Page 2 of 2 FirstFirst 1 2
Results 16 to 18 of 18
Reload Thread: Got a problem , any idea ? (**** draw inside )
  1. #16
    BrownVanMan's Avatar
    BrownVanMan is offline CarAudio.com Veteran
    May 2009
    Minneapolis MN
    2,018
    1 Post(s)
    331 Post(s)
    Re: Got a problem , any idea ? (**** draw inside )
    Sounds like the coil on the sub may be damaged from the clipping. To set gain you play a test tone an then check for AC voltage at the speaker terminals. In your case I would rewire to 1 ohm to be sure the amp isn't clipping. The you take your desired power (700) multiples by your ohm load(1) then the square root of that number. So the square root of 700 is how many AC volts you want to see.
  2. Thanks h2h0e thanked for this post
  3. #17
    calebkhill's Avatar
    calebkhill is offline CarAudio.com Elite
    Dec 2012
    Phenix City, Alabama
    1,103
    326 Post(s)
    Misread
    By the way, head unit volume at 80 percent and no bass boosts our eq when setting gains.
    Litten to your speakers when you test with the tone, it could clip before making rated power.
    "When I listen to a stereo loudspeaker playback in my room and an auditory scene has formed in my mind, how would I know that what I hear is an accurate replica of an auditory scene that could be had at the recording venue? Or more generally, that this is an auditory scene that could have existed at all?"
  4. Likes BrownVanMan liked this post
  5. #18
    maylar's Avatar
    maylar is offline Electrical Weenie
    Jan 2002
    Connecticut
    66
    3,498
    2 Post(s)
    399 Post(s)
    Quote Originally Posted by h2h0e View Post
    wire was fine , ive try to switch sub and reconnect but the same sub is getting hot, even if i switch subs connection and place in the box , i guess ill wait my ordered dmm
    Again.... if the subs are identical and only one is getting hot, there's something different between them. Either they're not wired the same or one of them has issues.
    dave
    1999 Buick Park Ave Ultra
    Head Unit: JVC KWHDR720
    EQ: Audiocontrol EQL
    Front Stage: Hybrid Audio Technologies Imagine 5.25 mids, Morel Maximo tweets
    Sub Stage: Boston G3 10", 0.5 cu ft sealed
    Amp: PPI Phantom 900.4
    Rear Fill: Boston SE953 6X9's
  1. Acoustics problem.. Any ideas?
    By hemaroid in forum Subwoofers
    Last Post: 02-01-2010, 12:26 AM
  2. Got a problem. Any help appriciated.
    By kasimo420 in forum General Discussion
    Last Post: 03-17-2009, 08:08 PM
  3. HELP!! short circus problem..any idea??
    By mdd99 in forum Amplifiers
    Last Post: 05-25-2004, 12:31 AM
  4. Anyone got any ideas for components??
    By XtremeBass in forum General Discussion
    Last Post: 07-16-2002, 11:52 PM
