Results 1 to 4 of 4
Reload Thread: 3 band parametric EQ
    Taycron's Avatar
    Taycron is offline Member
    Oct 2003
    Massachusetts
    41
    108
    Since my last post got an overwhelming zero responses I thought I'd try my luck again.
    I'm looking at 2 head units (both kenwood because money got tight). One is a regular kenwood that has a bass, mid, and treble controls while the other is an excelon that has a 3 band equalizer.. Are they basically the same thing? I'm not really sure if a 3 band EQ is better or not..
    Dec 2001
    Violates Miranda
    3,238
    Re: 3 band parametric EQ
    sounds to me like its the same thing.
    Drum437's Avatar
    Drum437 is offline The Mank!
    Mar 2004
    Texas
    30
    34
    On a Parametric EQ you can adjust the frequency that you increase or decrease the particular band at, (i.e. Bass, Mid, Treble)
    94' F150 Extended cab
    Infinity kappa 6.5's, and 5x7's
    2 JBL p1220d subs in a custom box ported at 28 hz
    1 JBL 1200.1
    1 JBL 80.4
    Sony M-630 cd receiver, still goin after 4 years...strange..
    sumone's Avatar
    sumone is offline CarAudio.com Veteran
    Dec 2003
    Midwest
    3,416
    same thing.
    only difference is the the EQ tells you the frequency in hertz, while the other one just gives you generic names (bass, treble, etc).
    HOwever, they may not be the same frequencies. Like it was said above, a parametric eq allows you to set the frequencies and width. I think on most radios 100hz is usually used for bass and about 10khz for treble
