Results 1 to 7 of 7
Reload Thread: Dynamat sheets or spray?
    <Black>'s Avatar
    <Black> Guest
    Hey guys... I have a hard decision here... I dont know wether to go with Xtreme sound deadening sheets for my car or go with the spray? or both? I have a 96 cutlass supreme and it raddles like a Mutha!! and lots of road noise. any sugestions?
    thanx
    you can e-mail me also [email protected]
    <img src="tongue.gif" border="0">
    <Bassik LowZ>'s Avatar
    <Bassik LowZ> Guest
    i remember this delima... when i had my 89 blazer i gutted the entire interior and lined and lined the whole floorboard, luggage area, adn roof with dampening sheets, then in all the awkward places (tailgate, kicks, doors, etc... i used liquid dampening. it worked pretty good ...later
    <Black>'s Avatar
    <Black> Guest
    Thanx man that is a thought... anyone else have any ideas?? I cant do any of this stuff yet cuz I am in minnesota and it is like 0 degrees outside and it is recommended that it has to be room tempture so... closer to spring I am gonna do this just need the in put... well to go with sheets or spray or even both....
    jaminlogic's Avatar
    jaminlogic is offline Junior Member
    Dec 2001
    Maryland
    13
    Hello,<br /> Use both. You would want to user the sheets for the floor boards and trunk of your car. That alone will eliminate a lot of your road noise. I'd use the spray on the door panels and areas where it's hard to have the sheets stay in place and are very curvy. The floor panels and trunk interior will be ideal to use sheets since they're generally flat and you can lay the shetts firmly in place.
    -Jaminlogic<br />Eclipse 8303r<br />Infinity Kappa Components & 3-way<br />MTX Thunder Amps (2)<br />Carver Pre-Amp Processors<br />12" Aura Force<br />Lightning Cap by Rockford Fosgate<br />Wiring by Phoenix Gold<br />Paid $1200.00 for total system.
    <Black>'s Avatar
    <Black> Guest
    How long does both of the dynamat stuff dry? it pretty cold up here now so I am sure it would be a while... just wondering
    prolly going to use the sheets for the floor and most of the trunk and the spray for the trunk lid, doors and back shelf... sound good?
    ramos's Avatar
    Dec 2001
    Virginia
    53
    10,329
    104 Post(s)
    If you have alot of road noise through the floor of the car. Try using some regular house hold carpet padding. Pull your carpet up and put a layer of the padding underneath. You will be surprised at how effective it is at killing road noise. As for the rattles. The sheets work better. THe sheets add mass to the rattling panel which stops the rattling. Check out <a href="http://www.b-quiet.com" target="_blank">http://www.b-quiet.com</a> They have a product called brown bread. It works as good as dynamat for about half the price.
    5 % equipment
    90 % install
    5% beer
    ghawkes10's Avatar
    ghawkes10 is offline Member
    Sep 2004
    MD
    30
    Re: Dynamat sheets or spray?
    Have any of you guys ever heard of a product called Quiet Coat. If so, have you used it? Were the results about what you expected...compared to Dynamat and other "vibartion dampening" products?
    Thanks.
    Grahm
  1. WTB 2 sheets of dynamat
    By tyoung87 in forum Wanting to Buy (WTB) - Car Audio
    Last Post: 08-04-2010, 06:36 PM
  2. Is spray Dynamat worth it's weight?
    By IowaBoomer in forum General Discussion
    Last Post: 11-13-2002, 01:40 PM
  3. Where exactly do you put the spray type Dynamat???
    By 95cougarxr7 in forum Wiring, Electrical and Installation Help
    Last Post: 03-29-2002, 01:16 AM
