Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 31 to 45 of 46
Reload Thread: Point of oversized wire?
  1. #31
    UnderFire's Avatar
    UnderFire is offline CarAudio.com Veteran
    Apr 2011
    Dayton, OR, 97114
    2,096
    1 Post(s)
    542 Post(s)
    Re: Point of oversized wire?
    Quote Originally Posted by mlstrass View Post
    Holy contradiction. Any REAL car audio 1/0 wire = 2/0 wire, is that better? Don't care if it's mislabeled, it will be the size of 2/0 AWG which you just said...
    Basically sums it up right there.
    I don't understand why CA companies don't just sell their stuff as 2/0 TBH.
    97 4runner, 3RZ, 5 Speed
    Headunit: Pioneer DEH-P9800BT
    Mids: Pioneer ????
    Tweets: CDT DRT-25
    Fronts Amp: Memphis M-Class 4x50
    Sub Amp: Diamond D3 400.1
    Substage: 2x 12" Dayton HO's
    Electrical: 160 Amp Alt, Kinetik HC2400, Interstate DCM0100, 2/0 Throughout
  2. #32
    Gawdzila's Avatar
    Gawdzila is offline Junior Member
    Apr 2013
    San Diego, CA
    2 Post(s)
    Quote Originally Posted by BlurredVision View Post
    I get that, but the wire that's only making contract is really useful correct? I could have a wire twice the size of a 0 gauge terminal, but trimming half of it away to make it fit defeats the purpose right?
    I have a degree in physics, so I can say with authority that this is not true.
    Total resistance to current flow is just the sum of all the resistances. In the case of a linear resistor like wire, the total resistance is equal to the per-length resistance multiplied by the length of wire. The per-length resistance goes DOWN with larger wire gauge. Thus (using made-up figures for simplicity), if some 18-gauge wire has 0.1 ohm-per-foot resistance and some 4-gauge wire has 0.01 ohm-per-foot resistance, 10ft of 18-gauge will add 1 ohm of resistance and 10ft of 4-gauge wire will add 0.1 ohms of resistance. PERIOD.
    The connector on the end will certainly add it's own resistance, and a larger connection area will result in less added resistance. But just because the connector isn't as large as the cable doesn't remove the low-resistance benefits of a fat cable.
  3. Thanks BlurredVision thanked for this post
  4. #33
    mlstrass's Avatar
    mlstrass is offline Shaggy DOA
    Jul 2006
    Illinois
    10,782
    6 Post(s)
    1266 Post(s)
    Quote Originally Posted by Gawdzila View Post
    Sorry but you are wrong, slofocus said it's just marketing. Perhaps you should have gotten a degree in marketing
  5. #34
    TheUnderFighter's Avatar
    TheUnderFighter is offline Beer Addict
    Mar 2011
    Murrieta, California, (SoCal)
    27
    3,488
    862 Post(s)
    No, because it doesn't HAVE to be 2/0 AWG. SOME of it is as oversized as 2/0, but some is in between, and some is exactly 1/0. It's not a requirement for quality Car Audio 1/0 to be exactly the equivalent of 2/0 AWG. It just so happens that a small number of companies "1/0" wire is actually 2/0/. Some of it is **** near, but not quite that big. Some of it is just in between.
    2009 Hyundai Elantra - Budget Sound in Progress
    HU- Kenwood eXcelon KDC-X994
    Fronts- Crescendo MP6 mids, Vifa Ring Radiator tweets on Arc KS300.4
    Subs- Single SA-10 on Mmats 2000.1 @ 1ohm
    Misc- 1/0 CCA from AT, Big 3 in Stinger HPM, and AT 60 mil deadener
    Bought from: Inferno333, select127, treesive, Kangaroux, DonH
    Sold to: coolest user, Psychodrama, MidgetClown, mr.tigger, av83
  6. #35
    Vincer77's Avatar
    Vincer77 is offline Member
    Feb 2013
    Near Nashville, TN
    58
    23 Post(s)
    When monster wire came out several years ago, they made some claim about larger wire transmitting some frequencies better when used as speaker wire. Was this just marketing hype?
  7. #36
    Mar 2011
    27
    3,488
    862 Post(s)
    Quote Originally Posted by Vincer77 View Post
    Yes.
  8. #37
    mlstrass's Avatar
    Jul 2006
    Illinois
    10,782
    6 Post(s)
    1266 Post(s)
    Quote Originally Posted by TheUnderFighter View Post
    Didn't say HAVE, said it WILL. I've 99% of the ca wire out there, and several types of welding. All the better car audio 1/0 is the same size as 2/0 welding and fits 2/0 terminals perfectly.
