+ Reply to Thread
Page 3 of 12 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 LastLast
Results 31 to 45 of 175
Reload Thread: Bass dosent wobble
  1. #31
    darron016's Avatar
    darron016 is offline Senior VIP Member
    Dec 2012
    minneapolis, mn
    384
    14 Post(s)
    Re: Bass dosent wobble
    Quote Originally Posted by falcons03079313 View Post
    clipping is when your amp is being pushed to hard, creating heat, which can blow your whole system up. and yes, you can get some pretty decent stuff if you build your own box man.
    is it possible to push my amp too hard when it is bridged at 600 rms so im gettin 300 per sub. And the gain is 70%, so how could I be pushing too hard? Is it the DB or any other option?
  2. Dislikes its10v1 disliked this post
  3. #32
    NASTY08IMPALA's Avatar
    NASTY08IMPALA is online now CarAudio.com Veteran
    Aug 2012
    LOUISVILLE, KENTUCKY
    2,981
    31 Post(s)
    Look around on here and buy a decent 1krms sub like a xfl hdc3 lots of others find a 1500 w amp like a used. saz1500 or sonethin along those lines..and u will quadruple or more the output u have now...and buikd a custom box ...the box makes the build
  4. #33
    darron016's Avatar
    Dec 2012
    minneapolis, mn
    384
    14 Post(s)
    Quote Originally Posted by NASTY08IMPALA View Post
    Gain isnt a volume knob its meant to match output volts from the deck if u exceed this u are clipping..unless u used a dd1 or dmm or oscope to set the gains u are most likely clipping
    I fugure if 300 RMS is the max. That means if the gain is 100% than it would be putting out full 300 RMS to each sub, and if my gain is 65% how could I be clipping? I thought clipping is when the gain is too high, and i set mine low just to make sure I dont blow anything.
  5. #34
    Falcons's Avatar
    Falcons is offline that **** i dont like
    Jan 2011
    Albion, New York, United States
    5,099
    17 Post(s)
    Quote Originally Posted by darron016 View Post
    i can almost guarentee you are clipping your system. in order to set the gains properly you need to use a dd1, an o-scope, or a dmm.
    Things to look forward to:
    (2) 10" or 12" imperium audio designs subs
    set of PHD MF 6.5" comps
    Completely seal off and deaden my doors
    aquire a 2k amp
    aquire a 2 channel amp for front stage
  6. Thanks its10v1 thanked for this post
    Likes its10v1 liked this post
  7. #35
    Aug 2012
    2,981
    31 Post(s)
    just bc u have it set to 70% doesnt mean anything ..like i said its not a volume knob u wana match the output of ur rcas from ur deck..and bridging a amp isnt helping ur problem
  8. Likes its10v1 liked this post
  9. #36
    Falcons's Avatar
    Jan 2011
    5,099
    17 Post(s)
    100% on the gain is not what your looking to do. the gain matches your head units voltage. any higher than that than you are sending a clipped signal which will blow your amp or subs.
    aquire a 2k amp
  10. #37
    darron016's Avatar
    Dec 2012
    minneapolis, mn
    384
    14 Post(s)
    Yes but after that, than I would need to do the big 3 and even a battery and alt upgrade...
    Quote Originally Posted by B2WJ4.7 View Post
    bro you gain only at 65% that means the amp is only puttin out 65% power.
    So therefor I can't be clipping, correct? I set my volume up to 30 on my HU and tuned everything on that volume.
    dont get upset bro. we all gotta start somewhere. hell i started with a 12" sony xplod sub. give us a budget you would be willing to work with and we will help you out
    If i junk everything i have now, my tops is 500$ And my uncle is in construction so I could get a perfect box built for a good price.
  11. #38
    RicksI30's Avatar
    RicksI30 is offline CarAudio.com Elite
    May 2011
    Tucson, Az
    24
    546
    100 percent gain does not mean 100 percent power. You can reach full power without moving the gain much at all, it all depends on the source unit.
