Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 16 to 30 of 32
Reload Thread: Matching amps with battery fuse...
  1. #16
    2010HHRUMADBRUH's Avatar
    2010HHRUMADBRUH is offline Senior VIP Member
    Jan 2009
    East Bay, CA
    32
    154
    54 Post(s)
    Re: Matching amps with battery fuse...
    Quote Originally Posted by naughtyca View Post
    wow my mistake, so if you are using a 4ga wire and your amp recommends a 200a external fuse, you still use 150a? or do you need to up your 4ga wire?
    You still want to use an in-line fuse holder right before the amp, IMO. I had to do that for my 4080dsm. I always get a lower fuse and kinda guess when it's clipping (don't have tools to really test it, but you can basically tell when it's clipping, and the lower fuse rating can be a decent estimate as to when you are clipping the amp, I guess)
  2. #17
    NASTY08IMPALA's Avatar
    NASTY08IMPALA is offline CarAudio.com Veteran
    Aug 2012
    LOUISVILLE, KENTUCKY
    6,131
    3 Post(s)
    2554 Post(s)
    yes if your amp is goin to outdraw the amout of power your wire can handle its time to upgrade
  3. #18
    Aug 2012
    6,131
    3 Post(s)
    2554 Post(s)
    dbl post
  4. #19
    Jan 2009
    East Bay, CA
    32
    154
    54 Post(s)
    Quote Originally Posted by NASTY08IMPALA View Post
    ok thats fine but for the 4ga ofc u wana use 150..thats what i use for my 4ch
    ****, do they even make 150 ampere AGU fuses?
    I told this guy to order the fuse holder but I guess it didn't come with a fuse.
    There is no hurt in fusing lower, other than popping more fuses, right?
  5. #20
    Aug 2012
    6,131
    3 Post(s)
    2554 Post(s)
    Quote Originally Posted by 2010HHRUMADBRUH View Post
    time to upgrade to anl ..i wouldnt fuse below myself.
  6. #21
    thatguy12's Avatar
    thatguy12 is offline CarAudio.com Elite
    Dec 2012
    Madtown, WI
    582
    206 Post(s)
    then ive been doing it wrong for a while if thats true. when my amp recommends a 150 external fuse because it doesnt have any on the amp ive been under the impression i use a 150 amp fuse regardless of wire?that just seems wierd.
    Sold To: Goodear and ATC_DJ
    Bought From: Dtrom and f1mclarenagr
    Build about to go down in my new 2006 Honda Crv
    Head Unit: pioneer deh 80prs, Front stage: Hertz HSK Components, Rear: Hertz dsk comps , Sub Stage: Tantric HD 10s, Sub Amp: AudioQue 3500.1, Highs Amp: AudioQue 120.4
    Electrical Consists of a Singer 200 amp alt, a Shuriken BT 80, two Crescendo Group 31s and lots of Execution Audio 1/0 Gauge.
  7. #22
    Aug 2012
    6,131
    3 Post(s)
    2554 Post(s)
    Quote Originally Posted by thatguy12 View Post
    if.ur wire is 4ga ofc yes if not then no
  8. #23
    naughtyca's Avatar
    naughtyca is offline CarAudio.com Veteran
    Feb 2012
    Tampa FL
    2,105
    803 Post(s)
    What's next wire after 4 ga?
  9. #24
    thatguy12's Avatar
    Dec 2012
    Madtown, WI
    582
    206 Post(s)
    that just seems weird. when you say you fuse for your wire, does that mean that 300 amp fuse will still protect my 150 fused amp? i wanna protect my amp, not my wire.
  10. #25
    trumpet's Avatar
    trumpet is offline CarAudio.com Veteran
    Jan 2011
    Grafton, ND
    37
    6,793
    43 Post(s)
    1859 Post(s)
    This discussion is just going around in circles. Choose your main power wire wire beyond what your amplifiers can draw. Size the fuses to match the wire, unless your amp does not have internal fuses. Then you use an inline fuse holder close to the amp and put in an appropriate fuse for the amp. The fuse at the battery is sized for the wire. If you guys listened to what NASTY has been saying repeatedly this thread would be done.
    Rubyserv - I believe I can delivery joy every time you drive by the power of an incredible sound system. Barry Schanz, Owner
    FB | Rubyservsales
    IG | Rubyserv
  11. Likes n8skow liked this post
  12. #26
    naughtyca's Avatar
    Feb 2012
    Tampa FL
    2,105
    803 Post(s)
    So for clarification on amps w no fuse you fuse 2x by the battery and close to the amp and on 4 ga wire 140a by the batt and anl for the fuse by the amp
  13. #27
    thatguy12's Avatar
    Dec 2012
    Madtown, WI
    582
    206 Post(s)
    Quote Originally Posted by trumpet View Post
    im not the blind truth type. what impala said seemed weird so i wanted to make sure i dont raise my fuses and blow stuff up. when i got my saz 1500 i was toldby my dealer to get 0 gauge wire and fuse it at 150 or up at my front battery and then i have a 150 amp fuse before my second battery and a 150 amp fuse after second battery close to my amp, its only a foot run. my amp doesnt have a fuse on it so i have to use inline. its confusing when so many people tell you different things.
  14. #28
    Aug 2012
    6,131
    3 Post(s)
    2554 Post(s)
    yea idk how else to put it lol
  15. #29
    trumpet's Avatar
    Jan 2011
    Grafton, ND
    37
    6,793
    43 Post(s)
    1859 Post(s)
    Go to Google and start searching, or check BCAE1.com and read up. You can get even more expert info in hard copy format if you order the MECP Basic study guide on Amazon.com.
    FB | Rubyservsales
    IG | Rubyserv
  16. #30
    Aug 2012
    6,131
    3 Post(s)
    2554 Post(s)
    some companies make 2ga but. with the availibilty and new overized cca its almost extinct...1/0. give u headroom ..only reasonable jump from 4ga ..or add another run of 4ga
  1. matching amps with subs
    By krishlal925 in forum Amplifiers
    Last Post: 07-20-2008, 12:57 PM
  2. help matching amp with subs?
    By burton7 in forum General Discussion
    Last Post: 06-22-2008, 05:19 PM
  3. Amps with no Fuses safe?
    By mightycrappy in forum Amplifiers
    Last Post: 06-30-2007, 12:53 AM
  4. Match Amp with Solobarics
    By DoomsquadEnt in forum Amplifiers
    Last Post: 01-27-2006, 12:25 PM
  5. question about amp with external fuse
    By treefitty in forum Wiring, Electrical and Installation Help
    Last Post: 01-02-2003, 07:40 AM
