Poll: Best way to go for front stage?
+ Reply to Thread
Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 31 to 45 of 47
Reload Thread: Poll: Front stage opinions
  1. #31
    West's Avatar
    West is offline Banned
    Jan 2012
    Oliver Springs, TN
    3,705
    73 Post(s)
    Re: Poll: Front stage opinions
    Quote Originally Posted by gckless View Post
    @West where do you cross your rears at? Bandpass right?
    Bandpass from 8khz-60hz
    8k-200 would be another one to try
  2. #32
    neo_styles's Avatar
    neo_styles is offline AKA Pop Twidget
    Sep 2012
    Porter Ranch, CA
    27
    3,055
    41 Post(s)
    Quote Originally Posted by West View Post
    I would think something more like 2k-60Hz would work out better with keeping the stage from pulling to the rear.
  3. #33
    neo_styles's Avatar
    Sep 2012
    Porter Ranch, CA
    27
    3,055
    41 Post(s)
    BTW, OP, get the Levi. Should be the last amp for your comps you'll ever need. That or a Zuki. When I'm ready for it, I'll be going with one of those. Have to find the right HU/processor first, though.
  4. #34
    gckless's Avatar
    gckless is online now CarAudio.com Veteran
    Aug 2011
    San Antonio
    3,387
    23 Post(s)
    That seems high, no? I would definitely need a seperate crossover for that high.
    Quote Originally Posted by neo_styles View Post
    Dude, trust me, I want that Zed really bad. Have to square away my sub stage first, not to mention get a new vehicle lol.
    Quote Originally Posted by ducatipaso View Post
    To say that 8inch, 10inch and even 12inch subs are for girls is just not true. 15inch subs can't play fast beats, they take more power and that taxes the vehicles electrical system. You will wake up and "hear" then see the light at the end of the tunnel and it will be 3 10's pounding so hard you wont even open your trunk or turn your system on because you 15's will sound sloppy & weak.
    Quote Originally Posted by benbenondatrack View Post
    stfu lesbo.why are you worried about me so much? you must want to date me ya little cookie monster but i dont even like sweets. your just a cup full of ice, dirt dead nasty azz ice...without the water.
  5. #35
    neo_styles's Avatar
    Sep 2012
    Porter Ranch, CA
    27
    3,055
    41 Post(s)
    Lol, hear you on that. I'm borrowing an active-capable HU for a bit so I can get the feel of that. Might start me from square one if it takes off like I think it will, but I'm learning every day. I was thinking of the Levi, too, until I learned about how happy people were after switching from the Levi to the Zuki Eleets Hybrid 5-channel. Considering it's cheaper and seems to be getting really favorable reviews (not to mention lots of power on tap), I'd be willing to go from a 6-channel to a 5 if it lives up to the hype.
  6. #36
    Why So Cereal?'s Avatar
    Why So Cereal? is online now Invisible Cereal
    Sep 2010
    Drowning in milk
    7,348
    74 Post(s)
    TL;DR
    Best to have the active controls up front as you WILL find yourself tweaking everyday for a long time to come. Better to be able to change there and listen than hop in the back and hop back up front for a listen.
    Rear fill has way more benefits than a lot of people like to make it seem. Rear fill completes an SQ system and, when implemented properly will sound better at the driver's seat than to the rear passengers.
    However, if you're running active off the 80PRS with subs, you will not have extra preouts for rear fill. The only way to do rear fill would be to somehow split the signal from your mids to an amp for the rears but to get the full effect of real rear fill, you would need to integrate a mini DSP with the rear fill plug in that will properly process the rear signal and also allow you to delay them beyond the Haas effect, thus creating a larger listening space.
  7. #37
    gckless's Avatar
    Aug 2011
    San Antonio
    3,387
    23 Post(s)
    The whole point of upgrading to the Levi for me would be to have 6 channels. Could always do a 4+2 channel, but the Zed is so damn sexy.
    Quote Originally Posted by princ3cmo View Post
    TL;DR
    Good points. So, which would you go with out of my 3 choices? Also, just noticed your location. I like it.
  8. #38
    Sep 2010
    Drowning in milk
    7,348
    74 Post(s)
    Of your 3 choices, I would go with the HU to DC, no rears as of now. That way you control everything from the HU and it costs nothing.
    If in the future you decide you would like to add rear fill, you can upgrade to a 4 way HU or external processor or simply add the mini DSP into the mix. But, no need to do that right now as you may be satisfied with just the fronts.
    Its always recommended to perfect the front stage before moving to other speakers anyway. Otherwise things just get more complicated with more drivers.
  9. Likes Slayerx, gckless liked this post
  10. #39
    West's Avatar
    Jan 2012
    Oliver Springs, TN
    3,705
    73 Post(s)
    I am talking about the rear field
    8khz was where I liked it, I am assuming you have full range 6x9's
  11. #40
    gckless's Avatar
    Aug 2011
    San Antonio
    3,387
    23 Post(s)
    I think I am going to go that way, no rears. Not getting a DSP now, and I do like having control up front. If I did rears off the HU speaker outs it would be off the mid channel, and I would not have any independent control of their crossover points or slopes or their volume. Would end up being a headache I think. Plus, it costs nothing, which is really the enticing part.
  12. #41
    Sep 2010
    Drowning in milk
    7,348
    74 Post(s)
    You woudn't need to worry too much about their crossover points. Thats why I said use the mids output for the rears. That way the aren't playing too high and drawing the stage back. Volume wise they would just need to be low enough to not be noticeable and take away from the front stage. These are easy quick "set it and forget it" type things.
    Once the DSP does the differenced signal and delays them about 20ms behind the fronts, you're pretty much good to go and not much tweaking should be needed.
    But, I still say go with just fronts first. Just don't count out the possibility of rear fill even on your setup.
  13. #42
    gckless's Avatar
    Aug 2011
    San Antonio
    3,387
    23 Post(s)
    But I wouldn't be able to set the volume of them seperately. Well, I guess if they were too loud I could just turn the mid channels down and then turn the gains up on my amp to compensate. Either way I'll have to test before I do that.
    I'll probably just end up running my CDT HD-62CF's up front and nothing in the rear for now. Planar tweets look really enticing, but cost money
  14. #43
    Sep 2010
    Drowning in milk
    7,348
    74 Post(s)
    The rears will be on a separate amp anyway since your preouts will be taken. Just reduce the rear amp gain
  15. #44
    gckless's Avatar
    Aug 2011
    San Antonio
    3,387
    23 Post(s)
    My original intent was to just use the internal amp on the 80PRS.
  16. #45
    Sep 2010
    Drowning in milk
    7,348
    74 Post(s)
    Then, you can't run rears at all if you're gonna go active and even if you stuck with passive fronts, you still couldn't run properly processed rears on that HU. I don't think it even has enough delay.
    Only way you would be able to add rears and go active is adding a separate amp for the rears.
+ Reply to Thread
  1. Advanced front stage opinions.
    By DDtC in forum Speakers
    Last Post: 03-09-2012, 10:58 PM
  2. Replies: 0
    Last Post: 01-18-2010, 11:34 AM
  3. Opinions on front stage
    By alex211 in forum Speakers
    Last Post: 08-13-2009, 12:25 PM
  4. my first quality build, front stage opinions
    By Stupid8000 in forum Speakers
    Last Post: 02-27-2009, 02:55 PM
  5. help me select an amp for front stage...
    By xmywarx in forum Amplifiers
    Last Post: 03-24-2002, 08:26 PM
