+ Reply to Thread
Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 31 to 45 of 50
Reload Thread: What is a light weight sub that can handle a good chunk of power?
  1. #31
    Gbob2003's Avatar
    Gbob2003 is online now Great Odens Raven
    Jun 2011
    Around, MN
    27
    954
    1 Post(s)
    Re: What is a light weight sub that can handle a good chunk of power?
    Quote Originally Posted by RicksI30 View Post
    That's bad *** but I just can't see why you would add a heavy *** battery, 0 gauge, an HO alt and then skimp over 30 extra lbs on the sub.
    Well i might not even add the battery if i can find a more efficient amp. I dont want to if i dont have to. Cuz if i find a more efficient amp then the 270 should hold it fairly well
    2003 Mustang,
    2 skar vvx-10's, 1 sundown saz-1500, 2.4^3ft @34hz
    Knu wiring, AGM batt
  2. #32
    murph's Avatar
    murph is offline Low for Life
    Sep 2011
    Richmond,VA
    3,485
    89 Post(s)
    Quote Originally Posted by pro-rabbit View Post
    What do you plan on tuning to with a 6"' port with his limited space? I like the sub choice though.
    Just read his space req's. He could have the areo go through the ski hole opening and tune it to 34hz. Or he could go with two 3 inch areo's and put them in roughly a 2.5-2.6 cubic foot box with each one around 13inches long.
    Hu: kenwood kdc-x995
    Sub: Boston acoustics G5 12 in a quasi 6th order
    Amp: Eclipse Xa5000
    Front Speakers: Eclipse sc6500
    HIT UP FOR BASS ---> http://www.youtube.com/user/BassWithMurph?feature=mhee
  3. #33
    TheUnderFighter's Avatar
    TheUnderFighter is offline Beer Addict
    Mar 2011
    Murrieta, California, (SoCal)
    22
    3,405
    28 Post(s)
    ^ that.... it all seems very silly. You're going to have to compromise somewhere bud. Be it with 40lbs for a bigger sub..... or a MARGINALLY quieter set-up would save you at least a hundred pounds. Doing something like I suggested would mean you wouldn't need that HO alt (sucks performance), and you wouldn't need an extra battery (saves at least 60lbs). And you could use a lighter, and smaller amp (saves weight). And likely a little smaller box.
    Or you could get the sub that Tj linked for a measly $3,000. And then add weight and suck performance with your HO alt. And add weight with the battery.
    An Icon on 1500w will still get decently loud. Box, sub, and amp and you're probably only up 100lbs.
    2009 Hyundai Elantra - Budget Sound in Progress
    HU- Kenwood eXcelon KDC-X994
    Fronts- Crescendo MP6 mids, Vifa Ring Radiator tweets on Arc KS300.4
    Subs- Single SA-10 on Mmats 2000.1 @ 1ohm
    Misc- 1/0 CCA from AT, Big 3 in Stinger HPM, and AT 60 mil deadener
    Bought from: Inferno333, select127, treesive, Kangaroux, DonH
    Sold to: coolest user, Psychodrama, MidgetClown, mr.tigger, av83
  4. #34
    Gbob2003's Avatar
    Jun 2011
    Around, MN
    27
    954
    1 Post(s)
    Quote Originally Posted by TheUnderFighter View Post
    Or you could get the sub that Tj linked for a measly $3,000. And then add weight and **** performance with your HO alt. And add weight with the battery.
    How would would the Icon compare vs the death penalty. Ive never heard any of the ssa lines. But I may just listen to you on the smaller equip parts.
    2003 Mustang,
  5. #35
    Gbob2003's Avatar
    Jun 2011
    Around, MN
    27
    954
    1 Post(s)
    2003 Mustang,
  6. #36
    RicksI30's Avatar
    RicksI30 is online now CarAudio.com Elite
    May 2011
    Tucson, Az
    24
    545
    Quote Originally Posted by Gbob2003 View Post
    SSA makes very great subs and has awesome customer service. The ICON can get plenty loud and sound great doing it. I would very strongly suggest that you run a bit less power and skip the battery.
    Head unit: Kenwood Excelon KDC-X996
    Front stage: Alpine Type X PRO mids Vifa Neo 1" silk tweeters
    Front stage amp: PPI Bk800.4
    Subs: SSA XCON 12's in 4.5 cubes tuned to 34hz
    Sub amp: PPI Bk1300.1
    Sound Deadening: Second Skin Damplifier Pro, Spectrum, and Sludge
    Team SSA
  7. #37
    RicksI30's Avatar
    May 2011
    Tucson, Az
    24
    545
    SSA makes very great subs and has awesome customer service. The ICON can get plenty loud and sound great doing it. I would very strongly suggest that you run a bit less power and skip the battery, and maybe even the alternator.
