Page 2 of 2 FirstFirst 1 2
Results 16 to 19 of 19
Reload Thread: Subwoofers are shutting off even at low base and volume output, please help.
  1. #16
    ufxcrunner's Avatar
    ufxcrunner is offline Junior Member
    Jun 2013
    jacksonville, fl
    3 Post(s)
    Re: Subwoofers are shutting off even at low base and volume output, please help.
    alright well to get the best outta the situation you suggest just doing 4ohms to 4ohms like it says in crutchfield's diagram?
  2. #17
    LosIsATool's Avatar
    LosIsATool is online now CarAudio.com Veteran
    Apr 2011
    Pensacola, Florida
    37
    17,724
    107 Post(s)
    7516 Post(s)
    That's all you can do if you have DVCs. If you have singles it should be at 2 ohm already. It's a very ****** amp and honestly those subs are not much better. You got hosed like thousands others do everyday by false advertising.
    2014 Ford Fusion SE 2.0T
    JBL MS-8
    DD M1c, DD SS4A
    IDQ12v4 1.8cu sealed
    Hertz HT28
    Hertz HV165XL
    Knuconceptz OFC, Custom fit Soundrive RCAs.
  3. #18
    iSteven's Avatar
    iSteven is offline Member
    Mar 2013
    San Diego, CA
    78
    31 Post(s)
    Quote Originally Posted by ufxcrunner View Post
    I just got 2 1400W pioneer subs and a 2500W amp installed in my car. The subs are 4ohms and they wired it to make it 1ohm to get maximum power output. Well, 15 minutes down the road, at the level they tuned the system at(base and subwoofer levels(-6)) it shut off when i changed the song. i stop take the key out restart the system and it works again. The amp was pretty hot. The next day the same thing happened but a lot sooner this time maybe 4 minutes into my drive. I got out and the amp was still running(light was still on). Took the key out put it back in and it worked fine. The amp this time wasn't that hot. What do you think it could be? Maybe they shoulda made it 2 ohms instead of 1 because i know the more ohm the less stress it is on the system. PLEASE HELP thanks a lot
    From the bit you said. Possibly the amplifier isnt 1 ohm stable. Putting that low of an ohm on an amplifier that isnt ment to go that low puts it into protect mode. Try to put the ohms to 4. Cause you cant put two DVC 4 Ohm speakers to a final impedance of 2 Ohms.
  4. #19
    ufxcrunner's Avatar
    Jun 2013
    jacksonville, fl
    3 Post(s)
    Rewired it to 4ohms and the amp is cool. Thanks for all the help guys! Still gettin the same bass but the amp runs a whole lot cooler now.
  1. SOS please help. Amps are shutting off
    By E LOZANO187 in forum Wiring, Electrical and Installation Help
    Last Post: 06-01-2011, 04:06 PM
  2. Subwoofers are not hitting hard at all :(
    By RMD in forum General Discussion
    Last Post: 02-02-2010, 07:56 PM
  3. audio kicking in and out even at low volume
    By stray~johnny in forum Wiring, Electrical and Installation Help
    Last Post: 03-13-2008, 10:06 PM
  4. Amps getting hot even at low volume
    By rc10mike in forum Amplifiers
    Last Post: 11-25-2007, 01:02 PM
  5. amps are shutting off WTF?!?
    By dirtye30 in forum General Discussion
    Last Post: 03-15-2007, 11:37 PM
Tags for this Thread
