Page 8 of 14 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 LastLast
Results 106 to 120 of 204
Reload Thread: street max build on the CHEAP!!!
  1. #106
    n8skow's Avatar
    n8skow is offline CarAudio.com Elite
    May 2009
    Kansas City, MO
    1,291
    263 Post(s)
    Re: street max build on the CHEAP!!!
    What frequency are you playing?
    On 2k - should be doing a much higher score from a wall...
    Do the coils check out okay on those woofers?
    Quote Originally Posted by akadj View Post
    well I ran it a couple times now that the box is finished. but I cant play it much since I dont have the battery and my volts are seriously dropping and it cut out once and shutdown the two amps.. and I dont want to cook them.. here's the clamped numbers and voltage. ..
    A.C. amperage 20.51
    A.C. voltage 102.4
    D.C. voltage (starting 13.1 - dropping 11.2)
    Impedance (starting 1.9 ohms - rising 4.99
    Total RMS output 2100 watts
    I have to try a few things to lower impedance rise but im seriously surprised this amp is putting out 2100 watts at 4.99 ohms strapped.. and surprised it's doing 147.5 db legal with 2100 watts.. it only gained .5 or so db sealing off the wall but it could be more and im just having voltage issues restricting me from seeing a higher output (due to testing it off a battery sitting on the garage floor)
    anyways the wife is going out of town for the week.. and it just happens she's going be in the same city the xs power 3100 is! !
    once I get that the system is completed .. well the street max cheap build anyways. . then I will be putting 10 the power with the stetsom 7k2d amps! !
    National Finals
    Oct. 28-29th, 2017 - Sedalia Missouri
  2. #107
    akadj's Avatar
    akadj is offline Senior VIP Member
    Apr 2004
    Edmonton Alberta CANADA
    40
    458
    161 Post(s)
    Quote Originally Posted by n8skow View Post
    what numbers should i be looking for with 2k clamped.. i was thinking 152
    i seriously didnt even get a chance to burp it more then 5 - 6 times. voltage drop was so severe when the amps shut down i knew i was playing with fire and risk smoking them so im waiting till friday when i get my new battery and alternator hooked up.
    but.. when i did burp it i tried 60hz cuz thats the max in this class and got 147.5 db .. then i went to 50hz and was going to work my way up but i didnt even get 3 seconds worth and everything shutdown.
    i have a few things i want to try out so bad but i gotta wait for this battery.. and i leave to go out of town for work again on monday
  3. #108
    n8skow's Avatar
    May 2009
    Kansas City, MO
    1,291
    263 Post(s)
    What is it tuned to on paper? Any idea what frequency the car likes?
    Burp box, on 2k clamped - I'd expect a 151-153 with a more traditional SPL wall design (woofers on passenger side, port on driver side) with the vehicle sealed up, mic on dash.
    Music tuning - probably 2-3 db under that.
    With the port up top, probably subtract 1-1.5 db from these numbers though (149.5ish with your current setup).
    Getting your electrical situation squared away, you'll probably see db or so gain without changing anything else. Then it's just working on your box and tuning from there =)
    National Finals
  4. #109
    akadj's Avatar
    Apr 2004
    40
    458
    161 Post(s)
    i did run through all the frequency tracks and unfortunately the lowest impedance was at 47/49 hz with a spl peak at 52/53 hz... so ive got to try and subtract some internal volume and then once ive taken as much as possible im going to shorten the port and try to raise the tuning closer to 60hz because thats my limit in this class.
  5. #110
    n8skow's Avatar
    May 2009
    Kansas City, MO
    1,291
    263 Post(s)
    Do you know what your box is actually tuned to though? Trying to visualize here the gap between your tuning and actual peak frequency.
    Get that electrical solid first - or all your testing is gonna be frustrating with inconsistencies.
    It will be a bit counter-intuitive if your not used to clamping power - but you should see a point where your score is increasing as you go up a frequency at a time, but your power (amperage) is decreasing. At some point, your amperage will reverse stop dropping, and start climbing as you get higher and higher - that area where the amperage was lowest is where your box is wanting to play. The trick is to get that frequency close to what the car likes.
    National Finals
  6. #111
    akadj's Avatar
    Apr 2004
    40
    458
    161 Post(s)
    Do you know what your box is actually tuned to though?.....
    ...that area where the amperage was lowest is where your box is wanting to play. The trick is to get that frequency close to what the car likes.
    ya the box is tuned to 47/49 hz.
    I'm trying to match the box frequency to what the car likes.. I had 3 peaks in the car.. the first one at 52hz second at 61hz third at 72hz.. I would imagine the first peak at 52 is only because the box is tuned so low.. the 72 seams right on track with relationship of drivers to the mic / the speed of sound and quarter wave equation
  7. #112
    n8skow's Avatar
    May 2009
    Kansas City, MO
    1,291
    263 Post(s)
    What organization are you competing in?
    That 60hz cap is gonna hurt a lot of your car likes 72hz...
    National Finals
  8. #113
    akadj's Avatar
    Apr 2004
    40
    458
    161 Post(s)
    That 60hz caps is gonna hurt a lot of your car likes 72hz...
    Db Drag Racing Street Max.. actually all street classes in the db drag racing are 60hz & under with a max of 15 volts... super street and high classes are 80hz & under with a max of 18 volts..
  9. #114
    sbarber82's Avatar
    sbarber82 is offline CarAudio.com Elite
    Dec 2012
    Vegas baby
    35
    520
    162 Post(s)
    updates?
    Ride:2009 Silverado Crew Cab
    H/U: Pioneer avh-p4400bh
    Amps: Ampere Audio 3800.1 Ampere Audio 125.4
    Subs: 2 Tantric HDD 15's
    Enclosure: 4th Order Blow Through
    Mids/Highs: Tantric HD
    Singer 320 Hairpin 6 phase
  10. #115
    akadj's Avatar
    Apr 2004
    40
    458
    161 Post(s)
    Quote Originally Posted by sbarber82 View Post
    updates?
    I was tweaking it a bit.. got up to 148.. still not happy.
    Right now im out of town working again but next weekend im going to be cutting 8" of port length off and adding 100 square inch of area.
  11. #116
    akadj's Avatar
    Apr 2004
    40
    458
    161 Post(s)
    UPDATES! !
    I've started on removing the port and adding an additional 100 square inches!!
  12. #117
    akadj's Avatar
    Apr 2004
    40
    458
    161 Post(s)
  13. #118
    akadj's Avatar
    Apr 2004
    40
    458
    161 Post(s)
    I tested it the way it was in the last picture just to see what my max frequency was with zero port length and to get an idea of how long of a port to add..
    73 hz was the peak slp which is way to high for this class so im gonna try adding 7.5" of port length and see if i can get back to 60hz
    I went down 3 db at 60 hz but went up 3 db at 73 hz the way it is now
  14. Likes n8skow liked this post
  15. #119
    akadj's Avatar
    Apr 2004
    40
    458
    161 Post(s)
    Added 7.5" inch of port and my peak is at 68hz.. gonna do a few more mods over the next few weeks
  16. #120
    sbarber82's Avatar
    Dec 2012
    Vegas baby
    35
    520
    162 Post(s)
    Whats new?
  1. Door Panels on the Cheap - Pics
    By mlstrass in forum General Discussion
    Last Post: 07-08-2007, 07:41 AM
  2. Sub/Amp Combination on the cheap
    By Lynx331 in forum Subwoofers
    Last Post: 11-19-2003, 08:15 PM
