Page 2 of 2 FirstFirst 1 2
Results 16 to 17 of 17
Reload Thread: Werid problem I can't figure out..
  1. #16
    mlstrass's Avatar
    mlstrass is offline Shaggy DOA
    Jul 2006
    Illinois
    10,755
    5 Post(s)
    1262 Post(s)
    Re: Werid problem I can't figure out..
    Quote Originally Posted by IonRL205 View Post
    The problem I'm having is it seems like my system doesn't play loud around tuning, but plays loud for the low notes and the high notes, but not in between..some info on what I"m running.
    Two kicker solo x 12s
    APSM 1500 (lulz)
    6.2 cubes @ 34 hz
    It plays 30 hz and below loud, and like 43 Hz and up loud, but in between just doesn't have much output, just not sure why there is a dead spot there.
    The subs are in the back seat area with subs and port facing front of the car. It isn't completey sealed off from the trunk, which could be a cause of the issue. The amp could just be a total pos and be the reason for this, but I don't have another amp to test it with. Only other thing I can think of is it could be a signal/RCA issue.
    Anybody else had this problem/seen this problem?
    Probably the issue right there. No diff then doing a wall and not sealing it off. Some vehicles it makes a BIG diff. Seal it off and see what happens.
  2. #17
    Beatin''s Avatar
    Beatin' is offline CarAudio.com Elite
    Nov 2012
    MI
    997
    574 Post(s)
    I believe "dead spots" are usually the result of poor subwoofer placement, car accoustics, and incorrect box volume.
    My system still has the same dead spot after two amps and three firing positions were used.
  1. Can't figure out the source of my problem
    By Beastums in forum Speakers
    Last Post: 12-14-2012, 11:53 AM
  2. Amp problem and can't figure it out
    By Robahr24 in forum Amplifiers
    Last Post: 10-24-2009, 07:32 PM
  3. Can't figure out the wire for RE Bass Control Knob..
    By LinxuS in forum General Discussion
    Last Post: 05-26-2008, 05:24 AM
  4. Replies: 6
    Last Post: 02-25-2007, 01:31 PM
  5. Can't figure out port tuning
    By nismos14 in forum Enclosure Design & Construction Help
    Last Post: 12-15-2006, 09:56 PM