    Head unit: Kenwood Excelon KDC-X996
    Front stage: Alpine Type X PRO mids Vifa Neo 1" silk tweeters
    Front stage amp: PPI Bk800.4
    Subs: SSA XCON 12's in 4.5 cubes tuned to 34hz
    Sub amp: PPI Bk1300.1
    Sound Deadening: Second Skin Damplifier Pro, Spectrum, and Sludge
    Team SSA
  12. #39
    Falcons's Avatar
    Jan 2011
    5,099
    17 Post(s)
    pm me man i got nothing going on, ill help you out 1 on 1
    aquire a 2k amp
  13. Likes BoomBoxStereo liked this post
  14. #40
    UnderFire's Avatar
    UnderFire is offline CarAudio.com Elite
    Apr 2011
    Dayton, OR, 97114
    1,750
    26 Post(s)
    Everybody's gotta start small. The box was most likely designed to be used with the sealed section, like I said before a bandpass is part sealed, part ported. I've never built or even owned one though, so I'm by no means an expert. Basically any sub set-up will sound loud at first, but you'll get used to the Kickers very quickly, they are really not that loud,
    You could probably get a new set-up pretty cheaply, a Single SA-15 in the proper box on that Treo @ 2 ohms would definitely slam harder than the comps. And if your local Craigslist is anything like mine, you could get most of the money back out of the comps on there.
    You do need to pick up a Digital Multimeter, it is an essential tool for setting up amps, and even having a proper set-up can't even prevent clipping, you've got to know what you're doing, base rules are never go up past 80% volume on the headunit, and set your amp's gain to slightly under the rated output there.
    Your sony headunit is definitely a problem too, don't cheap out on the headunit, it is the base of the system, I've had 500$ systems where 250$ of it was the headunit.
    97 4runner, 3RZ, 5 Speed
    Headunit: Pioneer DEH-P9800BT
    Mids: Lanzar 6m
    Tweets: Crescendo CCX
    Fronts Amp: Alpine PDX4.100
    Sub Amp:Hifonics BRZ1.1700D
    Substage: 18" SSA ZCON
    Electrical: 160 Amp Alt, Duralast Gold, C&D270FR, 2/0 Throughout
  15. Likes itsblown liked this post
  16. #41
    Aug 2012
    2,981
    31 Post(s)
    No ur amp puts out max power when the voltage is matched to the output of the amp..for example my hu ha 4v preouts and the gain on my amp to get max power. is only halfway up anything past that and im clipping
  17. #42
    splwj47's Avatar
    splwj47 is online now CarAudio.com Veteran
    Aug 2011
    Great White North
    24
    2,582
    29 Post(s)
    lol that gain is to match the voltage from you head unit. depending on the voltage you HU puts out will depend on where the gain is set. 70% gain you are clipping the subs. there is a stickied thread around here somewhere that runs you through the proper ways to set you gain. all you need is a digital multimeter. i would stop arguing that your gain is set low at 70% and are not clipping.
    2003 JEEP Grand Cherokee LTD
    HU- pioneer 80prs
    Front Stage- B2 ES 6.1I
    FS Amp- B2 Quattro
    Sub Amp-B2 Zero1
    Subs- Tantric HDD 12's
    box - 6^3 33hz
  18. #43
    splwj47's Avatar
    Aug 2011
    Great White North
    24
    2,582
    29 Post(s)
    also if you dont want to spend money on a new setup, get one of the designers on here to make a design for you for your subs. it will make a world of a difference. that box you have is a turd. if it was mine i would use it for firewood. do yourself a favor and take peoples advise.
    HU- pioneer 80prs
    FS Amp- B2 Quattro
    Sub Amp-B2 Zero1
    box - 6^3 33hz
  19. #44
    darron016's Avatar
    Dec 2012
    minneapolis, mn
    384
    14 Post(s)
    What does a clean bass and clipped bass sound like? Like what is the thing you look for to know? If you sat in my car and heard my subs you could be like, yes they are clipping.. So I know what to listen for tomorrow when i go in my car
    The amp has a input button high/low I think it is for the RCA?
    So basically I need a DMM and measure everything?
    Some people said you can do it all by ear, I turned the gain up to a point where it sounded like a good bang honestly.
  20. #45
    Falcons's Avatar
    Jan 2011
    5,099
    17 Post(s)
    like i said man shoot me a private message and ill tell you everything you need to know as far as setting your gains. to be honest, after you set everything up properly, you are not going to be happy with how quiet your subs are.
    aquire a 2k amp
+ Reply to Thread
  1. good bass songs to show off my system?
    By <dustint17> in forum General Discussion
    Last Post: 05-09-2010, 07:55 PM
  2. What are THEE King of Bass Subs?
    By <Matt> in forum Subwoofers
    Last Post: 09-16-2005, 02:26 PM
  3. I LOVE BASS>>> I LOVE IT, I LOVE IT
    By mrt1184 in forum Subwoofers
    Last Post: 12-15-2004, 08:47 PM
  4. Bass competition cd songs
    By 2002Mustang in forum General Discussion
    Last Post: 01-10-2002, 08:41 PM
  5. American Bass
    By Cadillac in forum Amplifiers
    Last Post: 12-21-2001, 11:33 AM
