Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 16 to 30 of 46
Reload Thread: Point of oversized wire?
  1. #16
    fasfocus00's Avatar
    fasfocus00 is offline doITdaWHITEwayORdoITtwice
    Jun 2007
    New Orleans, LA
    5,618
    3 Post(s)
    459 Post(s)
    Re: Point of oversized wire?
    Quote Originally Posted by mlstrass View Post
    WTF are you talking about? In the CA world it is not accurate since 1/0 car audio wire = 2/0 AWG wire. Which is why I always tell people getting welding wire to get 2/0...
    I assume you have never built a high powered system, so maybe to you it is marketing. For those of use who have it's a necessity....
    no I have just been around longer than you and know what it means to have standards like what AWG have for wire sizes.
    Here is my feedback Thread: http://www.caraudio.com/forum/showth...ght=fasfocus00
    "If you ain't cheatin', You ain't trying"
  2. #17
    TheUnderFighter's Avatar
    TheUnderFighter is offline Beer Addict
    Mar 2011
    Murrieta, California, (SoCal)
    27
    3,488
    862 Post(s)
    Quote Originally Posted by BlurredVision View Post
    I get that, but the wire that's only making contract is really useful correct? I could have a wire twice the size of a 0 gauge terminal, but trimming half of it away to make it fit defeats the purpose right?
    No. Not at all.
    2009 Hyundai Elantra - Budget Sound in Progress
    HU- Kenwood eXcelon KDC-X994
    Fronts- Crescendo MP6 mids, Vifa Ring Radiator tweets on Arc KS300.4
    Subs- Single SA-10 on Mmats 2000.1 @ 1ohm
    Misc- 1/0 CCA from AT, Big 3 in Stinger HPM, and AT 60 mil deadener
    Bought from: Inferno333, select127, treesive, Kangaroux, DonH
    Sold to: coolest user, Psychodrama, MidgetClown, mr.tigger, av83
  3. #18
    Mar 2011
    27
    3,488
    862 Post(s)
    1/0 Car Audio wire does NOT equate to 2/0 AWG..... SOME car audio wire manufacturers OVERSIZE their wire (i.e. mislabel it), so that it is bigger than the AWG standard it is rated at. Knu is a great example, as their 1/0 wire, is the size of 2/0. Guess what. That makes it 2/0 wire, mislabeled as 1/0.
  4. #19
    mlstrass's Avatar
    mlstrass is offline Shaggy DOA
    Jul 2006
    Illinois
    10,782
    6 Post(s)
    1266 Post(s)
    Quote Originally Posted by fasfocus00 View Post
    Ok, you've never done any big builds just like I figured....
  5. #20
    mlstrass's Avatar
    Jul 2006
    Illinois
    10,782
    6 Post(s)
    1266 Post(s)
    Quote Originally Posted by TheUnderFighter View Post
    Holy contradiction. Any REAL car audio 1/0 wire = 2/0 wire, is that better? Don't care if it's mislabeled, it will be the size of 2/0 AWG which you just said...
  6. #21
    bgowdy's Avatar
    bgowdy is offline HE NEEDS SOME MILK
    Apr 2011
    Campbellsville, Ky
    7,749
    82
    2 Post(s)
    2440 Post(s)
    I went alttle cheap on my wire. I got 1/0 install bay wire. How ever i have 4 runs of it
    2 power wires ran front to back and 2 grounds front to back to make up for the lesser qualtiy wire
    But again i only paid like $15 and got 60ft from a friend...
    [B]02 KIA SPORTAGE
    2 Sundown SA 12 Dual 4's
    Enclosure: 4 Cubes Net @ 34ish Hz
    Soundstream Ta.3kw @ 1 ohm
    Stock 70a Alt ~ XS D3400 & 1 Kinetic HC1800 ~ 2 Runs Bullz Audio 1/0 ~ Bullz 1/0 Big 3
    Current Build Score ~ 143.5 On The Dash
    F.C.B.C. > 2010 450 Street 3rd Place Overall > 2011 450 Street Champion
    YOUTUBE SEARCH->bgowdy31 & bgowdy3131
  7. #22
    skylineTT's Avatar
    skylineTT is offline bass=sekz
    Jun 2007
    Houston/Dallas
    4,181
    714 Post(s)
    Quote Originally Posted by keep_hope_alive View Post
    for some theory on wire sizing and terminal contacts you can look to the National Electrical Code (NFPA 70).
    When wire is attached to a ring terminal, the goal is maximum conductivity. You can solder the wire to the ring terminal for better conductivity in car audio but that isn't done in commercial wiring, and we move a lot of power. Consider that DC current is simply the movement of electrons from one valence band to another (for more about valence bands and the materials that are good conductors, consult the periodic table of elements). So at every connection you are trying to maximize the ability for electrons to move from the wire strands to the connector. Compression-fit connectors are very good at achieving this.
    NEC also recognizes that the connector itself limits the amount of current you can move through a wire. So the tables are based on three different connector types.
    60 deg. C is based on a set screw connection (shove bare wire in and tighten a screw to hold it).
    75 deg. C is based on a compression lug with one bolt hole.
    90 deg. C is based on a compression lug with two bolt holes (larger/longer).
