Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 31 to 45 of 53
Reload Thread: Alt? Batt? Or both?
  1. #31
    Villeza1's Avatar
    Villeza1 is offline Night Ryder
    Mar 2009
    Valdosta, GA
    1,996
    215 Post(s)
    Re: Alt? Batt? Or both?
    Quote Originally Posted by Silverado SS View Post
    It seems to be his daily. His 140 amp alt could charge 2 very small agms but more than likely his alt will smoke up trying to keep up.
    I dont understand why you think it will smoke up?
    2 AB 1100.1's
    4 Tantric Sounds SHD 18's
    Team Tantric Sounds
  2. #32
    Villeza1's Avatar
    Mar 2009
    Valdosta, GA
    1,996
    215 Post(s)
    No its not a need but don't be mad when your car won't start because the batteries are drained. If you do plan on not running a new alt do not play your system for maybe the last 10 minutes of your ride so they can charge and your car will have sufficient power to start
    That never happened to me when I had my D9's on my stock all. I played mine full tilt all the time. The only reason I could do that was b/c every weekend I recharged the batts. The batts are key here, not the alt. As long as the batts are recharged, the system is golden. The example has been set by Pipo and Nic Watts.
    You have to be smart here and let your alt recharge the system. It's not going to take all day or as long as you might think. My Stock GM alt would have my 6 XS Power D3100 and 1 D3400 batts recharged enough to start my car the next day. I had that setup for nearly 8 months. Most of the time I recharged the batts during the weekend. Which I could tell how good my alt was recharging the batts by how fast the external charged would finish its charge (which only took 2-3 hrs). Now, with 4 alts, it takes like 5 minutes to recharge the batts with an extra d3100 (7 total / 1 d3400) and I have way more power now.
    I keep editing this post lol
    There was one time I let the system go for roughly 1 month before I finally put the system on my external charger and it took nearly the avg recharge time (8hrs) to recharge my batts bake to 100%.
    2 AB 1100.1's
    Team Tantric Sounds
  3. #33
    Silverado SS's Avatar
    Silverado SS is offline Shake Pound and Rattle
    Feb 2013
    Cleveland
    1,572
    636 Post(s)
    Quote Originally Posted by Villeza1 View Post
    In your case with your goals, yes, a H/O isn't necessary (but if added, you will benefit from the added power). Like I said before, the only reason to add a H/O would be to cut the recharge time shorter. If you purchase an alt that can handle the entire load be itself, then you wouldn't need an extra battery. It's cheaper for you to just add 2 more batteries instead of spending more money on a H/O. both will work, one is cheaper.
    A XS 3100 is about 350$ an alt is about 400for what he needs maybe less. With a HO he will have more power and no faults. OP moral of the thread is buy both. Car audio isn't cheap and sometimes you have to bite the bullet and do it right if you want top results
  4. #34
    Feb 2013
    Cleveland
    1,572
    636 Post(s)
    It will be trying to charge everything. Your alt is not always making full amps just like an amp is not pulling all of its amps depending on what your playing. This also depends on vehicle and how the alt is controlled. There's a ton of variables as we all know but as I stated before for optimal audio get an alt and battery
  5. #35
    Feb 2013
    Cleveland
    1,572
    636 Post(s)
    85% of people on this site don't recharge there batteries every week and did you ever take a 6 hour road trip and use your system? Did the car start? I'm off to work will respond when out
  6. #36
    Villeza1's Avatar
    Mar 2009
    Valdosta, GA
    1,996
    215 Post(s)
    He doesnt have to get XS power batts though.... duracell agm batts were suggested to him.
    2 AB 1100.1's
    Team Tantric Sounds
  7. #37
    Villeza1's Avatar
    Mar 2009
    Valdosta, GA
    1,996
    215 Post(s)
    True, but with the added 2 batteries in the rear it will be fine.
    2 AB 1100.1's
    Team Tantric Sounds
  8. #38
    Villeza1's Avatar
    Mar 2009
    Valdosta, GA
    1,996
    215 Post(s)
    4 Hrs from Valdosta,Ga to Augusta,Ga **** near full tilt the entire way there only to turn it down when changing song or seeing cops. truck started just fine.
