Results 1 to 11 of 11
Reload Thread: 2 10's and 1 15' in the same box???
    Only The Best's Avatar
    Only The Best is offline CarAudio.com Elite
    Nov 2012
    texas
    548
    1 Post(s)
    189 Post(s)
    so i have a very very large.... like 6ftx2.5ftx2ft box that is sittin on my entire backseat of my dodge ram 1500.... it has 3 10 alpine type r's facing the roof with the port all the way across the bottom blowing forward.... yes it is chambered off.... but i have enough room on the top to cut the hole out bigger for a 15" in the middle of 2 of the type r's and i wanted some lower bass... would there be a problem with doing this if i had my rockford fosgate t1000.1bd running the two type r's and find something else to run the 15"?...
    RicksI30's Avatar
    RicksI30 is offline CarAudio.com Elite
    May 2011
    Tucson, Az
    29
    588
    189 Post(s)
    Re: 2 10's and 1 15' in the same box???
    Really it is not the best idea, also your assumption that a 15 will give you lower bass is wrong especially thrown into an enclosure that wasn't made for it.
    1. What are the specs of the enclosure?
    2. What 15?
    Head unit: Kenwood Excelon KDC-X996
    Front stage: Alpine Type X PRO mids Vifa Neo 1" silk tweeters
    Front stage amp: PPI Bk800.4
    Subs: SSA XCON 12's in 4.5 cubes tuned to 34hz
    Sub amp: PPI Bk1300.1
    Sound Deadening: Second Skin Damplifier Pro, Spectrum, and Sludge
    Team SSA
    Nov 2012
    texas
    548
    1 Post(s)
    189 Post(s)
    for each chamber its about 2-2.3 ft^3 tuned to 34 hz
    and idk about the 15... thats a whole nother question.... probably wanting something around the 200$ range maybe 300... pushing at least 800 rms
    RicksI30's Avatar
    May 2011
    Tucson, Az
    29
    588
    189 Post(s)
    Where did you get the enclosure? Three 10" type r's in a proper enclosure should be very loud.
    Team SSA
    Nov 2012
    texas
    548
    1 Post(s)
    189 Post(s)
    i built it myself... and yes... it is... VERY rediculously loud.... BUTTTT.... i want it to be louder... the reccommended air space for them was 1.8 i believe and i made them have a little bit more... the lows are stupid.. but i want it to be so loud to the point of where i cant physically take it..... i have a bass fetish i know...
    RicksI30's Avatar
    May 2011
    Tucson, Az
    29
    588
    189 Post(s)
    Quote Originally Posted by Only The Best View Post
    Sell the r's add that to your 2-3 hundred and buy two 15's.
    Team SSA
    Nov 2012
    texas
    548
    1 Post(s)
    189 Post(s)
    2 15's better than 3 10's?... and which 15's would u reccomend for around $500
    RicksI30's Avatar
    May 2011
    Tucson, Az
    29
    588
    189 Post(s)
    Yes it is more cone area, so it should be louder. The most important part will be a good enclosure though. If the enclosure for your r's isn't right you might want to try a new one before changing equipment.
    Two of these if you can do $550 GCON-15 Sound Solutions Audio 15" 750W GCON Series Subwoofer - SSA STORE
    Team SSA
  9. #9
    Nov 2012
    texas
    548
    1 Post(s)
    189 Post(s)
    have you had a chance to hear them?... might be looking for somthing louder... i might be willing to push 750 if it is competition worthy
  10. #10
    momax_powers's Avatar
    momax_powers is offline Senior VIP Member
    Jul 2012
    Canada
    448
    175 Post(s)
    Depending on the layout of the box if you are able to knock out the walls separating the chambers or cut the centers oit making them into braced... You may be able to salvage the box and use it for 2 15s or you can leave the box as is and make the cutouts larges enough for 3 12s since 2-2.3cube is good for most 12s
  11. #11
    RicksI30's Avatar
    May 2011
    Tucson, Az
    29
    588
    189 Post(s)
    I have heard them and they are awesome for their price. If you step your budget up the Icons can take twice the power.
    Team SSA
  1. differnt sized subs in the same box(running an 8" and 12" in the same box)
    By Jroo in forum Enclosure Design & Construction Help
    Last Post: 12-07-2012, 02:36 PM
  2. Replies: 1
    Last Post: 01-01-2012, 09:06 PM
  3. Box for DD 2512 & DD1510 . in the same BOX "HELP"
    By MeMo2 in forum Enclosure Design & Construction Help
    Last Post: 06-28-2010, 12:27 AM
  4. Putting different size aero ports in the same box?
    By bunkerking09 in forum Enclosure Design & Construction Help
    Last Post: 08-14-2008, 04:12 PM
  5. ? about 2 subs in the same box not sealed off.
    By generalGOTCHA in forum Enclosure Design & Construction Help
    Last Post: 02-06-2007, 12:17 PM
Tags for this Thread
