Page 3 of 3 FirstFirst 1 2 3
Results 31 to 39 of 39
Reload Thread: Adding Low End to Stock System in BMW
  1. #31
    Lexicon740iL's Avatar
    Lexicon740iL is offline AGM FTW!
    Jan 2013
    Minneapolis, MN
    187
    76 Post(s)
    Re: Adding Low End to Stock System in BMW
    Next question guys.....
    The nakamichi has 4GA inputs
    I have a bunch of Stinger Pro 1/0 OFC laying around.
    If it were you would you run the 1/0 into the amp with a 0-4 Guage reducer? I already have a set of reducers.
    Or should I take the 1/0 into a fused distro w/ 4 Gauge out into the amp direct?
    One of the reasons I'm wondering is I don't think I can put the cover on if I use the 1/0 directly into the amp w/ reducers. If you look at the pic below they leave holes on both ends to run the wiring in so the cover can bolt on. I don't think I can get that 1/0 to bend 90 and mount up with the reducers if I put the cover on.....But then again do I really need to use the cover???
    What would you do?
    http://i.ebayimg.com/t/NAKAMICHI-PA-...EP+Q~~60_3.JPG
  2. #32
    neo_styles's Avatar
    neo_styles is offline AKA Pop Twidget
    Sep 2012
    WA
    32
    3,623
    1703 Post(s)
    Quote Originally Posted by Lexicon740iL View Post
    I'd go with a distro. Doesn't necessarily have to be fused, though. Learned that reducers weren't the be-all-end-all when they wouldn't even fit into my Rockford P8004. It's not as clean, but you can also trim down the 0ga to fit into the hole. Honestly, it's a lot easier just to use the distro.
    Spotify: http://open.spotify.com/user/neo_styles/playlist/6t9ru42j0wbEsuo4bXqXD8
  3. #33
    keep_hope_alive's Avatar
    keep_hope_alive is offline Acoustics Engineer keep_hope_alive is a Supporting Member of the forum!
    May 2007
    Quad Cities, IL
    7,082
    28
    48 Post(s)
    1502 Post(s)
    i would use a distro also. i agree it doesn't have to be fused if the amp has internal fuses for overload protection of the wire.
    got a question? shoot me a PM. Matthew 6:9-15 - YouTube Channel: https://www.youtube.com/channel/UCkYUo2EShW9lgtrfXiDvLNQ/videos
    2014 Accord build log: http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/608637-2014-accord-sport-sq-build-keep_hope_alive.html
    2001 Accord build log: http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/536049-2001-accord-ex-sedan-its-long.html
    My 1966 MGB: http://www.mgexp.com/journal/keephopealive
    Fix Photobucket Image Loading ------> https://addons.mozilla.org/en-US/firefox/addon/photobucket-fix/ <------
  4. #34
    Jan 2013
    Minneapolis, MN
    187
    76 Post(s)
    Quote Originally Posted by neo_styles View Post
    Quote Originally Posted by keep_hope_alive View Post
    So the next question is.......
    Do you guys see any benefit to using the 1/0 in my application. My amp is only 1200W RMS.
    Should I just run a standard inline fuse 4GA in and out from the Batt to the amp?
    Is there any point on going 1/0 from the batt. and ground point into fuse/distro then gauge it down to 4 for input into the amp?
    I guess I figured everyone is all about the big 3 and 0 Guage here.
    My SAV already has the big 3 stock.....It's 1/0 from the alt back to the starting battery in the trunk and 1/0 from battery ground to chassis.
    Is the 1/0 Overrkill for me with my 1200WRMS monoblock?
  5. #35
    May 2007
    Quad Cities, IL
    7,082
    28
    48 Post(s)
    1502 Post(s)
    run 1/0. lower voltage drop and better future flexibility.
  6. #36
    Jan 2013
    Minneapolis, MN
    187
    76 Post(s)
    So run the 1/0 from battery into an inline fuse and 4GA out of the fuse holder and into the amp for now. {Keeping in mind my starting battery is in the trunk less that 4ft. from the amp}
    Using a 1/0 in and 1/0 out fuse holder. So I can 4GA directly into the 4GA inputs of the Nakamichi for now.
    That way I can run swap in a larger amp Fuse and 1/0 out of the holder and into a distro/Larger Sub Amp if I decide to upgrade to run more amps in the future?
  7. #37
    Jan 2013
    Minneapolis, MN
    187
    76 Post(s)
    My enclosure arrived yesterday from Double07
    I'm very happy with the results. I snapped a few shots of my eD13aV.2 and it's new home.
    I'm loving the recessed mount with this 13"
    he did a great job with the custom logo
    and the Kerf is just plain secs
  8. #38
    bobozxsdoz's Avatar
    bobozxsdoz is offline Banned
    Feb 2013
    casr3edsd
    24
    Cá d? online M88 Mansion88 Betno1.info ·· Ch? 200k ^^
  9. #39
    May 2007
    Quad Cities, IL
    7,082
    28
    48 Post(s)
    1502 Post(s)
    Oh. If the distance is that short then 4awg is fine.
  1. Adding Low End to Stock BMW System
    By Lexicon740iL in forum Wiring, Electrical and Installation Help
    Last Post: 01-13-2013, 05:53 PM
  2. 1998 grand prix amp and sub added to stock system using high end output jacks.
    By mstauffer in forum Wiring, Electrical and Installation Help
    Last Post: 01-06-2011, 10:29 PM
  3. Adding more bass to stock system
    By 1997PAU in forum General Discussion
    Last Post: 08-04-2008, 03:28 PM
  4. need help hooking amp to stock radio in a 2001 grand am
    By needtoknow in forum Wiring, Electrical and Installation Help
    Last Post: 04-12-2004, 10:31 AM
  5. Howto Add Sub To Stock System
    By TooFastForYa in forum Wiring, Electrical and Installation Help
    Last Post: 05-21-2003, 03:54 PM
