Page 2 of 2 FirstFirst 1 2
Results 16 to 19 of 19
Reload Thread: Tuning Gains
  1. #16
    T3mpest's Avatar
    T3mpest is offline CarAudio.com Veteran
    Mar 2005
    Illinois
    3,053
    1 Post(s)
    372 Post(s)
    Re: Tuning Gains
    Have you tried just turning your gain on your sub amp up. There is nothing wrong with that if your music is indeed quiet in the bass region. You'll just have to dial things back on the HU quite a bit, if you have the capability, if you did decide to play rap or something else bass heavy.
    Quote Originally Posted by sdmtnbiker420 View Post
    JL is for ballers. Theres a reason all the biggest rappers sing about JL, Zapco, Alpine..... and not Lightning audio or Pyle. It's all about the BALLER FACTOR.
  2. #17
    argenis69's Avatar
    argenis69 is offline SQ Bass Lover
    Dec 2012
    NY, USA
    834
    245 Post(s)
    Re: Tuning Gains
    After I did my gains with the 50hz -7.5db, the output is better, I didn't add bass boost yet, I'm worried of what might happened if I add bass boost and overpower the sub, as of what I have, Its said on my signature.
    02 Nissan Maxima
    HU JVC KW-AV61BT.
    Front stage Image Dynamics 6.5 CX62 V2. Rear stage O2 Audio 5 1/4in.
    Cadence Tweeters. KnuKonceptz Rcas and Wiring.
    Kicker Impulse x3i 3-way Active Electronic Crossover(disconnected for now).
    JL Audio 300/4 . Crescendo BC3500D.
    15" Fi Audio SP4 fully loaded in 3.5cu ft flared ported box.
    200 amp HO Alt. One complete +/- run of Knu Ofc 0 gauge with big 3, volt meter inside, biggest acid battery under hood, Battery Isolator. A XS Power D3100 and a Crescendo Logic F-31HP battery in trunk.
  3. #18
    argenis69's Avatar
    Dec 2012
    NY, USA
    834
    245 Post(s)
    Re: Tuning Gains
    Quote Originally Posted by bbeljefe View Post
    Go ahead and set the bass boost on the amp at about half way and then set the gains on a 50 hx tone at -5 or -7.5.
    Bass boost only becomes a real problem when you crank on it after gain setting. .
    1- Should I follow this procedure above?
    2- Is there any harm with tuning my bass gains with a 50hz -7.5db tone ?
    02 Nissan Maxima
    HU JVC KW-AV61BT.
  4. #19
    argenis69's Avatar
    Dec 2012
    NY, USA
    834
    245 Post(s)
    Re: Tuning Gains
    bump
    02 Nissan Maxima
    HU JVC KW-AV61BT.
  1. How to tune gain on strapped amps???
    By REAudio2001 in forum Wiring, Electrical and Installation Help
    Last Post: 04-05-2012, 04:12 PM
  2. Gain setting/tuning question
    By Nevalite in forum General Discussion
    Last Post: 06-05-2008, 04:43 PM
  3. gain tune down?
    By pablo4429 in forum Amplifiers
    Last Post: 05-29-2005, 04:05 PM
  4. when tuning gain...
    By silverlude56 in forum Amplifiers
    Last Post: 11-30-2004, 04:35 PM
  5. Tuning Gain *Newbie*
    By hinanzo in forum General Discussion
    Last Post: 02-10-2004, 09:53 PM
