Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 16 to 30 of 31
Reload Thread: Budget bass help needed
  1. #16
    st0n3r's Avatar
    st0n3r is offline Senior VIP Member
    Apr 2012
    317
    115 Post(s)
    Re: Budget bass help needed
    You dont seem to be really understanding what people are telling you. 15's are just not a feasible option. If you wanted to run just 2 15" subs in that trunk it would literally require the ENTIRE trunk being used as a box. It would require the box to be built and assembled in the trunk. My Ford Fusion has about that same amount of trunk space and i have a single 15" sub. I cant stand that i dont have the room to make a box that would allow the sub to maximize its potential. It also ***** that building the box out of the car severely limits the size you can go. I suppose to could go 2 sealed 15's but than your budget on an amp needs to go up significantly.
  2. Likes AxT4430 liked this post
  3. #17
    MOFOMAN's Avatar
    MOFOMAN is offline Senior VIP Member
    Jan 2013
    Michigan
    150
    44 Post(s)
    iv heard 4 cheap *** 12s beatin the **** out a blazer if you can fit them
  4. Dislikes av83, DoesDad disliked this post
  5. #18
    zako's Avatar
    zako is offline CarAudio.com Elite
    Jan 2011
    TX
    1,347
    238 Post(s)
    One proven formula is two Sundown SA-12s in a ported box, wired for final 1 ohm load. Spend the rest of money on the best 1ohm stable mono subwoofer amplifier, hopefully with 1500watt RMS output or more. Note, this may require upgrading cars electrical (at least the big 3 wires). Adjust box size and tuning frequency according to taste, etc. These handle a lot of power and can sound very clean (they did very well on a Klippel)
  6. #19
    zako's Avatar
    Jan 2011
    TX
    1,347
    238 Post(s)
    Quote Originally Posted by st0n3r View Post
    I agree mostly, though some 15s can work in a manageable sealed box. An Alpine engineer recommended 2cu ft for the new Alpine type-S. Not only they're cheap, but they also sound very good. According to him, better than the R8s which were his favorites previously. Still, trying to fit 4cu ft box in a sedan trunk is a challenge. The woofer probably needs to be up firing. Jim did that experiment in an SUV, which is of course much easier.
  7. #20
    SPLaudio's Avatar
    SPLaudio is offline CarAudio.com Veteran
    Feb 2009
    upstate ny
    6,621
    8 Post(s)
    722 Post(s)
    i can make you some high powered subs but dont have anymore aq motors,pm me...
  8. #21
    naughtyca's Avatar
    naughtyca is offline CarAudio.com Veteran
    Feb 2012
    Tampa FL
    2,105
    803 Post(s)
    I need to put my 2 vvx 15 skar subs in sealed to see how much bass I lose just to test this theory.
  9. #22
    AxT4430's Avatar
    AxT4430 is offline CarAudio.com Elite
    Aug 2012
    Akron, OH
    28
    848
    470 Post(s)
    Quote Originally Posted by SPLaudio View Post
    Damnit Dean.. I cant be suggesting you and youre low on stock ....
  10. #23
    SPLaudio's Avatar
    Feb 2009
    upstate ny
    6,621
    8 Post(s)
    722 Post(s)
    i got motors just no aq
  11. #24
    PrinceCharming's Avatar
    PrinceCharming is offline PrinceCharming
    Aug 2012
    New Albany, MS
    94
    15 Post(s)
    I have a feeling it would cost a bit of cash to have someone make me a sub.
  12. #25
    Aug 2012
    New Albany, MS
    94
    15 Post(s)
    Alright so which would be better? 2 12's or 1 15?
  13. #26
    CaddieJapan's Avatar
    CaddieJapan is offline Senior VIP Member
    Feb 2008
    Japan
    268
    60 Post(s)
    In your car I would do two wicked a$$ 12's on a Crescendo BC2K or Audioque amp. Have you looked in the classifieds for anything yet?
    SA 12s used
    Aug 2012
    New Albany, MS
    94
    15 Post(s)
    I havent yet because I'm just trying to get everything planned out before I start buying. It'll probably be summer before I even have time to set everything up.
  15. #28
    Aug 2012
    New Albany, MS
    94
    15 Post(s)
    So measured my db level using a couple cheap *** apps on my phone. Which sounds better for 2 "old" Memphis Power Class 10's in a sealed dual ProBox? 119 dbs or 100 dbs? Whichever is right, I want at least 4 times the output.
  16. #29
    Aug 2012
    New Albany, MS
    94
    15 Post(s)
    Ive been reading around and Its come down to 2 Sundown SA 12's or 2 American Bass XFL 12's. I'm leaning more toward the XFL's because of the reviews and comments they got but I'm looking for someone to give me a reason to go with the SA's.
  17. Dislikes joom disliked this post
  18. #30
    Tenacious's Avatar
    Tenacious is offline Banned
    May 2012
    Lebanon, TN
    542
    239 Post(s)
    I'd go with 2 XFL 12s. Seal off your trunk and fire them into the cabin. If you build your own box (it isn't really hard, can just be time consuming and requires tools) that would only take $400. You could use the rest of your budget to buy a good 2000-3000w amp. You'll also want to look into doing the big 3 and probably getting a AGM battery in the back to power it.
  1. Budget components help needed!
    By lovephil in forum Speakers
    Last Post: 08-14-2012, 10:38 AM
  2. i need more bass help pls
    By timythea05 in forum General Discussion
    Last Post: 10-11-2004, 07:09 PM
  3. *help: need some bass but want no sub*
    By jeremy1122k in forum General Discussion
    Last Post: 05-24-2004, 03:32 AM
  4. in need of more bass HELP sony
    By bottwell666 in forum Subwoofers
    Last Post: 04-20-2004, 12:54 AM
  5. Bass Blockers! Need Help ASAP
    By nofriends46 in forum Wiring, Electrical and Installation Help
    Last Post: 05-19-2002, 03:20 PM
Tags for this Thread
