+ Reply to Thread
Page 7 of 12 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 LastLast
Results 91 to 105 of 175
Reload Thread: Bass dosent wobble
  1. #91
    darron016's Avatar
    darron016 is offline Senior VIP Member
    Dec 2012
    minneapolis, mn
    384
    14 Post(s)
    Re: Bass dosent wobble
    When i turn it to the 200 top left, at first it was at 2.0 when 0 gain. As I turned the gain up to full blast. The reading was 5.0
    Than it started going negative, than it started to read 0 no matter what, that I turned it off than turned it on. It got up to about 15.2. Now it is 0 out again.
    Lpf is at 80h,
    i tried 50hz tune got nothing, turned to 60 hz tune it made a little difference in the DMM.
  2. #92
    NASTY08IMPALA's Avatar
    NASTY08IMPALA is online now CarAudio.com Veteran
    Aug 2012
    LOUISVILLE, KENTUCKY
    3,108
    32 Post(s)
    Somethin is clearly wrong here
  3. #93
    jungstah's Avatar
    jungstah is offline Senior VIP Member
    May 2012
    san francisco
    278
    2 Post(s)
    where are your probes plugged into?
    Pioneer AVH-P2400BT
    Stock Pioneer 4" components
    Hifonics Brutus BRZ1700.1D
    Two SA-12's
    cruddy prefab ported box----new box otw
  4. #94
    darron016's Avatar
    Dec 2012
    minneapolis, mn
    384
    14 Post(s)
    The amp is bridged, so I plugged the positive dmm wire to the positive output where my speaker wires were. Than I put the negative to the negative output on the amp. And screwed them down with the allan wrench
  5. #95
    Aug 2012
    3,108
    32 Post(s)
    U need both probes in speaker outputs ..u mean u have black probe in neg on amp or neg speaker imput
  6. #96
    darron016's Avatar
    Dec 2012
    minneapolis, mn
    384
    14 Post(s)
    The dmm is connected straight to the amp.. Negative probe to negative out put. Pos to pos.. Basically I disconnected the speaker wire from my sub to my amp and left the wire still connected to the SUB terminals. Than put the probes in the same spots where the speaker wire was leaving from the amp
  7. #97
    Aug 2012
    3,108
    32 Post(s)
    Is your lpf turned up to accept the 60htz tone
  8. #98
    Falcons's Avatar
    Falcons is offline that **** i dont like
    Jan 2011
    Albion, New York, United States
    5,087
    18 Post(s)
    His low pass is at 80
    Things to look forward to:
    (2) 10" or 12" imperium audio designs subs
    set of PHD MF 6.5" comps
    Completely seal off and deaden my doors
    aquire a 2k amp
    aquire a 2 channel amp for front stage
  9. #99
    darron016's Avatar
    Dec 2012
    minneapolis, mn
    384
    14 Post(s)
    Lpf is 80 hz, just went out there to try again and took this pic of the set up (building a rack soon)
    I turned the gain up all the way on the 200 setting and it for once. Stayed at a 20.6 and didnt move (like it did all the other times) Im looking for 34.5 , if bridged the amp is 600 RMS so 600*2 = 1200
    SQ is about 34.5 .. So each sub is getting 300 rms.. Or should I do 300*2 =600 SQ = 24.4
    When I put the gain at half way. It shoots down to a 6.8
  10. #100
    Falcons's Avatar
    Jan 2011
    5,087
    18 Post(s)
    I'm thinking something isn't turned up that should be. Do you have a sub volume on your head unit that increases by. Decibels? If so, turn that all the way up
    aquire a 2k amp
  11. #101
    Jan 2013
    OKC
    buy skar, problem solved. then your bass will wobble.
  12. Dislikes slim2fattycake, its10v1, RicksI30 disliked this post
  13. #102
    darron016's Avatar
    Dec 2012
    minneapolis, mn
    384
    14 Post(s)
    Quote Originally Posted by falcons03079313 View Post
    If you are talking about the SUB option, I do have that. But when my subs are on, I don't use the sub option because I thought it was the same as bass boost and people say not to use bass boost?
    Will turning the sub option on the HU up, make the volts from my amp turn up as well?
  14. #103
    jungstah's Avatar
    May 2012
    san francisco
    278
    2 Post(s)
    wait, you keep looking for 34.5, what ohm load? 34.5 @ 1 ohm is 1200w, does that amp even put out 1200?
    Pioneer AVH-P2400BT
    Two SA-12's
  15. #104
    Aug 2012
    3,108
    32 Post(s)
    I think ur looking for twice the voltage u should be ...turn sub output on deck all the way up this will let match ur output without cranking up the volume
  16. #105
    darron016's Avatar
    Dec 2012
    minneapolis, mn
    384
    14 Post(s)
    im looking for 2 ohms.. 600 RMS bridged. 600*2 =1200 SR = 34.5 but im not sure if I should do 600 *2 or 300*2 because each sub will see 300 RMS but together the amp is putting out 600RMS
+ Reply to Thread
  1. good bass songs to show off my system?
    By <dustint17> in forum General Discussion
    Last Post: 05-09-2010, 07:55 PM
  2. What are THEE King of Bass Subs?
    By <Matt> in forum Subwoofers
    Last Post: 09-16-2005, 02:26 PM
  3. I LOVE BASS>>> I LOVE IT, I LOVE IT
    By mrt1184 in forum Subwoofers
    Last Post: 12-15-2004, 08:47 PM
  4. Bass competition cd songs
    By 2002Mustang in forum General Discussion
    Last Post: 01-10-2002, 08:41 PM
  5. American Bass
    By Cadillac in forum Amplifiers
    Last Post: 12-21-2001, 11:33 AM
