Results 1 to 6 of 6
Reload Thread: sub amp to home receiver
    PV Audio's Avatar
    PV Audio is offline The Vision of Sound
    Apr 2004
    Indy
    29
    19,655
    hey yall. i just got my receiver and my speakers and my fmod. i think that i need a sub amp to drive the type-s. is this a good amp for my type-s in my room?
    http://www.partsexpress.com/pe/showd...number=300-804
    how would i connect that to the receiver? how do i connect the sub to the amp? straight speaker wire? thanks to anyone who can help me out.
    PV Audio's Avatar
    Apr 2004
    Indy
    29
    19,655
    Re: sub amp to home receiver
    anyone? *cricket noises*
    Berry47's Avatar
    Berry47 is offline CarAudio.com Elite
    Dec 2003
    My Pants
    34
    1,076
    this might be nice .......
    if it is dual 4 ohm...
    http://www.musiciansfriend.com/srs7/...e_pid/482052X/
    Mine: CDT, Eclipse, Diamond Audio, Dayton, Aura
    Wifey: Infinity, Concept, Pioneer, Profile, JBL
    Refs: Ruckus, MSSOKC
    CWT's Avatar
    CWT
    CWT is offline Member
    Jan 2004
    Dallas, TX
    46
    144
    lemans23;
    The amp you show in your link is intended to be mounted on the back of a sub box; it actually needs a hole in the back of the box to sit inside of; my KLH 10" sub has an amp with a similar design. For home use, it looks pretty good; as long as your not trying for high SPL.
    The amp that berry47 shows is a pro, bridgable rack mounted unit that a band would use. It is a simple 2-channel amp that although it has gain controls, it does not have a crossover or phase selector. It was designed to run full range, not just subs. Its input jacks are 1/4" TRS or XLR plugs that use cables typically used by recording studios and bands for concerts. It is a strong amp though.
    Which model type-S sub do you have? In any case, a single 4-ohm voice coil or a dual 2-ohm (Wired in series) would be ideal for the amp you've shown. If yours is a dual 4-ohm, then you will have no choice but to wire it in series for 8 ohms; but then your only going to get 150 watts out of that amp, which if I read Alpines' web site correctly, that's not quite enough to power the type-S sub diecently. The reason I say this, is the amp is only capable of going down to a 4-ohm impeadance load; not a 2-ohm.
    How do you connect it to your reciever? From the sub out single RCA on the back of the reciever to the left RCA channel on the sub amp (Usually marked "mono"); if your reciever does not have a sub out jack, then the standard RCA stereo line out to the stereo line in on the amp will do. If that's not possible, then the amp you've got shown is eqiupped with a high power pass-thru; simply run the front left and right speaker wires to the high power inputs (Red and black banana jacks), then from the high power outputs, run wires to your front speakers.
    Wiring it to your type-S sub? Like I said, this amp is intended to be mounted in a hole in the back of a box; most home-use subs use a ported, side-firing cube design. If your thinking of just running it not attached to any box, that may be possible too; but you will have to run wires into whatever sub enclosure you are using. The speaker wires attach to the sub and the amp just like a car amp; just remember what I said about the impeadance. There should be a pair of speaker terminals (Not shown in the picture) on the back-side of the amp.
    Sorry if this was too long; let me know if you have any questions.
    Later.
    PV Audio's Avatar
    Apr 2004
    Indy
    29
    19,655
    Quote Originally Posted by CWT
    lemans23;
    Later.
    dang thanx! i thought i said it was a type-s 1040. oh well. thats the sub then.
    helotaxi's Avatar
    helotaxi is offline Kilroy was Here
    Dec 2003
    South Central (New Mexico that is...)
    42
    8,933
    150W would be plenty for the sub. You don't have to give it RMS rated power. That is the MAX not the MIN.
    Artificial Intelligence is no match for Natural Stupidity.
    Never underestimate the power of stupid people in large numbers.
    Life's tough...it's even tougher when you're stupid.
  1. Loudest (Inexpensive) 10" Sub (plus amp)
    By scottrc5391 in forum Subwoofers
    Last Post: 11-23-2005, 12:12 PM
  2. My amp is SUCKING my subs inward!!
    By substance in forum Amplifiers
    Last Post: 04-15-2004, 12:20 AM
  3. 2-channel amp for $150? Recommendations?
    By SiliconBadger in forum Amplifiers
    Last Post: 04-06-2004, 12:19 PM
  4. Crrent amp Draw? need help As fast as possible :)
    By J13ntv in forum Wiring, Electrical and Installation Help
    Last Post: 02-02-2004, 08:48 PM
  5. strangest wiring problem ever, PLEASE HELP!!! (thanks!)
    By dragonplayboy in forum Wiring, Electrical and Installation Help
    Last Post: 12-21-2003, 04:51 PM
