Page 1 of 2 1 2 LastLast
Results 1 to 15 of 24
Reload Thread: 2 ohm vs 4 ohm
    bradl79's Avatar
    bradl79 is offline CarAudio.com Elite
    Jan 2013
    NLR
    1,407
    1 Post(s)
    447 Post(s)
    2 ohm vs 4 ohm
    should i wire my sub at 2 ohm or 4 ohm
    Amp: Kicker 11DX250.1
    Sub: Rockford Fosgate R2D2-10
    Head Unit - Clarion NX702 w/Backup Cam
    DSP - JBL MS-8
    Amp 1 - MB Quart 800.4 (Sub, Mid Bass)
    Amp 2 - MB Quart 600.4 (Tweeters/Mid Range, Center)
    Amp 3 - MB Quart 400.2 (Rears)
    Fronts Stage (3-Way) - CDT HD-6 (Mid Bass) CDT ES-03 (Mid Range) CDT DRT 26s (Tweeters)
    Center Stage - CDT HD-100 (Hi) CDT ES-03 (Lo)
    Rear Stage - CDT HD 6EX
    Sub - Sealed in Custom Box - 12" Sundown E12V2
    Deadened/MLV - All Doors and Trunk (Reckhorn 80mil)
    mylows10's Avatar
    mylows10 is offline B2,singer,ampere rep
    Sep 2009
    monterey , ca
    54
    22,442
    142 Post(s)
    1 Thread(s)
    6016 Post(s)
    Re: 2 ohm vs 4 ohm
    you mean 1 ohm or 4 ohm
    pioneer avhx 4800 dvd, ampere tfhe 9.0 and 150.4 with arc audio xxd 4080
    4 d3100 and 3 deka 8a31 and d975 ,270 dc power and 320 amp singer alt
    B2 ref mids,Cdt es6 mids cdt es 010 tweets x2 ,es 03 Mids x 2 mx1000 , sky high ,eb flex, and stinger hpm o gauge wires ,also 2 crossfire xsv2 18s in a 4th order no wall box
    NOR CAL DB DRAG JUDGE
    http://www.dcsoundlab.com
    Full Tilt's Avatar
    Full Tilt is offline Bonafide MAFer
    Mar 2012
    Iowa
    1,977
    848 Post(s)
    Re: 2 ohm vs 4 ohm
    Right...2 ohm DVC subs can only be wired at one or four ohms (with one driver). Since that amp isn't stable at 1 ohm, you're going to be stuck at 4.
    Quote Originally Posted by T.I.K. View Post
    Careful, by those definitions Spider Monkey is a contributing member, I don't think he even knows what a subwoofer is.
    Quote Originally Posted by Truman View Post
    Thanks quackhead. Your the only person who agrees with me. Jesus Christ I have like 40 post and I've been called a ******* like 37 times
    bradl79's Avatar
    Jan 2013
    NLR
    1,407
    1 Post(s)
    447 Post(s)
    Re: 2 ohm vs 4 ohm
    i have it wired at 2 ohm right now, so should i just re wire it to 4 ohm then?
    DSP - JBL MS-8
    mylows10's Avatar
    Sep 2009
    monterey , ca
    54
    22,442
    142 Post(s)
    1 Thread(s)
    6016 Post(s)
    Re: 2 ohm vs 4 ohm
    Quote Originally Posted by bradl79 View Post
    then your only using one coil , not both
    bradl79's Avatar
    Jan 2013
    NLR
    1,407
    1 Post(s)
    447 Post(s)
    Re: 2 ohm vs 4 ohm
    sorry i am new to DVC and subs, what would i get out of the using both coils? wiring it to 4 ohm?
    DSP - JBL MS-8
    Full Tilt's Avatar
    Mar 2012
    Iowa
    1,977
    848 Post(s)
    Re: 2 ohm vs 4 ohm
    Go ahead and check your impedance with a DMM. You're either running at 1 ohm or you're only running one of your coils. Either case = no bueno.
    Full Tilt's Avatar
    Mar 2012
    Iowa
    1,977
    848 Post(s)
    Re: 2 ohm vs 4 ohm
    Using both of your coils is basically using your sub to it's full potential. Wiring to four ohms would reduce the power your amp will be able to send to your subwoofer, but at least then you'll be running it the way it was designed to operate.
  9. #9
    bradl79's Avatar
    Jan 2013
    NLR
    1,407
    1 Post(s)
    447 Post(s)
    Re: 2 ohm vs 4 ohm
    i am running 2 ohm, i checked before i wired it
    DSP - JBL MS-8
  10. #10
    Full Tilt's Avatar
    Mar 2012
    Iowa
    1,977
    848 Post(s)
    Re: 2 ohm vs 4 ohm
    So you're sending 250w (probably a bit more) to only 1 coil on a sub that's rated at 250? How long have you been running it this way?
  11. #11
    Side Show's Avatar
    Side Show is offline Bringin The Noise
    Aug 2007
    Australia
    3,337
    457 Post(s)
    Re: 2 ohm vs 4 ohm
    you have it wired wrong, google how to wire up a single duel 2 ohm sub
  12. #12
    bradl79's Avatar
    Jan 2013
    NLR
    1,407
    1 Post(s)
    447 Post(s)
    Re: 2 ohm vs 4 ohm
    ok thank you all, i have been running it for about 2 months, will this hurt the amp or sub?
    this is how i have it
    I Guess i need to do it like this
    DSP - JBL MS-8
  13. Likes Full Tilt liked this post
  14. #13
    Side Show's Avatar
    Aug 2007
    Australia
    3,337
    457 Post(s)
    Re: 2 ohm vs 4 ohm
    correct, hopefully the sub will be fine.... also don't forget to retune and reset all your settings too
  15. #14
    bradl79's Avatar
    Jan 2013
    NLR
    1,407
    1 Post(s)
    447 Post(s)
    Re: 2 ohm vs 4 ohm
    i am sure it is, b/c i set my gains with a cd which was 4v and then i mainly play my music through the aux port which is about 2v so i do not get much voltage with aux, i tested using a Oscope and not getting much voltage to hurt anything, but i am going to re wire tomorrow and reset my gains, will it make my sub sound any better?
    DSP - JBL MS-8
  16. #15
    Side Show's Avatar
    Aug 2007
    Australia
    3,337
    457 Post(s)
    Re: 2 ohm vs 4 ohm
    yep, i'd say you'll see a huge improvement
  1. DVC 4 ohm vs DVC 2ohm?
    By basketball346 in forum General Discussion
    Last Post: 03-21-2004, 02:34 PM
  2. Help.....2 ohm vs 4 ohm
    By NKC in forum Subwoofers
    Last Post: 03-20-2003, 05:58 PM
  3. 1 ohm vs 4 ohm
    By nswartley in forum Amplifiers
    Last Post: 03-19-2003, 08:42 PM
  4. Replies: 2
    Last Post: 10-26-2002, 01:10 AM
  5. 2 ohm vs. 4 ohm?????????
    By Hurst421 in forum Subwoofers
    Last Post: 10-06-2002, 02:07 PM
