Re: 88 Prelude budget build (HELP)
Op make sure you leave room for your amps and batteries. I doubt you can fit 2 15's in a proper enclosure and still have room for the rest of your equipment. You might be able to but you will be limited to sub selection as not all subs like small ported enclosures. If this is for daily I'd suggest 2 12"s n they're proper enclosure tuned nice and low. If it's an spl build you might get away with 2 15"s using aero ports tuned high. For budget batts deka and Duracell agm 31's are a good bang for the buck. There's a lot of good used amps out there right now on the forums you just gotta look for the best deals. You can get a quality Korean 3.5k for 4-600$
Sony h/u
Front stage-CDT CL Comps
Ppi p.600.2
Knu ofc 4g
Sub stage-Single 15" Crossfire XSV2 in 4.25 cu box tuned to 31hz
AB Vfl 120.1
Knu ofc 1/0
Bookmarks
