Page 2 of 2 FirstFirst 1 2
Results 16 to 18 of 18
Reload Thread: Custom build - expert advice needed.
  1. #16
    jockhater2's Avatar
    jockhater2 is offline CarAudio.com Veteran
    Sep 2011
    Saukville, WI
    3,037
    1282 Post(s)
    Re: Custom build - expert advice needed.
    Quote Originally Posted by veedubtek View Post
    LOL, yeah...8 exotic pearls in this paint, it's nuts. I'm basically just taking elements from the new scirocco that we don't get, and implementing them into mine. The paint, engine, etc...I've owned and built several mk5's, so I've got a soft spot for this engine anyway. I also worked for VW for 14 years fixing these dam things. This engine with just a k04 and fuel pump and some uni software is gonna be around 300hp in a 2100lb car...and the way I built the transmission, it'll cruise 70mph at 2300rpm's all day long.
    We cut out my arches (which barely flare out at all on a mk1), and cut out the same from a mk2 GTI (much wider), and welded them in. Alot easier to say than do obviously...and they look like they belong there. We probably spent 40 hours alone getting them on there and making them look legit. and mk1 rocco didn't have a fuel door, just an exposed cap. Again, just cut a fuel door and surrounding metal out of a mk2 jetta, and grafted it in.
    Thanks again, I'll definitely shoot him a pm. I'm not tied to JL at all...I just happen to have one out of my old R32. I'd be just as happy tossing it in my TDI wagon and something works better for this project.
    200hp in a 2100lb car is a lot. You don't have to try and per sway me into what fast is. My jetta is a 1.8L, and so is my bmw. SO I know what slow is
    That is a great idea. Fast car, but still have good daily driver capabilities.
    Wow. I can't believe you cut off and welded on new arches. It doesn't look like you did that. What a fantastic job you did.
    JL is definitely a great brand. But there are so many SQ brands out there and you could something a little more unique if you would like.
    I am by no means a fabricator or anything. I am 22. But I will be adding a 2nd alternator in my jetta if you would like to see how it was done. (I didn't do it, my buddy did 1 for me, and iraggi did the other). I just did the serpentine belt conversion, which I thought would be over my head. But was straight forward and easy.
    Head Unit Pioneer P99RS
    3 Runs of 1/0 OFC Power and 3 Runs of 1/0 OFC Ground
    1 XS Power D3400 & 2 XS Power XP3000 with Copper Bus Bars
    380 Amp & 320 Amp Iraggi Alternators(One is a chevy case, the other ford)
    RD 7500.1 running 2 12 inch SPLaudio (AA Mayhem motors/baskets)
    Tuned to 36 hertz. About 4.5 cubic feet, 8" Aeroport (made by dbeez)
    Zed Audio Leviathan III on Morel MDT-29, RS100-4 & RS225-8 Daytons
    Alex Jones www.infowars.com Endgame, Obama Deception, Truth Rising,
    Fluoride in the water, poison in vaccines, chemical trails in the skyglobal
    elite banks run our government towards a one world global government.
  2. #17
    veedubtek's Avatar
    veedubtek is offline Junior Member
    Feb 2013
    Winston-Salem, NC
    5 Post(s)
    Quote Originally Posted by jockhater2 View Post
    Check out my build thread, detailed pics of everything thus far:
    VWVortex.com - I hate money...
  3. #18
    jockhater2's Avatar
    Sep 2011
    Saukville, WI
    3,037
    1282 Post(s)
    wow. The attention to detail is unheard of. It really looks great.
  1. 4 Channel Amp System. Expert advice needed
    By suleman36 in forum General Discussion
    Last Post: 02-06-2008, 10:12 PM
  2. SQ expert advice needed.
    By davidtemple in forum Wiring, Electrical and Installation Help
    Last Post: 01-13-2007, 10:07 PM
  3. $800 To Spend. Expert Advice Needed
    By travolta in forum General Discussion
    Last Post: 07-02-2006, 03:44 AM
  4. Will this work? Expert advice needed
    By MotoRider in forum General Discussion
    Last Post: 10-14-2002, 01:48 AM
  5. Help Me! (Expert Advice Needed)
    By LoneRanger in forum Subwoofers
    Last Post: 05-20-2002, 01:25 PM
