Page 11 of 12 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 LastLast
Results 151 to 165 of 175
Reload Thread: Bass dosent wobble
  1. #151
    darron016's Avatar
    darron016 is offline Senior VIP Member
    Dec 2012
    minneapolis, mn
    392
    294 Post(s)
    Re: Bass dosent wobble
    Can you suggest a set up for about 3 - 400 $
  2. #152
    NASTY08IMPALA's Avatar
    NASTY08IMPALA is offline CarAudio.com Veteran
    Aug 2012
    LOUISVILLE, KENTUCKY
    6,131
    3 Post(s)
    2554 Post(s)
    American bass xfl dual2 185bucks auiopipe apsm1500 125 i think then build a nice box for it ..will be 10times louder than what u got ..i personally hate the audiopipe amps but for u they will rock ur car conpared to what u got bro
  3. #153
    darron016's Avatar
    Dec 2012
    minneapolis, mn
    392
    294 Post(s)
    Would that set up, need a big 3 upgrade?
  4. #154
    Aug 2012
    6,131
    3 Post(s)
    2554 Post(s)
    Yes
  5. #155
    Timmy13091's Avatar
    Timmy13091 is offline Team DC
    Apr 2012
    Chicago
    3,000
    1 Post(s)
    1286 Post(s)
    My 20 dollar 10" wobbles lmao all glued up
    ---------- Post added at 09:38 PM ---------- Previous post was at 09:37 PM ----------
    Check out this video on YouTube:<br/><br/>Budget glued up 10" in action - YouTube
  6. #156
    Falcons's Avatar
    Falcons is offline that **** i dont like
    Jan 2011
    Albion, New York, United States
    5,448
    1499 Post(s)
    The formula is square root of total watts times ohms
    People complained about my sig so I changed it.
  7. #157
    Falcons's Avatar
    Jan 2011
    5,448
    1499 Post(s)
    Quote Originally Posted by darron016 View Post
    Big three is the easiest thing ever bro. That's not a problem. But yeah go with what he just offered you. You'll be amazed
  8. #158
    UnderFire's Avatar
    UnderFire is offline CarAudio.com Veteran
    Apr 2011
    Dayton, OR, 97114
    2,096
    1 Post(s)
    542 Post(s)
    Quote Originally Posted by slim2fattycake View Post
    is it even rated at 2 ohm bridged or are you just telling him that? What amp is this?
    It's a Treo TSX75.2, more than capable of running @ 2 ohms, there is no actual rating though. I've never lied in any way, even in the post where he linked another thread, that seller stated he heard they were stable down to even 1 ohm. The Treo is more than capable of giving the comps rated power @ 2 ohms safely.
    97 4runner, 3RZ, 5 Speed
    Headunit: Pioneer DEH-P9800BT
    Mids: Pioneer ????
    Tweets: CDT DRT-25
    Fronts Amp: Memphis M-Class 4x50
    Sub Amp: Diamond D3 400.1
    Substage: 2x 12" Dayton HO's
    Electrical: 160 Amp Alt, Kinetik HC2400, Interstate DCM0100, 2/0 Throughout
  9. #159
    UnderFire's Avatar
    Apr 2011
    Dayton, OR, 97114
    2,096
    1 Post(s)
    542 Post(s)
    Well thanks for a lot of nothing underfire, just a waste of time and money $
    If these are the REAL specs,
    [email protected]
    [email protected]
    [email protected] ohm
    If I bridge it at 2 ohms, what should I look for on the DMM?
    I just want to listen to bass until I find someone off CL to buy some of this shyt
    Read the thread you posted.
    "Confirmed that these are 2 ohm stable and will do 600+ @2ohms"
    Exactly what I've been telling you. You do not even need that much power ATM, it's more than capable of what you need with the comps.
    Mids: Pioneer ????
    Tweets: CDT DRT-25
  10. #160
    darron016's Avatar
    Dec 2012
    minneapolis, mn
    392
    294 Post(s)
    Others are saying that my amp is a 300 rms amp,
    In the thread he said put bigger fuses in it
    ---------- Post added at 10:28 PM ---------- Previous post was at 10:27 PM ----------
    Is there anyway with the DMM I can somehow calculate how much watts or RMS my amp is putting out?
  11. #161
    UnderFire's Avatar
    Apr 2011
    Dayton, OR, 97114
    2,096
    1 Post(s)
    542 Post(s)
    It's 350 @ 4, I was trying to get specs off the top of my head, that's why I got it wrong, sorry about that. As you lower the Ohm load (Raise the resistance) the power output will go up, most 2 channels won't go past 4 ohms, but I assure you, the Treo can. You will not need bigger fuses if you set it to 300RMS, you will be drawing about the same amount of power still.
    if you wanted to crank it up as far is it could go @ 2 ohms, you may need to because it might be drawing more than 40 amps then.
    Calculating output of the amp accurately would require a better DMM and a Clamp meter, a good set-up would run 4-500$.
    Mids: Pioneer ????
    Tweets: CDT DRT-25
  12. #162
    darron016's Avatar
    Dec 2012
    minneapolis, mn
    392
    294 Post(s)
    Basically I cannot get a straight answer on what my amp is giving out RIGHT now @2ohms and therefor cannot set my gain right, meaning i cannot BASS
  13. #163
    UnderFire's Avatar
    Apr 2011
    Dayton, OR, 97114
    2,096
    1 Post(s)
    542 Post(s)
    You can set your gain right because you need 300W RMS for the pair of comps. Set it to 24.4V and you're good.
    Mids: Pioneer ????
    Tweets: CDT DRT-25
  14. #164
    Aug 2012
    6,131
    3 Post(s)
    2554 Post(s)
    In the thread he said put bigger fuses in itf
    Regardless of how much power the amp is u need to find 24.49 on dmm thats about all those can handle for long end of story..dont fvck around with putting different fuses in and running amp below its stability..or upgrade if u arent satisfied
  15. #165
    Aug 2012
    6,131
    3 Post(s)
    2554 Post(s)
    It doesnt matter man stop sweating it ..those subs can only handle 150 each
    ---------- Post added at 11:53 PM ---------- Previous post was at 11:52 PM ----------
    U dont need to know how much it puts out ..only what ur subs can handle
  1. good bass songs to show off my system?
    By <dustint17> in forum General Discussion
    Last Post: 05-09-2010, 07:55 PM
  2. What are THEE King of Bass Subs?
    By <Matt> in forum Subwoofers
    Last Post: 09-16-2005, 02:26 PM
  3. I LOVE BASS>>> I LOVE IT, I LOVE IT
    By mrt1184 in forum Subwoofers
    Last Post: 12-15-2004, 08:47 PM
  4. Bass competition cd songs
    By 2002Mustang in forum General Discussion
    Last Post: 01-10-2002, 08:41 PM
  5. American Bass
    By Cadillac in forum Amplifiers
    Last Post: 12-21-2001, 11:33 AM
