Results 1 to 8 of 8
Reload Thread: LOC to sub amp question - simple
    nate v's Avatar
    nate v is offline Junior Member
    Apr 2004
    Ft Lauderdale
    I had a mono Alpine sub amp installed with a LOC by tapping into a rear speaker - ...question is that the installer only tapped off of the right side speaker...so when I shift balance to the left there is no bass at all.....should the LOC be hooked up to both right and left rear speaker lines (the LOC that is)? Am I losing half the "bass" signal or does it not matter as it is a mono amp?....sorry for the confusing question but it should be a very simple answer. Thanks in advance
    Mark_ab's Avatar
    Mark_ab is offline The Alpha Male
    Feb 2002
    Edmonton, Alberta
    36
    4,213
    5 Post(s)
    Re: LOC to sub amp question - simple
    Most LOC's utilize the signal from both right and left channels off the HU. Which LOC are you using?
    Is this not a reasonable place to park?
    maylar's Avatar
    maylar is offline Electrical Weenie
    Jan 2002
    Connecticut
    66
    3,498
    2 Post(s)
    399 Post(s)
    Yah, usually LOC's are stereo and you feed both channels to the amp. You can't depend on all music to have the same bass out both channels.
    dave
    1999 Buick Park Ave Ultra
    Head Unit: JVC KWHDR720
    EQ: Audiocontrol EQL
    Front Stage: Hybrid Audio Technologies Imagine 5.25 mids, Morel Maximo tweets
    Sub Stage: Boston G3 10", 0.5 cu ft sealed
    Amp: PPI Phantom 900.4
    Rear Fill: Boston SE953 6X9's
    nate v's Avatar
    Apr 2004
    Ft Lauderdale
    Well I am using one from Best Buy (orange and black one) and one from the world famous Radio Shack...would switching to a David Navone 4 channel (or (2) 2 channels ones of his improve things noticeably? I understand that it "should" be connected to both left and right channels as there is usually different bass signals routed to each side....I just needed some confirmation before I tried attatcking it as it is under my rear seat. Thanks a lot
    preunnerv6's Avatar
    preunnerv6 is offline Member
    Feb 2004
    Depends on your point of view
    59
    I've used David Navone LOC's in different installs for years. I just put a new DN 4-channel loc on a 5-year old aftermarket cd-player w/ weak pre-outs. This loc works like a charm gives great SQ. They are some of the best on the market.
    BUT, in your application, you're just using it for a sub. I would first get the loc installed properly, both left and right, as others posted. Then see how that works. If you are unsatisfied, then DN has great locs. Some are even strictly for lowpass applications.
    Mark_ab's Avatar
    Feb 2002
    Edmonton, Alberta
    36
    4,213
    5 Post(s)
    For the price Navone units can't be beat. Plenty of options to choose from, quality units (although their 9.5V rating on the 77 and some others may be a little overrated).
    VTEC11's Avatar
    VTEC11 is offline Member
    Mar 2004
    NJ
    83
    I think the output level from the LOC depends on the signal output from your radio's amplifier section.
    nate v's Avatar
    Apr 2004
    Ft Lauderdale
    Yes I agree that it does depend on HU output voltage but I think the Mod was speaking of a "line driver loc". Anyways, I appreciate the input. I am using 1 of the LOCs (probably the Best Buy one) - I haven't checked yet. Would I be better off with a higher quality LOC for the front stage? Boston Acous. Pro Series 6.5 driven with a JBL GTO series ****** amp.....upgrade amp first of loc first?
  1. Sub wire question for a 2 ch amp
    By Cathlock in forum Subwoofers
    Last Post: 03-19-2004, 11:55 PM
  2. JL 12w08 amp question, HELP!
    By corollin in forum Subwoofers
    Last Post: 02-29-2004, 06:20 PM
  3. amp question
    By Benny212 in forum Amplifiers
    Last Post: 01-08-2004, 08:58 AM
  4. Question about my 2 ch amp
    By liqdsm in forum Wiring, Electrical and Installation Help
    Last Post: 12-19-2003, 11:31 PM
  5. SIMPLE QUESTION ON 4 channel amp
    By drpain714 in forum Wiring, Electrical and Installation Help
    Last Post: 07-22-2003, 01:07 PM
