Page 3 of 3 FirstFirst 1 2 3
Results 31 to 33 of 33
Reload Thread: whay to set amp gains at
  1. #31
    Rockguy475's Avatar
    Rockguy475 is offline CarAudio.com Elite
    Jan 2006
    houston
    559
    62 Post(s)
    Re: whay to set amp gains at
    Quote Originally Posted by bradl79 View Post
    Nice system. How does it sound
    Sounds amazing now that I properly have my gains set. When I first set everything up I tried to set my gains by ear which wasn't too hard for my front and rear speakers but I ended up turning my sub gain up too high which was causing it to clip at high volumes which in turn was shutting my amp into protection mode. This was very frustrating for me bc I had no idea how to properly set my gains and didn't have any of the right equipment (at the time I didn't even know it was shutting off because of clipping which was even more annoying). Spent a few days searching on these forums and online sites and learned that it was actually pretty easy. Now my system slams just like I want it to and I can play my music at higher volumes without it shutting off on me.
    If you don't have a LPF and HPF on your stock deck, which I doubt you do, make sure you set your amp up correctly otherwise it can make your music sound like **** and can strain your speakers. If you have a sub you really don't want your door speakers playing anything below 80Hz, or at least I don't. Same with your sub, you do not want it to be straining to hit the upper Hz (anything over 80Hz for the most part).
    Listen to Hip-Hop/Rap especially when its Chopped&Screwed, classic rock, hard rock, and most electronic
    Car: 2014 Mustang
    Sub: Jl Audio 12W6v2
    Amp: 16-SRX1.500
    HU: Stock
    Front speakers: Stock shaker system
    Back speakers: Stock shaker system
    Sub box: Custom built for W6 for mustang trunk
  2. #32
    CumminsFan's Avatar
    CumminsFan is offline Member
    Jan 2012
    Fred, Va
    61
    20 Post(s)
    Go all the way to the max then back it off by a 16th and you're golden.
  3. #33
    d77543020's Avatar
    d77543020 is offline CarAudio.com Veteran
    Dec 2005
    stockton ca
    2,671
    428 Post(s)
    this is exactly why there is a dd1
  1. Replies: 5
    Last Post: 10-25-2011, 01:13 PM
  2. Problems Using DMM to Set Amp Gain
    By Jer510 in forum Amplifiers
    Last Post: 03-23-2009, 11:26 PM
  3. web site to setting your "Gain" on your amps.
    By da12b in forum Wiring, Electrical and Installation Help
    Last Post: 09-22-2003, 02:17 AM
  4. How to set amp gain at 2V?
    By Bobyota in forum Amplifiers
    Last Post: 09-13-2003, 07:36 PM
  5. What to set amp crossover at using passive crossover?
    By nrgy in forum General Discussion
    Last Post: 02-21-2003, 01:15 PM