    We're just splitting hairs now...
  9. #38
    tommydh's Avatar
    tommydh is offline CarAudio.com Elite
    Mar 2012
    Baltimore, MD
    501
    160 Post(s)
    Well instead of cutting strands away I would look into terminal adapters. think of it like this you take a gallon of water n pourt through a straw takes forever take gallon of water pour through 2" pipe moves faster same in electrical less resistance from wire =less voltage drop and lower amp drw since less heat build up
  10. #39
    tommydh's Avatar
    Mar 2012
    Baltimore, MD
    501
    160 Post(s)
    Quote Originally Posted by UnderFire View Post
    They would have to have it tested by UL and to list as such and adhee to stricter manufacturing specs then. That cost money
  11. #40
    Bettr n' Revrse's Avatar
    Bettr n' Revrse is offline I do what I want
    Dec 2010
    Grand Junction, CO
    16,867
    2341 Post(s)
    Quote Originally Posted by Staynlean View Post
    omg, some dumb assses itt. Going back to bed
    Whos this newb?
    99 Honda CRV: (Always Changing) ___________ 79 F-150: Show Truck ________________
    -Head Unit: Kenwood DNX-692HD_____________ -Head Unit: Eclipse CD7100
    -Sub Stage: Focal KX40 16"_________________ -Sub Stage: Looking
    -Mids/Highs: Focal KRX & PHD AF____________ -Mids/Highs: Scan Speak & Blaupunkt
    -Sub Amp: Mosconi AS200.4_________________ -Sub Amp: American Warrior Set (Zed Built)
    -Mid Amp: Mosconi AS200.4_________________ -Mid Amp: ^^^
  12. #41
    Mar 2011
    27
    3,488
    862 Post(s)
    Quote Originally Posted by tommydh View Post
    They would have to have it tested by UL and to list as such and adhere to stricter manufacturing specs then. That cost money
    And they don't have to do any of that by listing it as 1/0?
  13. #42
    audioholic's Avatar
    audioholic is offline Moderator
    Aug 2003
    Parts Unknown
    23,747
    8 Post(s)
    411 Post(s)
    While finding an adapter that keeps you from having to trim away some strands is more ideal, trimming those strands for an inch or two of the wire does not limit over all resistance nearly as much as your water/pipe example implies. As someone explained eariler in this thread, wire resistance is defined as resistance per unit length multiplied by the over all length. So a couple inches of higher resistance (where you trim for a connector) wont alter the over all resistance by very much.
    No speaker, in the history of speakers, has ever been blown by too little power. Ever. I don't care what your friend told you, he's a dirty liar.
  14. #43
    tommydh's Avatar
    Mar 2012
    Baltimore, MD
    501
    160 Post(s)
    I was explaining more to the point of wh6y to go bigger I was not addressing the cutting of strands. All I know is if car audio ever had an inspection like real electrical Better not knick a whire while terminating let alone cut strands. I am a Master Electrician in MD, I have done numerous jobs with an insppector watching me do terms. I was dumbing down the explanation for the guy Resistance over length only means something to guys that know electrical theoryt.
  15. #44
    tommydh's Avatar
    Mar 2012
    Baltimore, MD
    501
    160 Post(s)
    The size is not the determining factor of ul listing or not. Someone mentioned NEC is more concerned with failure points. the exact table is NEC 70 310.16 has ampacity listings for copper, aluminum, and ccaluminum in various insulation types. To get that marking requires the testing and standards. As an electrician if I were to try to use a car audio cable in an application although 1/0 is supposedly 1/0 the jacketing would cause me to fail my inspection. Now a quick point some cables do look inconsistent to others in size that is due to number of strands and a bunch of other stuff.
  16. #45
    Mar 2011
    27
    3,488
    862 Post(s)
    ooo ok gotcha, I misunderstood. I thought you were responding to "why don't they just label it 2/0" haha. Hence my confusion.
  1. what kind of speaker wire for 15" RE XXX
    By adammk5 in forum Subwoofers
    Last Post: 08-07-2003, 11:55 AM
  2. Resistance of combination wiring scheme?
    By Diabolic in forum Wiring, Electrical and Installation Help
    Last Post: 05-13-2003, 02:37 PM
  3. does the size of the wiring matter??
    By ZmanTT in forum General Discussion
    Last Post: 08-02-2002, 07:19 PM
  4. Newbie in need of help wiring a system
    By Xtremitie in forum Wiring, Electrical and Installation Help
    Last Post: 04-25-2002, 04:26 PM
  5. What type of speaker wire to use?
    By tsbarro in forum Wiring, Electrical and Installation Help
    Last Post: 04-16-2002, 12:09 PM
