+ Reply to Thread
Results 1 to 7 of 7
Reload Thread: hopefully someone has an easy fix for me
    campbell8402's Avatar
    campbell8402 is offline Junior Member
    Nov 2012
    south carolina
    27
    i am running 4 speakers and a sub off one 4 channel amp. the speakers are where im having my issue.....
    my amp specs say 160x4 at 20hms
    so i took a set of 4 ohm 6x9s i had in boxes and put them in my hatch and have a set of 6.5 components in the front. i wired the two rights and two lefts together so it would be a 2 ohm load
    now my problem is the rears are 45w rms and the fronts are 80w rms so with my amp at about half gain my rears overpower my fronts by a alot
    is there anything i can put in line with the 6x9s to knock down the wattage going to them but yet retain the wattage to the fronts?
    OmegaBunny's Avatar
    OmegaBunny is offline Moderator
    Oct 2007
    Keyser, West Virginia, United States
    2,654
    60 Post(s)
    Re: hopefully someone has an easy fix for me
    No, not that I know of unless you have a way to increase the resistance going to the rear speakers.
    There may be an easier way so I will let someone else chime in but for me the easiest fix and best solution would be to get a separate amp for the sub
    2007 Black Diamond FJ Cruiser with Box built by Pro-Rabbit
    H/U Kenwood DNX6960
    Sub: 1-18" Zv3 with NS coils and cone Sub Amp: Mmats 2100.2
    Front Stage: Hybrid Audio L6 mids, SEAS Neo Tweets, SAX 100.4, RF 3sixty.2
    Bought From: Rio, davidtemple, Bassin Buick, Pro-Rabbit, Kangaroux, KyleBechtold Traded With: WhiteDragon551 Sold To: jdmeklove, Kpozr2, 97accordalpine
    Nov 2012
    south carolina
    27
    unfortunately thats not the greatest option money is tight....... i might ditch the 6x9s and just stick to the front stage and sub only
    blobb454's Avatar
    blobb454 is offline CarAudio.com Elite
    Nov 2012
    LANSING MI
    983
    6 Post(s)
    Did I read right, you did left from with left rear? Right front right rear?
    Quote Originally Posted by kpetree View Post
    I feel like you're a waste of your mothers stretch marks, better luck finding your gf next season. Fck off, post dump somewhere else.
    wickedwitt's Avatar
    wickedwitt is offline CarAudio.com Veteran
    May 2010
    Abilene, TX
    2,933
    34 Post(s)
    Without breaking up the channel, increasing resistance in the more efficient speakers is the only option.
    Stupid Loud.
    mylows10's Avatar
    mylows10 is online now WEST COAST DC & PHD REP mylows10 is a Supporting Member of the forum!
    mylows10 is a Supporting Vendor of the forum!
    Sep 2009
    monterey , ca
    13,120
    364 Post(s)
    just run the 6x9s off the deck power ,fixed
    pioneer avhp 4100 dvd, 2 dc lvl 4 10's custom built by Thor's hammer , ab vfl 4480
    ab vfl 150.4 ,2 pc 2150 ,
    cdt 6.5 es 61 im mids,cdt es 010 tweets with es 200 us x overs stinger hpm o gauge wires
    NOR CAL DB DRAG JUDGE
    http://www.dcsoundlab.com
    dragonrage's Avatar
    dragonrage is offline CarAudio.com Elite
    Feb 2007
    Massachusetts
    572
    Rears aren't necessary without rear passengers. If you want them anyway, run them from the deck. Also, unless you have passengers listening to them, cut off/down the treble from your rear speakers from 10kHz down (even lower might be helpful). Keep the volume of the rears as low as possible so they are only just audible. Most of the music should come from the front.
    Also keep in mind the more power you run, the more there's a tradeoff between output and low frequency extension. The more output you want, the higher you need the highpass filter on the speakers to be for them to be able to handle what you're asking. If you want to actually run that 160W to just about any front speaker, you will need to highpass at like 100+Hz, or you WILL be blowing speakers if your music has bass (and I don't mean bass test music only, either). With lower powers 60-80Hz should be attainable. Some people claim to be running 400w to their fronts. For those using ANY speaker in stock locations, that's BS - they may have an amp capable of 400w, but they have probably never even peaked over 100W to them. My Helix Dark Blue 4 at 60WRMS could fry my Rainbow Profi Kick 6.5" woofers EASILY highpassed at 80Hz. It could also do the same for the Dayton RS180-4s. Point of this paragraph: Be careful if you're trying to run that 160W to your fronts. Edit to note: I suppose it would probably be more like 80-100W at 4 ohms, but still, that can blow most speakers, so be careful.
    2009 Pontiac G8 GT - Selling/Trading soon...
    Ebay: ddfromma | Heatware feedback: ddfromma
+ Reply to Thread
  1. hopefully an easy fix?
    By pbnj22 in forum General Discussion
    Last Post: 08-19-2012, 11:50 PM
  2. Someone PLEASE tell me this is an easy fix!!!!!
    By stikystikyricky in forum Wiring, Electrical and Installation Help
    Last Post: 03-14-2010, 02:54 PM
  3. Can someone put together an audio system for me
    By toyopl in forum General Discussion
    Last Post: 05-29-2009, 10:48 PM
  4. is this an easy fix?
    By sw1ft in forum General Discussion
    Last Post: 06-19-2003, 09:02 AM
