+ Reply to Thread
Page 3 of 3 FirstFirst 1 2 3
Results 31 to 40 of 40
Reload Thread: Mp3 or Cd
  1. #31
    Roth's Avatar
    Roth is offline Member
    Nov 2012
    San Antonio, TX
    32
    Re: Mp3 or Cd
    Quote Originally Posted by SourDeez View Post
    Since when are cd's not 320kpbs?
    320 kbit/s is an MP3, compressed audio. Audio stored on CD's is not compressed and has a bit rate of 1,411.2 kbit/s. 320 is the highest standardized bit rate for MP3's though, so it's often equated to being the same as CD quality.
    I remember back in the Napster days when people claimed 128 kbit/s was CD quality, that's quite amusing by today's standards.
    HU: Pioneer AVH-P8400BH
    DSP: JBL MS-8
    Front: HAT Unity
    Sub: JL 10W6v3
    Amp: JL HD900/5
    References:
    Bought from: Iosias
  2. #32
    SourDeez's Avatar
    SourDeez is offline CarAudio.com Veteran
    Apr 2007
    Fuqy u
    4,134
    62 Post(s)
    Re: Mp3 or Cd
    Quote Originally Posted by darron016 View Post
    I only have an AUX port so how would i connect my IPOD through USB?
    Also if I use the USB my songs will still be 128 so how would it make a difference?
    Get a headunit that has usb
    And because aux is analog and usb is digital
    Headunit - Stock cassette player - Pioneer P9400
    Front Stage - Pyle 8 inch subs (1000 watt peak!!) - Polk DB6.5 (about to be CDT 6.5s)
    Rear stage - Deleted (stolen) - Deleted
    Sub stage - custom built 15 inch sony xplod (5k watt peak!!!) (huge box) - Two SA12's built by Corey
    Sub amp - Pyle 8000w peak!! (spl edition) - AQ2200
    Electircal - 35 amp alt from ford festiva upgrade, stolen battery, 28 gauge solder coil for my cable - Dual D34 Yellows, 1/0 trystar OFC, 135amp alt
  3. #33
    darron016's Avatar
    darron016 is offline Senior VIP Member
    Dec 2012
    minneapolis, mn
    384
    14 Post(s)
    Re: Mp3 or Cd
    Can I get a new deck, as in just the outside piece.. Or do I need a whole new radio?
    Don't want to re wire my remote wire.
  4. #34
    Roth's Avatar
    Nov 2012
    San Antonio, TX
    32
    Re: Mp3 or Cd
    You can't with your current head unit. As mentioned in this thread, you're bypassing the iPod's internal DAC when you're connecting through USB and using the DAC in your head unit.
    Even if you used a USB connection, your songs would still sound pretty terrible since they're encoded in 128. The solution? Download better rips of the music. Try and go for either V0 or V2 variable bit rates. V0 is essentially the same quality as a 320 rip, but it's a smaller file size.
    DSP: JBL MS-8
    Front: HAT Unity
    Sub: JL 10W6v3
    Amp: JL HD900/5
    References:
    Bought from: Iosias
  5. #35
    Alrojoca's Avatar
    Alrojoca is offline Senior VIP Member
    Jan 2012
    USA West Coast
    189
    Re: Mp3 or Cd
    Did u read post #25 ?
    Quote Originally Posted by Alrojoca View Post
    Exactly, funny how we try to solve a problem and overlooked the main sources, like I said before, USB will give you the best sound and digital integration and sound. 2 issues, 128 k stereo files and headphone jack output to aux. if you need to use the aux port, buy one of these iPod iPhone Dock Connector Male to 3 5mm Plug Cable Mm | eBay it will give you much cleaner and better sound than the headphone jack.
    That cable is the closest to USB sq you can get! Also on your iTunes uncheck the option to convert all files to 128k by clicking on the iPod itself to check the settings, maybe your files are apple lossless but that takes 4 times the memory of a 256k file. It's good to check the rate not only on your iPod but also on the music library also.
  6. #36
    darron016's Avatar
    Dec 2012
    minneapolis, mn
    384
    14 Post(s)
    Re: Mp3 or Cd
    So it probably isn't worth buying a new HU usb adapter etc... Since all my songs are 128 and it won't make a HUGE difference anyways, right?
  7. #37
    SourDeez's Avatar
    Apr 2007
    Fuqy u
    4,134
    62 Post(s)
    Re: Mp3 or Cd
    If its the same brand, you should be able to swap out the whole deck and plug the harness right back in.
  8. #38
    darron016's Avatar
    Dec 2012
    minneapolis, mn
    384
    14 Post(s)
    Re: Mp3 or Cd
    My songs sounds clean already, it is just some songs are different quality than the others, and it is hard to compensate for that between songs.. Turning up volume etc.
    ---------- Post added at 11:37 AM ---------- Previous post was at 11:36 AM ----------
    I have a sony , idk if there anygood or not.
  9. #39
    SourDeez's Avatar
    Apr 2007
    Fuqy u
    4,134
    62 Post(s)
    Re: Mp3 or Cd
    Those songs that sound bad, you're just gonna have to live with that. Something got messed up along the way, converting or moving the song.
    Sony.. wouldnt be my first choice but its whatev should work fine
  10. #40
    Alrojoca's Avatar
    Jan 2012
    USA West Coast
    189
    Re: Mp3 or Cd
    I also mentioned that some recordings are bad and some music just will not sound better sometimes worse in a car set up, unless you know someone with a better system that have those songs and you can hear improvement, there is nothing you can do to make them better.
+ Reply to Thread
  1. Should I rip my CD's to MP3 or WMA?
    By verb1999 in forum General Discussion
    Last Post: 10-05-2008, 11:03 PM
  2. Just want opinion on Mp3 or audio cds
    By BUMP MY RIDE in forum General Discussion
    Last Post: 12-18-2005, 11:09 AM
  3. mp3 or CD, CAN YOU TELL?
    By don_Davi in forum General Discussion
    Last Post: 10-29-2002, 12:33 PM
  4. Question about mp3s and CD Changers
    By Josh03 in forum General Discussion
    Last Post: 04-21-2002, 03:27 AM
  5. Mp3/md/cd
    By kidren in forum General Discussion
    Last Post: 02-25-2002, 03:09 AM
