Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 16 to 30 of 58
Reload Thread: Reasons why you shouldn't use CCA wire
  1. #16
    Beatin''s Avatar
    Beatin' is offline CarAudio.com Elite
    Nov 2012
    MI
    998
    574 Post(s)
    Re: Reasons why you shouldn't use CCA wire
    Quote Originally Posted by DonH View Post
    Im all about degradation of a product. CCA life span is far less compared to OFC in the same application. Ive done countless tests at work on the stuff... but like i said to each there own.
    Are you implying that if two wires, OFC vs. CCA, are both made in their respective gauge size to handle 200A, but only put no more than 150A through them daily, the CCA wire will degrade faster than the OFC?
    How?
    I know that the copper coating will degrade, but this seems to be a problem with the manufacturing process regardless of whether it's CCA or OFC. I've seen OFC wires with severe corrosion in the middle of the run, rendering that whole expensive copper wire useless. The degredation of the copper coating on the terminal ends of CCA wire are a non-issue due to the length of the exposed surface.
    Until I'm shown otherwise, I stand by my original statement in that if the electric current carrying apparatus (wire, lol) is built correctly for a specific amerage rating, then it will do the job with no problem. Steel, copper, aluminum, banana, doesn't matter.
    All day I'm clippin'
    voltage be dippin'
    I don't give a damn,
    cause my trunk always hittin'!
    creating a proper sound wave. Step one, turn it up until clipping. Step two, done.
  2. Likes brandonkain82 liked this post
  3. #17
    momax_powers's Avatar
    momax_powers is offline Senior VIP Member
    Jul 2012
    Canada
    448
    175 Post(s)
    Are all voice coils made from ofc copper?
  4. #18
    profundus-sanus's Avatar
    profundus-sanus is offline CarAudio.com Veteran
    Dec 2006
    wilmington, NC
    31
    2,970
    22 Post(s)
    this guy doesn't know what he's talking about. 4 gauge ofc will not keep up with 1/0 cca, ever.
    cca per national electrical code is good for 75% of the capability of ofc. Did he make the cca run 75% of the length of the ofc? Was the cca in his test cheap undersized wire? sure looked like a garbage undersized soundquest kit to me... Looks like a advertisement more than a scientific test.
    Cca is 50% of the cost of ofc in most cases. With 2 runs of cca you'll crush 1 run of ofc.
  5. #19
    double 07's Avatar
    double 07 is offline CarAudio.com Elite
    Nov 2011
    Etowah, TN
    1,960
    13
    3 Post(s)
    626 Post(s)
    I thought that was why most decent cca is over sized....case and point I have XS Power 1/0 cca in my BMW and it is 5200 strands and I have never had an issue with my wire....the ofc from XS is 4704 strand......I am not saying that ofc isn't better it's just that I think cca can do the job if used within it's limits and installed correctly......That video looked more like a sales pitch to me.......tell him to redo the video with some wire from XS Power instead of a cheap amp kit that probably had 10ga wire in a 8ga jacket...
  6. Likes brandonkain82 liked this post
  7. #20
    LosIsATool's Avatar
    LosIsATool is offline CarAudio.com Veteran
    Apr 2011
    Pensacola, Florida
    37
    17,856
    109 Post(s)
    7616 Post(s)
    The biggest problem with CCA is heat. More heat equals less efficency. As the efficency drops the heat will build up faster and faster. Its not worth it IMO. Do it right the first time
    2014 Ford Fusion SE 2.0T
    JBL MS-8
    DD M1c, DD SS4A
    IDQ12v4 1.8cu sealed
    Hertz HT28
    Hertz HV165XL
    Knuconceptz OFC, Custom fit Soundrive RCAs.
  8. #21
    LosIsATool's Avatar
    Apr 2011
    Pensacola, Florida
    37
    17,856
    109 Post(s)
    7616 Post(s)
    Quote Originally Posted by RLDriver View Post
    thats odd.. my cca wire has not gotten any warmer than the ofc it replaced (yes, tested with a thermometer.) again, use the correct size stuff, and you'll have no issues.
    EDIT: I am NOT saying it cant happen. im saying its not nearly as common as some people want to think!