    Team SSA
  8. #38
    Gbob2003's Avatar
    Jun 2011
    Around, MN
    27
    954
    1 Post(s)
    How much do one of those Mmats 1500s weigh?
    2003 Mustang,
  9. #39
    mylows10's Avatar
    mylows10 is online now WEST COAST DC & PHD REP mylows10 is a Supporting Member of the forum!
    mylows10 is a Supporting Vendor of the forum!
    Sep 2009
    monterey , ca
    13,046
    360 Post(s)
    Your a rep for DC yeah?
    yes i am
    pioneer avhp 4100 dvd, 2 dc lvl 4 10's custom built by Thor's hammer , ab vfl 4480
    ab vfl 150.4 ,2 pc 2150 ,
    cdt 6.5 es 61 im mids,cdt es 010 tweets with es 200 us x overs stinger hpm o gauge wires
    NOR CAL DB DRAG JUDGE
    http://www.dcsoundlab.com
  10. #40
    I Like Waffle's Avatar
    I Like Waffle is offline Be Swangin'
    Sep 2008
    North Carolina
    24
    4,199
    25 Post(s)
    Whats done to the car performance wise? The car is slow anyway, might as well weigh it down more
    Im better than you.
  11. #41
    mclerico83's Avatar
    mclerico83 is offline CarAudio.com Veteran
    Oct 2009
    tampa
    6,098
    12 Post(s)
    mmats amps are going to be your best options on light weight and small amps
    N212 - Fi Car Audio Store
    if money isnt an issue get a fi n with neo magnet 45 pount sub can handle 2500rms with ease
    the icon is an amazing sub but i would order the people who makes the icon over the icon
    Q12 - Fi Car Audio Store
    fi q with cooling hand build in the us and us machines steal motors can handle 2000rms easy for under 350 but not the beast the fi n is lol.
  12. #42
    mclerico83's Avatar
    Oct 2009
    tampa
    6,098
    12 Post(s)
    on 2000rms get a batcap for the rear great small batteries
    Xstatic Batcap Model 2000 Electric Car Battery 2000 Amp Battery | eBay
    only 34 pounds or
    BatCap Power Pack
    the powerpac that weighs only 10 pounds lol
    http://infiniteelectronix.com/batcap...capacitor.aspx
  13. #43
    Mar 2011
    22
    3,405
    28 Post(s)
    Let's put it this way.... I can easily hold my Mmats 2000.1 with my thumb and forefinger... And it fits in a medium flat-rate box. And again, unrivaled efficiency means no need for any electrical upgrades aside from the Big 3. I wouldn't be able to compare the SSA Icon against the IA since I've ran neither. I just know the SSA lines has a great balance between cleanliness and getting loud, as well as remaining decently efficient, and having a great build quality and competitive price-point.
  14. #44
    Gbob2003's Avatar
    Jun 2011
    Around, MN
    27
    954
    1 Post(s)
    ****, that is pretty light then lol well Ill look into them then. Thanks for the advice.
    2003 Mustang,
  15. #45
    T.I.K.'s Avatar
    T.I.K. is offline F*ck it, we'll do it live
    Oct 2010
    Charleston, SC
    20
    4,019
    24 Post(s)
    Doesn't want to sacrifice performance... but is planning on running an H/O alt... what?
    ICON + MMATS gets my stamp of approval.
    Get taken down to funky town on MobileAudioForum.com.
+ Reply to Thread
  1. Is there a sub that can handle 6000-7500 watts daily?
    By mgcauctions09 in forum Subwoofers
    Last Post: 11-20-2009, 06:45 PM
  2. whats a 12" sub that can handle 2000 rms daily?
    By bassknocker23 in forum Subwoofers
    Last Post: 04-05-2009, 09:01 PM
  3. what is the best 12'' sub you can buy,price range?
    By lask48180 in forum Subwoofers
    Last Post: 12-19-2008, 04:55 PM
  4. Replies: 53
    Last Post: 09-03-2006, 12:32 AM
  5. Need one 12' sub that can handle...
    By DeadOnArrival in forum Subwoofers
    Last Post: 07-29-2003, 08:02 PM
