
    Nov 2013
    Louisiana
    18
    1 Post(s)
    Quote Originally Posted by Side Show View Post
    Copy that. Would you recommend Image Dynamics products ?
  14. #11
    Side Show's Avatar
    Aug 2007
    Australia
    3,337
    457 Post(s)
    yes, but keep in mind that most brands make various diff speaker lines, i'd suggest you go have a listen to some speakers on a sound board or in your buddy's system.
  15. #12
    Apr 2009
    Dallas,TX
    4,395
    3 Post(s)
    773 Post(s)
    Baddass ride bro!
    You can't go wrong with image dynamics bro.
    I was gonna suggest Boston acoustics but ID works.
  16. Thanks jiggernaut thanked for this post
  17. #13
    nauc's Avatar
    nauc is offline CarAudio.com Veteran
    Mar 2005
    Home
    2,768
    1 Post(s)
    43 Post(s)
  18. Thanks jiggernaut thanked for this post
  19. #14
    jiggernaut's Avatar
    Nov 2013
    Louisiana
    18
    1 Post(s)
    Q12 - Fi Car Audio Store
    get the dual 2 ohm sub
    Thanks nauc, I like the Fi Q12. Hand built, quality, good reviews, I'm on board.
    I'm after crisp clean bass over rattling the nuts and bolts out of my car. I've been researching the options and It seems High QTS, the "I heat ring" and a sealed box would help accomplish that goal. Should I purchase the "I heat ring" upgrade?
  1. Building Camaro Sound System - Help!
    By MisterDeadeye in forum General Discussion
    Last Post: 05-31-2009, 02:58 PM
  2. Sound System help!.
    By Striker in forum Wiring, Electrical and Installation Help
    Last Post: 02-09-2005, 12:04 PM
  3. 91 Golf Sound System - Help
    By Reggie Lives in forum General Discussion
    Last Post: 08-23-2003, 03:52 PM
  4. Sound System Help
    By and1 in forum General Discussion
    Last Post: 10-21-2002, 11:10 PM
  5. I need complete sound system HELP
    By STruC in forum General Discussion
    Last Post: 03-25-2002, 11:37 PM
Tags for this Thread