    You may have already guess that the reason they rate on temperature is because NEC cares most about preventing failure. All of the ampacity tables are based on temperature of the wire and temperature of the conductors.
    The second reason we increase wire size is due to voltage drop. Voltage drop happens because all wire has resistance per linear foot. Over long distances, the relationship between current and resistance results in a drop in voltage at the end of the wire.
    We increase wire size to compensate for temperature and voltage drop. We can run parallel sets or increase wire size. At a certain point it because difficult to work with larger wires. I prefer routing a pair of 4 awg wires over one 1/0 wire.
    I've been wondering where you ran off to!
    Refs: Dipitydoo, appollyon, bad95gt, revrider1, jwh1598, ampjunkielikeme, deathpenalty18, ssackett, snoopysnooper, corey0928, SPLAudio, Clifff150, CL1CKCLACK, ShawnT, West + more
  8. #23
    Beatin''s Avatar
    Beatin' is offline CarAudio.com Elite
    Nov 2012
    MI
    998
    574 Post(s)
    Doesn't Knu do that with their copper clad aluminum wires because it's not as good a conductor like OFC?
    All day I'm clippin'
    voltage be dippin'
    I don't give a damn,
    cause my trunk always hittin'!
    creating a proper sound wave. Step one, turn it up until clipping. Step two, done.
  9. #24
    IonRL205's Avatar
    IonRL205 is offline DJ h4z4rdes
    Sep 2008
    Abilene, Texas
    2,449
    946 Post(s)
    Quote Originally Posted by Beatin' View Post
    All their wires are oversized
    Headunit - Pioneer DEH-P8300UB
    Subs - None
    Sub Amp - 2x Crescendo 3kwp
    Front Stage - Polk Audio db651 Coaxial
    Front Amp - None
    Quote Originally Posted by zako View Post
    Most properly done 15 inch subwoofers are not suited for car audio use simply due to box size requirements.
  10. #25
    keep_hope_alive's Avatar
    keep_hope_alive is offline Acoustics Engineer keep_hope_alive is a Supporting Member of the forum!
    May 2007
    Quad Cities, IL
    7,078
    28
    47 Post(s)
    1500 Post(s)
    "oversized" is a poor term to use. wire ampacity rating comes down to the material used (CU or AL), the number of strands, and the AWG of those strands. You can look at cross-sectional area as well, but more air between conductors (fewer strands) reduces the amount of conductive area relative to total area. so to compare based on diameter alone is inaccurate. some use extra insulation to make the wire look fatter.
    if wire manufacturers published ohms/1000ft and wire strand AWG and count we would have an easier time comparing wire. they should also provide a temperature rating.
    got a question? shoot me a PM. Matthew 6:9-15 - YouTube Channel: https://www.youtube.com/channel/UCkYUo2EShW9lgtrfXiDvLNQ/videos
    2014 Accord build log: http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/608637-2014-accord-sport-sq-build-keep_hope_alive.html
    2001 Accord build log: http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/536049-2001-accord-ex-sedan-its-long.html
    Fix Photobucket Image Loading ------> https://addons.mozilla.org/en-US/firefox/addon/photobucket-fix/ <------
  11. #26
    May 2007
    Quad Cities, IL
    7,078
    28
    47 Post(s)
    1500 Post(s)
    Quote Originally Posted by skylineTT View Post
    busy actually working on cars and systems and not just talking about it.
    i'm also a family man and my work is time consuming.
    i commonly pass up $ex to work on car audio late into the night.
  12. #27
    pieper88's Avatar
    pieper88 is offline CarAudio.com Veteran
    Dec 2008
    West Point, IA
    29
    2,108
    37 Post(s)
    Just dumb
  13. #28
    May 2007
    Quad Cities, IL
    7,078
    28
    47 Post(s)
    1500 Post(s)
    Quote Originally Posted by pieper88 View Post
    Just dumb
    i'm dedicated.
    if she was a hooker i could just take a fvck break but wives don't like the fvck and dash.
  14. #29
    May 2007
    Quad Cities, IL
    7,078
    28
    47 Post(s)
    1500 Post(s)
    dp
    i would not pass up DP for car audio though.
  15. #30
    kramer_212's Avatar
    kramer_212 is offline CarAudio.com Veteran
    Jul 2011
    Minnesota
    4,480
    478 Post(s)
    no the purpose is to relive the line of its resistance, terminal contact has minimal effect (within means)
  1. what kind of speaker wire for 15" RE XXX
    By adammk5 in forum Subwoofers
    Last Post: 08-07-2003, 11:55 AM
  2. Resistance of combination wiring scheme?
    By Diabolic in forum Wiring, Electrical and Installation Help
    Last Post: 05-13-2003, 02:37 PM
  3. does the size of the wiring matter??
    By ZmanTT in forum General Discussion
    Last Post: 08-02-2002, 07:19 PM
  4. Newbie in need of help wiring a system
    By Xtremitie in forum Wiring, Electrical and Installation Help
    Last Post: 04-25-2002, 04:26 PM
  5. What type of speaker wire to use?
    By tsbarro in forum Wiring, Electrical and Installation Help
    Last Post: 04-16-2002, 12:09 PM
