+ Reply to Thread
Page 2 of 2 FirstFirst 1 2
Results 16 to 18 of 18
Reload Thread: Few ohm Q's
  1. #16
    Photonfanatic's Avatar
    Photonfanatic is offline Member
    Jan 2013
    TX
    53
    Re: Few ohm Q's
    Hmm. So maybe I should run the little SA-8 at 4 ohm then? That would dramatically lower the power being sent to it and would take all the risk out. Its starting to sound like my 1200 watts RMS is just going to be too much. What wattage would I be running to the sub at 4 ohm? Its a dual 4 ohm sub. So lets see, 1200 watts RMS squared, is 34.7, times the impedance which is... crap what is the impedance? Is that on the amp or the sub?
  2. #17
    NASTY08IMPALA's Avatar
    NASTY08IMPALA is online now CarAudio.com Veteran
    Aug 2012
    LOUISVILLE, KENTUCKY
    2,976
    31 Post(s)
    Re: Few ohm Q's
    Well that sub is a d4 so u can only wire at 2 or 8 ohms ...not 4
  3. #18
    Aug 2012
    2,976
    31 Post(s)
    Re: Few ohm Q's
    Quote Originally Posted by Photonfanatic View Post
    and u wont be sending 1200 watts to the sub thats the 1 ohm rating u will be running at 2 ohms ..which will be around 6-700 @2ohms
+ Reply to Thread
  1. ECLIPSE OHMS
    By UNTOUCHABLEM3 in forum General Discussion
    Last Post: 09-29-2010, 03:01 PM
  2. amps that can handle .5 ohms?
    By Budnik in forum General Discussion
    Last Post: 01-06-2002, 03:45 AM
  3. Okay, new to the biz, a few questions....
    By rand in forum General Discussion
    Last Post: 12-28-2001, 12:36 AM
  4. Ohm to watt ratio
    By jrmax in forum Amplifiers
    Last Post: 12-15-2001, 07:58 PM
  5. ohms
    By <don248> in forum General Discussion
    Last Post: 12-13-2001, 04:13 PM