    100% of ppl let their alt charge their batteries though.
    The OP did say he's not gonna play full tilt but every so often, so it wont take nearly as long for his stock alt to recharge his system.
    2 AB 1100.1's
    Team Tantric Sounds
  9. #39
    JeepWithLows's Avatar
    JeepWithLows is offline Junior Member
    Jun 2013
    Turlock, Ca
    17
    12 Post(s)
    This post was to get me some info as to what my priorities were on what to buy and on a budget. Ive heard singer makes great alts. And i know i cant afford to run xs batts. Way overpriced in my opinion
  10. #40
    Villeza1's Avatar
    Mar 2009
    Valdosta, GA
    1,996
    215 Post(s)
    Quote Originally Posted by JeepWithLows View Post
    If you are getting a H/O, I would go Mechman hands down. There are plenty of good AGM batts out there, you dont have to get XS power.
    2 AB 1100.1's
    Team Tantric Sounds
  11. #41
    Jun 2013
    Turlock, Ca
    17
    12 Post(s)
    I have my interstate up front 34 i believe.. Would putting that same battery in the back be fine? So have 2 total?
  12. #42
    Jun 2013
    Turlock, Ca
    17
    12 Post(s)
    Mechman also doesnt have any models that fit my car. Id have to get a custom one.
  13. #43
    Feb 2013
    Cleveland
    1,572
    636 Post(s)
    I can call mike singer for you if you want PM me your number and what amps you want.
  14. #44
    psych0ticnemes1's Avatar
    psych0ticnemes1 is offline Psych0tic Customs
    Apr 2005
    Behind You
    5,842
    175 Post(s)
    Call him for me too! Ha. Haven't heard back.
    References:
    Ali1, michaellane, cadillac114, chasinSKURT, DaRevrin, rhuff80, sam yung, The215, tukn18s, Xenophontos,nuboot,jfitz97,LuckyDerDer 2x
  15. #45
    jar1zx's Avatar
    jar1zx is offline CarAudio.com Elite
    Feb 2011
    Nashville Arkansas
    43
    574
    166 Post(s)
    You're not gonna see a difference unless you plan to add more equipment. When you run a dedicated alt for the system, you'll notice your voltage will fluctuate (b/c the alt is only loaded down when the bass hits). Once you get to 2 or 3 extra alts dedicated to the system, you'll start to notice your engine will bog down everytime the bass hits. I couldn't stand that when I had my alts setup that way, now I have all 4 alts powering the vehicle and system.
    I plan on getting higher power subs then drop ohms from 4 to 2ohms going from 1500 to 2500 watts
    08 ext cab z71
    Hu pioneer avh-8500........prs80
    Mechman 320 and a Gp 370 with dual alt bracket
    northstar 34 and 480 with gp terminals for both
    Ton of ofc 2/0 and smd fuse blocks
    Soundqubed hdc4 12's
    Soundqubed 6.5's two sets
    crescendo concerto c1100.4
    Sound digital evo 12k
  1. Mechman alt, ground to batt or frame?
    By Deeper_shades in forum Wiring, Electrical and Installation Help
    Last Post: 03-31-2010, 08:42 PM
  2. More Batts or HO Alt.
    By stl_style in forum Wiring, Electrical and Installation Help
    Last Post: 02-12-2009, 08:31 PM
  3. Wtt:Xtant 3300x or ss ref 200 for batts or an alt
    By Bassman999 in forum Wanting to Buy (WTB) - Car Audio
    Last Post: 02-12-2009, 12:47 PM
  4. Do I need another batt. or upgraded alt.?
    By DINEAUTO in forum Wiring, Electrical and Installation Help
    Last Post: 12-28-2007, 04:48 PM
  5. Something is dying.. Batt or Alt?
    By XaznKewLguyX in forum Wiring, Electrical and Installation Help
    Last Post: 07-11-2006, 09:24 PM
Tags for this Thread
