+ Reply to Thread
Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 16 to 30 of 60
Reload Thread: What my weakest link in SQ?
  1. #16
    sjv13's Avatar
    sjv13 is offline StayStrange
    Apr 2011
    Lansing, MI
    616
    2 Post(s)
    Re: What my weakest link in SQ?
    @mylows10 ; @av83 ;
    Is it a big deal if I still have stock speaker wire in place from the speaker, through the door, through the door jamb boot to the inside? I still have it there because after taking a look and trying for 30 minutes or so, it seemed like it would be impossible to get my Kicker 16ga through there and to the speaker (1. It doesnt seem like there is room for anymore wires in the boot, 2. there are 2 90˚ turns in it).
    2000 Volvo v70
    HU: Pioneer MVH-8200bt
    Front Stage: Focal IS-165
    Sub: Alpine Type-R 12"
    Speaker Amp: Polk PA660 bridged to 150x2wrms
    Sub Amp: Alpine MRX-M50
    Sub Box: Custom, tuned to 33Hz
  2. #17
    av83's Avatar
    av83 is online now CarAudio.com Veteran
    Mar 2012
    Illinois
    2,601
    48 Post(s)
    Quote Originally Posted by sjv13 View Post
    @mylows10 ; @av83 ;
    I was able to disassemble the boot, and run two 16 ga wires through it, since I run active. There were plugs that unattached the wire harness from the body, and disconnected the boot from the door. I had to run wire from inside the door, to the boot opening i had disconnected(still had the wires in it, since the plug/wire harness was attached to the other end). Then i had to run the wires through the boot, past the wires(took some wiggling, lol) and to the disconnected plug. Then i had to route the wires through a little space in the plug, since i couldn't go around it, as the plug makes a water-proof seal with the body. Then I could pull the wires through into the body, and reassemble the boot and wire harness/plug.
    This is for a mid 2000's GM, though... so IDK if it applies to you. But it should be possible if you spend dome time trying to figure it out. I've heard some have had luck with using a rod or coat hanger to guide the wire through the boot.
    HU: KDC-X994
    Front stage: Phd FB 6.1PRO KIT, Active
    Sub stage: 1st gen RE XXX 12" w/Fi recone
    Highs Amp: Kenwood Excelon XR-4S
    Lows Amp: Mmats D300hc
    The Rest: AT 60 mil, Optima Redtop underhood and Yellowtop in trunk, Big 3 and front to rear +/- runs in Monster Cable 1/0
  3. #18
    sjv13's Avatar
    Apr 2011
    Lansing, MI
    616
    2 Post(s)
    Quote Originally Posted by av83 View Post
    Yeah. If I spent more time and looked at it closer I bet I could eventually get it. The tweeter wires go into the dash and I dont know where the heck they are routed. I just took the factory harness from behind the dash, snipped off the connector, and all the wires were right there and easy to get to. Do you think the stock speaker wire is really holding me back from some SQ?
    2000 Volvo v70
  4. #19
    av83's Avatar
    Mar 2012
    Illinois
    2,601
    48 Post(s)
    Same here, but local hardware store. I just have a hard time believing that OPEN cell foam can make much of a good seal. You know?
    Works just fine. Trust me. These seals..
    make me this sound like this.
    I used the rubber foam this time, but the more "foamy" foam worked for me in the past just fine.
    HU: KDC-X994
  5. #20
    av83's Avatar
    Mar 2012
    Illinois
    2,601
    48 Post(s)
    I did, but the wire in my car is soooo thin, lol. The 16 gauge i ran looks twice the size of my stock wire. If it's short, and the power is low, you're ok. But use this to find out if you're good. Wire Calculator
    HU: KDC-X994
  6. #21
    sjv13's Avatar
    Apr 2011
    Lansing, MI
    616
    2 Post(s)
    I'd say the reason you can do that is because your comps are being fed monsterous power. 120rms if I recall correctly? 150 is what they can handle
    2000 Volvo v70
  7. #22
    av83's Avatar
    Mar 2012
    Illinois
    2,601
    48 Post(s)
    My comps are on a 120x4, with a channel dedicated to each mid and each tweeter...
    But the midbass/bass would still be weak if I were allowing the rear firing sound waves to cancel out the front firing ones. They are opposite of each other, and if you allow them to mix, you can't hear the output. Wire two subs up, but with one out of phase(wired backwards), and you have the same effect. Cancellation. You can have great midbass with half the power.
    HU: KDC-X994
  8. #23
    sjv13's Avatar
    Apr 2011
    Lansing, MI
    616
    2 Post(s)
    If you notice the gap (where the woofer's magnet sets into the door), I plan to add some polyfill around back in there (if it doesnt interfere with the window) and then add a rubber strip to from a seal between the door and plastic speaker bracket. Will this help me out a lot?
    2000 Volvo v70
  9. #24
    av83's Avatar
    Mar 2012
    Illinois
    2,601
    48 Post(s)
    Attachment 26539906
    lol!! Fuck ya it'll help. Thats what i was asking you about in the email, about whether the bracket sat flush with the door or not. Fix those gaps, and get a solid tunnel leading into the door, and you'll be golden. That is, without a doubt, the source of your midbass problemo senor.
    HU: KDC-X994
  10. #25
    sjv13's Avatar
    Apr 2011
    Lansing, MI
    616
    2 Post(s)
    Awesome! That's what I wanted to hear. haha. How much of a difference will the polyfill make? Because I'm not sure if I will be able to use it or not because of the window.
    2000 Volvo v70
  11. #26
    av83's Avatar
    Mar 2012
    Illinois
    2,601
    48 Post(s)
    zip. Polyfil won't do a thing. Think of whats behind that speaker as an enclosure. You need something more solid to seal those gaps.
    HU: KDC-X994
  12. #27
    sjv13's Avatar
    Apr 2011
    Lansing, MI
    616
    2 Post(s)
    Yeah, I'm going to use some type of rubber stripping to seal that part off. But what about behind there? Would the polyfill help?
    2000 Volvo v70
  13. #28
    av83's Avatar
    Mar 2012
    Illinois
    2,601
    48 Post(s)
    yeah, i'm going to use some type of rubber stripping to seal that part off. But what about behind there? Would the polyfill help?
    Not really. Bagged fiberglass batt mat does.
    HU: KDC-X994
  14. #29
    sjv13's Avatar
    Apr 2011
    Lansing, MI
    616
    2 Post(s)
    Home insulation?
    2000 Volvo v70
  15. #30
    hispls's Avatar
    hispls is offline CarAudio.com Veteran
    Sep 2009
    Cape Cod, Massachusetts
    4,706
    15
    85 Post(s)
    So if you had to rate all those in order of making the most improvement, how would it go?
    Head unit with active crossover + time delay. 30 band EQ (probably separate), then care in component location and deadening/treatment of locations
+ Reply to Thread
  1. Here's what I wanna put in my car, opinions needed!
    By Tyrant171 in forum General Discussion
    Last Post: 08-24-2008, 01:41 PM
  2. Replies: 1
    Last Post: 03-18-2003, 02:22 PM
  3. What would be louder in my case.
    By QuadPioneer in forum Subwoofers
    Last Post: 02-06-2003, 03:24 PM
  4. What would work best in my Jeep Wrangler???
    By tomrob in forum General Discussion
    Last Post: 01-07-2003, 10:41 PM
  5. What should I put in my Lexus?
    By Casurfer99 in forum General Discussion
    Last Post: 08-16-2002, 11:25 AM
