Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 31 to 45 of 60
Reload Thread: Advice/Questions new system
  1. #31
    Tenacious's Avatar
    Tenacious is offline Banned
    May 2012
    Lebanon, TN
    542
    239 Post(s)
    Re: Advice/Questions new system
    Quote Originally Posted by darron016 View Post
    Back to my original question, when I have 2 amps hooked up.. Should I get battery in trunk than? Or just upgrade the alternator instead of a new battery in trunk..
    Or just do big 3 and call it.
    Do the big 3 and a single battery in the back won't hurt anything. No need to upgrade the alternator for that kind of power unless you have an old car with a very small alternator
    ---------- Post added at 11:55 PM ---------- Previous post was at 11:54 PM ----------
    And the volt meter is a good idea. They're worth the $2 they cost on eBay
  2. #32
    NASTY08IMPALA's Avatar
    NASTY08IMPALA is offline CarAudio.com Veteran
    Aug 2012
    LOUISVILLE, KENTUCKY
    6,131
    3 Post(s)
    2554 Post(s)
    Quote Originally Posted by Tenacious View Post
    i would start with the batterynder the hood first .i wouldnt put a good batt in the back with a crappy one up front
  3. #33
    darron016's Avatar
    darron016 is offline Senior VIP Member
    Dec 2012
    minneapolis, mn
    392
    294 Post(s)
    Why get a voltmeter? so i know it is changing volts? whats the point of that?
  4. #34
    Aug 2012
    6,131
    3 Post(s)
    2554 Post(s)
    to watch rhe voltage and make sure its not dipping too low..wire it directly to amp..its a must have
  5. #35
    darron016's Avatar
    Dec 2012
    minneapolis, mn
    392
    294 Post(s)
    Wire it directly to which amp?
    What should the voltage be at? And what is too low?
    And what should I do if it does dip too low?
  6. #36
    Aug 2012
    6,131
    3 Post(s)
    2554 Post(s)
    wire to sub amp ....should be around 13.8 -14.4 with car running ....dont dip below 12 and if it does turn it.down ..this will let u know how.good ur electrical is
  7. #37
    Tenacious's Avatar
    May 2012
    Lebanon, TN
    542
    239 Post(s)
    Quote Originally Posted by NASTY08IMPALA View Post
    Depends on how old his battery under the hood is. If its pretty old then yea, it's worth replacing it anyways
  8. #38
    tommydh's Avatar
    tommydh is offline CarAudio.com Elite
    Mar 2012
    Baltimore, MD
    509
    163 Post(s)
    Do the big three first. I have a Hifononics BRZ 1700 @2ohms and a 4 channel pioneer amp in a mini cooper with stock Battery and alternator only have 2 of the big 3 done grounds and am not having any problems with dimming at all. Im running 1 sd-2 10 soon to be 2 of them as soon as I finish my box
  9. #39
    Aug 2012
    6,131
    3 Post(s)
    2554 Post(s)
    Quote Originally Posted by tommydh View Post
    yea but hes already experiencing dimming issues.big 3 isnt a miracle fix. id say he needs at least a god batt under the hood if the stock one isnt new
  10. #40
    darron016's Avatar
    Dec 2012
    minneapolis, mn
    392
    294 Post(s)
    I have a stock battery but I just put it in last year bought it from O rillys so it is relatively new.
    Yes I was thinking of only doing 2 of the 3 because the 3rd one was confusing.. I can do ALT to batt easily and batt to ground easily.. But the other one about the motor is confusing so I might just go with the 2,
  11. #41
    darron016's Avatar
    Dec 2012
    minneapolis, mn
    392
    294 Post(s)
    Stock is new, I replaced it thinking my old battery was dead. Come to fine out I needed a new alternator instead. My alternator is 6 months old.
  12. #42
    tommydh's Avatar
    Mar 2012
    Baltimore, MD
    509
    163 Post(s)
    I agree Im just waitig for my factory battery to die before replacing it. Now the way I was taught as Electrician when running Multiple batteries they need to be the same ones
    ---------- Post added at 01:29 AM ---------- Previous post was at 01:28 AM ----------
    what type of vehicle is it?
  13. #43
    darron016's Avatar
    Dec 2012
    minneapolis, mn
    392
    294 Post(s)
    Chevy cavalier 1999
  14. #44
    Aug 2012
    6,131
    3 Post(s)
    2554 Post(s)
    the big 3 isnt confusing ur makin it harder than it has to be buddy..step 1 run fused power wire from alt to positive battery terminal..step 2 run ground from case bolt on alt to negative on battery ..step 3 run ground from the frame to the negative battery terminal...dont ground to block of engine
  15. #45
    tommydh's Avatar
    Mar 2012
    Baltimore, MD
    509
    163 Post(s)
    that is the easy one you ground your engine block AKA alternator ground to ground point. You should probably see a braided strap or something similar there now.
  1. Replies: 41
    Last Post: 12-17-2010, 11:02 PM
  2. Replies: 35
    Last Post: 09-02-2010, 11:19 PM
  3. Need Advice for new system
    By rwest0115 in forum General Discussion
    Last Post: 08-15-2007, 12:43 AM
  4. Second post......advice on new system
    By cphelan1 in forum General Discussion
    Last Post: 04-05-2005, 06:41 PM
  5. need advice on new system
    By JonnyBlaze in forum Subwoofers
    Last Post: 05-12-2004, 12:02 PM