    Personally I think its dumb to spend so much on top level equipment then sweat a few more bucks a foot on the POWER SUPPLY for said top level equipment. I guess thats why I can run full tilt for hours at a time without losing a volt. NO WEAK LINKS IN THE CHAIN
    JBL MS-8
    DD M1c, DD SS4A
    Hertz HT28
    Hertz HV165XL
  9. #22
    NASTY08IMPALA's Avatar
    NASTY08IMPALA is offline CarAudio.com Veteran
    Aug 2012
    LOUISVILLE, KENTUCKY
    6,131
    3 Post(s)
    2554 Post(s)
    Quote Originally Posted by DDtC View Post
    I dont drop below 14.4 with my cca so.....
  10. #23
    LosIsATool's Avatar
    Apr 2011
    Pensacola, Florida
    37
    17,856
    109 Post(s)
    7616 Post(s)
    Quote Originally Posted by NASTY08IMPALA View Post
    Are you running close to 6000 watts with only 3 group 34 batteries?
    JBL MS-8
    DD M1c, DD SS4A
    Hertz HT28
    Hertz HV165XL
  11. #24
    Aug 2012
    6,131
    3 Post(s)
    2554 Post(s)
    I could run ur setup and still hold that voltage with my cca..i un aq 3500 with 1 g34 and 2 g27s
  12. #25
    ciaonzo's Avatar
    ciaonzo is offline TheContinental
    Feb 2009
    WI
    43
    10,998
    20 Post(s)
    1157 Post(s)
    Roll call...
    CCA
    Saying "clipping doesn't kill speakers" is a half-truth at best. Technically no, clipping itself does not hurt the speaker. But in clipping your amp, you can easily create a situation that WILL kill the speaker. Was the squared waveform the DIRECT cause of the failure? No. In the end, the answer is, always has been, and can only be... heat kills speakers. BUT, clipping increases heat generation, sometimes by a drastic amount. So to start a thread simply to state that clipping does not hurt speakers is, again, a half-truth at best.
  13. #26
    LosIsATool's Avatar
    Apr 2011
    Pensacola, Florida
    37
    17,856
    109 Post(s)
    7616 Post(s)
    You dont know that cause you have never done it. I wasnt about to find out the hard way.
    JBL MS-8
    DD M1c, DD SS4A
    Hertz HT28
    Hertz HV165XL
  14. #27
    LosIsATool's Avatar
    Apr 2011
    Pensacola, Florida
    37
    17,856
    109 Post(s)
    7616 Post(s)
    Do you guys know what sets a audiophile apart from a ghetto basshead? Cheaping out on the important parts. If you can not afford good wire I'm sorry for you, if cheap wire is good enough for you to be pleased I will put you in the ghetto basshead catagory
    JBL MS-8
    DD M1c, DD SS4A
    Hertz HT28
    Hertz HV165XL
  15. Likes Garcia915 liked this post
  16. #28
    pro-rabbit's Avatar
    pro-rabbit is offline Moderator pro-rabbit is a Supporting Member of the forum!
    pro-rabbit is a Supporting Vendor of the forum!
    Jan 2004
    OKC, OK
    36
    12,395
    2 Post(s)
    2522 Post(s)
    You have a single m4 with that electrical, and decent alt so... No you shouldnt have voltage issues. To be honest I have ran a m4 with far less then you with little to no voltage drop. Those amps might as well be considered mythical creatures because all the claims on output with them.
  17. #29
    dbjunior's Avatar
    dbjunior is offline CarAudio.com Elite
    Jun 2009
    ma
    1,334
    314 Post(s)
    I run cca but I use a 50% method. Whatever your current draw is should only equal 50% what you wire is rated for. You will never have a voltage issue from your wire if run like this, regardless of wire type.
    bought from MBROOKY, johnny law.Lulz, subzero, tc3k101
    sold to mytrunkslamz , vitveet, cd6551, martiandancer31 (x2), pro-rabbit, whytellyou
    Trade with cf2004
  18. #30
    pro-rabbit's Avatar
    Jan 2004
    OKC, OK
    36
    12,395
    2 Post(s)
    2522 Post(s)
    odd.. I can do the same, with no issues. NOT BEING RETARDED. Ive got a more than adaquate charging system. of course, im not a semiretarded basshead like most of children here.
    the WEAK LINKS in most of the members here's system is the installer. take from that what you will.
    The other weak link is the alt. No one ever spends the money there. That is the most important part of the electrical.
  1. Wiring capacitors...you need to use ring terminals?
    By 31337hxr in forum Amplifiers
    Last Post: 06-26-2002, 02:32 AM
