Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 16 to 30 of 33
Reload Thread: whay to set amp gains at
  1. #16
    Bwap's Avatar
    Bwap is offline CarAudio.com Elite
    Apr 2013
    NY
    508
    234 Post(s)
    Re: whay to set amp gains at
    Quote Originally Posted by bradl79 View Post
    OK I will do that
    lmao
  2. #17
    bradl79's Avatar
    bradl79 is offline CarAudio.com Elite
    Jan 2013
    NLR
    1,407
    1 Post(s)
    447 Post(s)
    so even though my speakers are 80w rms, to set the gain on my amps i will want to use a voltage meter on my amps, which my amp is 50 rms @ 4ohms which would put it at an output of 14.1 volts, so is that what i want, what about the 80 rms for the speakers does that even matter?
  3. #18
    Bwap's Avatar
    Apr 2013
    NY
    508
    234 Post(s)
    Well, if nom is halfway then chances are that is 2 volts.
  4. #19
    bradl79's Avatar
    Jan 2013
    NLR
    1,407
    1 Post(s)
    447 Post(s)
    ok my amp is 50 rms and speaker is 80 rms, when setting the gains do i calculate and set voltage for the amp 50 rms or speaker rms 80?
  5. #20
    Bwap's Avatar
    Apr 2013
    NY
    508
    234 Post(s)
    Preout voltage
  6. #21
    Rockguy475's Avatar
    Rockguy475 is offline CarAudio.com Elite
    Jan 2006
    houston
    559
    62 Post(s)
    You go by the rms tht the amp puts out.
    Listen to Hip-Hop/Rap especially when its Chopped&Screwed, classic rock, hard rock, and most electronic
    Car: 2014 Mustang
    Sub: Jl Audio 12W6v2
    Amp: 16-SRX1.500
    HU: Stock
    Front speakers: Stock shaker system
    Back speakers: Stock shaker system
    Sub box: Custom built for W6 for mustang trunk
  7. #22
    LosIsATool's Avatar
    LosIsATool is online now CarAudio.com Veteran
    Apr 2011
    Pensacola, Florida
    37
    17,647
    106 Post(s)
    7467 Post(s)
    You say the amp puts out 50 watts. So how would you set it to 80 watts? if this is possible please let me know.
    2014 Ford Fusion SE 2.0T
    JBL MS-8
    DD M1c, DD SS4A
    IDQ12v4 1.8cu sealed
    Hertz HT28
    Hertz HV165XL
    Knuconceptz OFC, Custom fit Soundrive RCAs.
  8. #23
    Rockguy475's Avatar
    Jan 2006
    houston
    559
    62 Post(s)
    you need to get a volt meter and set your gains till they read 14.1 volts. The 50 rms is fine for your 80 rms speakers. This of course is only for your speakers you will need to recalculate the formula again when setting your sub.
    I just learned how to do all this myself. I too am a complete noob at car audio but learning and doing it the right way will benefit you far more then just setting your gains by ear or just guessing. I followed the JLaudio gain setting tutorial from their site. Helped me tons. Let us know if you have more questions.
    Another thing you will need is test tones to set your gains. If you have an iphone or mp3 player you can always download the tones from iTunes (costs 0.99 a track and you only need 2 [50 hz for the sub and 1Khz for the speakers]) I believe they also have some sites with free downloads but im not sure how good the quality is on them.
    Car: 2014 Mustang
    Amp: 16-SRX1.500
    HU: Stock
  9. #24
    bradl79's Avatar
    Jan 2013
    NLR
    1,407
    1 Post(s)
    447 Post(s)
    Thanks for all the help. I used a 50Hz to set speakers too should I download the 1Khz and re do the speakers.
  10. #25
    bradl79's Avatar
    Jan 2013
    NLR
    1,407
    1 Post(s)
    447 Post(s)
    No I meant do I set it using the amp RMS or the speaker RMS ratings
  11. #26
    Rockguy475's Avatar
    Jan 2006
    houston
    559
    62 Post(s)
    you set it using the RMS from the amp channel. And yes you should get a 1Khz tone for your front and rear speakers. A 50hz tone is much too low for them to get accurate ratings and you shouldn't have your speakers playing notes that low anyhow. I set everything from my deck which most let you do. Set the Low pass filter on 80Hz and the High pass filter on 80Hz and adjust from there. I personally keep my LPF on 80 and my HPF on 100.
    Car: 2014 Mustang
    Amp: 16-SRX1.500
    HU: Stock
  12. #27
    Dirtrider4eva's Avatar
    Dirtrider4eva is offline √\_The CaUsE__
    Mar 2011
    Milwaukee, WI
    4,292
    841 Post(s)
    dude what head unit are you using?
    welcome to
    Where b-stock is the new a-stock
    TEAM WEST
  13. #28
    bradl79's Avatar
    Jan 2013
    NLR
    1,407
    1 Post(s)
    447 Post(s)
    Thank u
    I am using stock hu
  14. #29
    Rockguy475's Avatar
    Jan 2006
    houston
    559
    62 Post(s)
    Quote Originally Posted by Dirtrider4eva View Post
    if you were asking me? Pioneer AVH-X2500BT
    Car: 2014 Mustang
    Amp: 16-SRX1.500
    HU: Stock
  15. #30
    bradl79's Avatar
    Jan 2013
    NLR
    1,407
    1 Post(s)
    447 Post(s)
    Quote Originally Posted by Rockguy475 View Post
    Nice system. How does it sound
  1. Replies: 5
    Last Post: 10-25-2011, 01:13 PM
  2. Problems Using DMM to Set Amp Gain
    By Jer510 in forum Amplifiers
    Last Post: 03-23-2009, 11:26 PM
  3. web site to setting your "Gain" on your amps.
    By da12b in forum Wiring, Electrical and Installation Help
    Last Post: 09-22-2003, 02:17 AM
  4. How to set amp gain at 2V?
    By Bobyota in forum Amplifiers
    Last Post: 09-13-2003, 07:36 PM
  5. What to set amp crossover at using passive crossover?
    By nrgy in forum General Discussion
    Last Post: 02-21-2003, 01:15 PM
