Click "Reload" to fetch new posts without leaving the page.
Automatic thread refreshing has been stopped because you appear to be idle. Un-Idle
Reload -
Re: Advice/Questions new system
Originally Posted by
darron016
I have a stock battery but I just put it in last year bought it from O rillys so it is relatively new.
Yes I was thinking of only doing 2 of the 3 because the 3rd one was confusing.. I can do ALT to batt easily and batt to ground easily.. But the other one about the motor is confusing so I might just go with the 2,
Engine to ground is arguably the most important of the three. You can alternatively use the alternator case to ground. This connection grounds out the alternator case, which is usually grounded through the engine block to the chassis by a tiny wire
darron016
NASTY08IMPALA
the big 3 isnt confusing ur makin it harder than it has to be buddy..step 1 run fused power wire from alt to positive battery terminal..step 2 run ground from case bolt on alt to negative on battery ..step 3 run ground from the frame to the negative battery terminal...dont ground to block of engine
out of curiosity, why does 2 of the big 3 have to do with ground?
And so when im done Ill be having 3 connections to my negative battery terminal correct? (stock neg to ground)(neg to alt neg)(neg to ground again)
Tenacious
yea because the engine is mounted in big.rubber mounts not.the greatest condductor ....that why alt case is better
Tenacious
Engine to ground?
Isnt the engine already grounded? Why would I connect a ground to a ground? I could see if it was the battery to ground..
Or am i getting lost. hahhahahaha
darron016
yes
darron016
Engine to ground?
You're getting lost. The engine itself is NOT a ground
darron016
Engine to ground?
yes exactly why i said dont worry abkut the engine ur getting confused do the 3 steps i said and u will be fine
NASTY08IMPALA
Either one works if done correctly but alt case is a whole lot easier to get to on my car. And I'd rather do alt case anyway because its more direct
Okay thanks, last questions does the VOLT METER plug into... a speaker output on amp? Or where in the amp do I plug it?
darron016
Put it with the power wire that's coming from your battery and ground it wherever you want
darron016
get a good one with 3 wires they r simple ...power ground remote all on amp that way it turns in and off when the amp does
---------- Post added at 01:43 AM ---------- Previous post was at 01:42 AM ----------
Tenacious
nah that tells u what the cars voltage is and not.the voltage at the anp which is what u wana monitor
---------- Post added at 01:43 AM ---------- Previous post was at 01:43 AM ----------
Tenacious
So do I ground it to my car, or just ground it with the ground wire at the point where it goes into amp?
darron016
Either one works, but grounding it somewhere else saves wire. Of course 18 gauge wire is about 7 cents a foot so that's not a big deal.
run 3 wires from the meter to the power ground and remote all on amp saves from tapping into factory wires
By BossBeimer in forum Subwoofers
Last Post: 12-17-2010, 11:02 PM
By systemJLx in forum General Discussion
Last Post: 09-02-2010, 11:19 PM
By rwest0115 in forum General Discussion
Last Post: 08-15-2007, 12:43 AM
By cphelan1 in forum General Discussion
Last Post: 04-05-2005, 06:41 PM
By JonnyBlaze in forum Subwoofers
Last Post: 05-12-2004, 12:02 PM
- You may not post new threads
- You may post replies
- You may post attachments
- You may edit your posts
Forum Rules
Bookmarks
