Page 2 of 2 FirstFirst 1 2
Results 16 to 17 of 17
Reload Thread: Need Help! Annoying Alternator Wine
  1. #16
    CerwinVega_Fan's Avatar
    CerwinVega_Fan is offline Coolest Member
    Apr 2009
    Dallas,TX
    4,395
    3 Post(s)
    773 Post(s)
    Re: Need Help! Annoying Alternator Wine
    Quote Originally Posted by maylar View Post
    Read the sticky on alternator whine. It's ALWAYS due to ground loops. The HU ground is different than the amp ground and you get ground currents running through the RCA shields. Different cables SOMETIMES helps, but the real issue is GROUNDS GROUNDS GROUNDS GROUNDS GROUNDS GROUNDS GROUNDS.
    I have that same JVC deck and it's fine.
    So a gound loop isolator would do the trick?
  2. #17
    maylar's Avatar
    maylar is offline Electrical Weenie
    Jan 2002
    Connecticut
    66
    3,498
    2 Post(s)
    399 Post(s)
    Quote Originally Posted by CerwinVega_Fan View Post
    That's basically what they're for, yes. People don't like them because you can lose SQ depending on the manufacturer but sometimes they are a viable solution. I have an install in an old car that's simply impossible to get equal grounds between the amp and HU. Isolator fixed it.
    dave
    1999 Buick Park Ave Ultra
    Head Unit: JVC KWHDR720
    EQ: Audiocontrol EQL
    Front Stage: Hybrid Audio Technologies Imagine 5.25 mids, Morel Maximo tweets
    Sub Stage: Boston G3 10", 0.5 cu ft sealed
    Amp: PPI Phantom 900.4
    Rear Fill: Boston SE953 6X9's
  1. I need help bout alternators
    By audiobahnuser18 in forum Wiring, Electrical and Installation Help
    Last Post: 02-17-2009, 12:30 AM
  2. Need help with alternator issue!!
    By KorpzJuggalo in forum Wiring, Electrical and Installation Help
    Last Post: 11-01-2007, 04:34 PM
  3. Need Help with alternator
    By jattgdup in forum Wiring, Electrical and Installation Help
    Last Post: 11-14-2005, 11:10 AM
  4. Need Help About Alternator....
    By Qckrun in forum General Discussion
    Last Post: 06-03-2003, 06:02 PM
  5. lady need help with Alternator
    By ladyfastcar in forum General Discussion
    Last Post: 03-23-2003, 07:24 PM
