Results 1 to 8 of 8
Reload Thread: Eq tuning
    argenis69's Avatar
    argenis69 is offline SQ Bass Lover
    Dec 2012
    NY, USA
    836
    245 Post(s)
    Icon14 Eq tuning
    Hi CA, I would like some experienced opinions and/or suggestions on how to tune or equalize properly my interior speakers. In a 2002 nissan maxima I have 6.5'' cadence component speakers on front and 5.25'' beyma mid high speakers on the rear, powered by a 500rms 4 channels amp.
    I recently installed an eql from audiocontrol to eliminate some bass and get clear sound from the interior speakers, but I've tried some much to get it tuned right, but I can't get it to sound right, and after that the sound output is also lower, and now if I put the volume loud on the hu the interior speakers start to sound like with some cracking sound. Also, if this helps, I recently bought an nano oscilloscope but haven't used it yet.
    1-What can I do to fix this issue? If possible, with specifications.
    2-Is it better to buy and put bass blocker filter to each speaker to eliminate the use of the eq? If yes, which is the best frequency to buy the blocker?
    Thank you.
    djeazie's Avatar
    djeazie is offline CarAudio.com Elite
    Jan 2007
    n.w. ohio
    39
    975
    6 Post(s)
    Re: Eq tuning
    Sounds like you need a crossover instead of an eq. A crossover will help you "assign" a frequency range to each speaker or set of speakers. An eq will only boost or attenuate those frequencys. Not sure if that audiocontrol piece as crossover adjustments.
    PSturmer's Avatar
    PSturmer is offline CarAudio.com Elite
    Jun 2006
    Minnesota
    1,948
    24 Post(s)
    Re: Eq tuning
    you should avoid adding processing equipment if it's no absolutely necessary. you should have two high-pass filter (let's high frequencies pass while lower ones die) options. the first is on your head unit. get the instructions out for it and see what you can do. try 80Hz first. the second option is on your 4-channel amp. switch it to HPF (high pass filter) and adjust it to around 80Hz and see what that does for you.
    4x 12" HDC3's
    1x Hifonics Maxximus (rated 10,[email protected])
    2x Powermaster D3100
    8x runs of 0 gauge
    1x stock alt
    155.2 dB legal (vehicle off and @50Hz) in a Ford exploder
    i2ain2thunder's Avatar
    i2ain2thunder is offline CarAudio.com Veteran
    Mar 2011
    st paul, mn
    2,240
    176 Post(s)
    Re: Eq tuning
    Here you go buddy, this helped me when I was working with EQ.
    8 Easy Steps To Better EQ
    cliff notes:
    to find what frequency to boost/cut, listen to your music, find an instrument that you want to stand out or cut back in the mix, boost a frequency up untill you find what frequency affects that instrument.
    Now a general rule of thumb cutting is a better option than boosting for sound quality.
    cut narrow
    boost wide
    (if you can change the width of the band)
    ^^above post was actually made based on title of thread. Reading your post, I agree with the fact you need a crossover more than anything. A crossover will cut off frequencies from getting to your speakers, (I.E. low bass frequencies). A crossover can be a LPF (low pass filter) or HPF (high pass filter) For cutting the low frequencies off to your speakers you want to setup a HPF (you can buy a passive HPF, or use an active HPF built into your HU, or amp).
    argenis69's Avatar
    Dec 2012
    NY, USA
    836
    245 Post(s)
    Re: Eq tuning
    Bump
    calebkhill's Avatar
    calebkhill is offline CarAudio.com Elite
    Dec 2012
    Phenix City, Alabama
    1,103
    326 Post(s)
    Re: Eq tuning
    Quote Originally Posted by argenis69 View Post
    Bump
    Take the eq out of your car and use your hu and amp crossovers properly.
    Also set your hu volume and amp gains properly.
    This well help. That eq your using is probably causing problems.
    "When I listen to a stereo loudspeaker playback in my room and an auditory scene has formed in my mind, how would I know that what I hear is an accurate replica of an auditory scene that could be had at the recording venue? Or more generally, that this is an auditory scene that could have existed at all?"
    argenis69's Avatar
    Dec 2012
    NY, USA
    836
    245 Post(s)
    Re: Eq tuning
    Thanks,
    -Is there any opinions about using bass blocker filters on the speakers instead of adding the crossovers? If yes, what frequencies should I block?
    calebkhill's Avatar
    Dec 2012
    1,103
    326 Post(s)
    Re: Eq tuning
    The crossovers on your head unit and amp are bass blockers.
    Subs: lpf 80hz
    Mids: bpf: 80hz-8khz
    Tweets: hpf: 8khz
    There's your settings, let us know how it sounds.
    Whatever allows you to set these options, whether it be the head unit or amp.
  1. 8 Band EQ tuning
    By 93civEJ1 in forum General Discussion
    Last Post: 02-29-2012, 12:31 PM
  2. EQ tuning...
    By groggy23 in forum Head Units
    Last Post: 05-24-2007, 11:48 AM
  3. Replies: 0
    Last Post: 12-12-2006, 10:20 PM
  4. help tuning system? do i need an EQ?
    By gc86 in forum Head Units
    Last Post: 03-02-2006, 04:05 AM
  5. System tuning, Use Eq's or not?
    By JettaGLI in forum General Discussion
    Last Post: 09-07-2005, 01:31 AM
