Page 2 of 2 FirstFirst 1 2
Results 16 to 18 of 18
Reload Thread: mounting amp onto sub box
  1. #16
    pro-rabbit's Avatar
    pro-rabbit is offline Moderator pro-rabbit is a Supporting Member of the forum!
    pro-rabbit is a Supporting Vendor of the forum!
    Jan 2004
    OKC, OK
    35
    12,395
    2 Post(s)
    2522 Post(s)
    Re: mounting amp onto sub box
    There are several threads about this topic already. With various points from both sides of the fence.
    Me personally, if the enclosure is build strong enough there is typically no issues from it. There are some amplifiers that are more prone to those kinds of damage, but they will likely fail just the same if you build something rather large with a good amount of output. The largest issue I have seen over the years are one of two things.
    1. Enclosure flexes to much causing damage to the board of the amplifier by typically do to the "twisting" action that could happen.
    2. Poor solder points and/or glue points on the amplifier simply break off. This was some what common of cheaper amps for several years. However, from what I have seen with the most basic Korean amplifier(what most run) that has been resolved.
    If you can keep from mounting the amp on the enclosure then I would do so...however, if you have no other area to place it..then you really have no choice. Just take all precautions you can and go from there.
  2. Likes BoomBoxStereo liked this post
  3. #17
    ™Caveman's Avatar
    ™Caveman is offline CarAudio.com Elite
    Jan 2013
    SoCal
    1,370
    268 Post(s)
    5/8 thick aluminum plate won't flex. Get a piece cut to the size of the top of your box. Also helps keel the amp.
    Bought from: Double07(Regular)Mylows10, Bhsdriller,Moller1129, 09civic , Oxsign, Regizzle
    Sold To: Zedicus , Nate1017, Ram1500 , Oxsign , 310_cutty(twice), RoYALbLUE08, joelacer, Jeep2000
  4. #18
    ™Caveman's Avatar
    Jan 2013
    SoCal
    1,370
    268 Post(s)
    Answer aluminium plate.
  1. What's so wrong about mounting amp on sub box?
    By accuab in forum Wiring, Electrical and Installation Help
    Last Post: 11-04-2012, 08:19 AM
  2. Mounting Amps to Sub Box
    By >>SQL<< in forum Wiring, Electrical and Installation Help
    Last Post: 08-31-2011, 02:30 PM
  3. mounting amp on sub box ?
    By texicanz in forum Wiring, Electrical and Installation Help
    Last Post: 10-09-2009, 12:11 AM
  4. Mount Amps on Sub Box (Yay or Nay)???
    By KnockatomiTower in forum Wiring, Electrical and Installation Help
    Last Post: 03-06-2009, 11:53 AM
  5. Mounting amp to sub box=bad???
    By goose5741 in forum General Discussion
    Last Post: 04-05-2006, 01:22 AM
