+ Reply to Thread
Page 2 of 2 FirstFirst 1 2
Results 16 to 20 of 20
Reload Thread: Hooking up my crossover power wire.
  1. #16
    calebkhill's Avatar
    calebkhill is offline Senior VIP Member
    Dec 2012
    Phenix City, Alabama
    387
    2 Post(s)
    Re: Hooking up my crossover power wire.
    Quote Originally Posted by maylar View Post
    Is the crossover the XM6? If not, what model?
    Coustic XM-3
    The Alpine amp is 4 channel - are you bridging it to 2 tweeters?
    No, only running 2 channels.
    The Sony amp is 2 channel - are you running the 4 6x9's as parallel pairs?
    Yes, unbridged.
    How do you have the crossover configured, and what settings are you using on the amps' HPF/LPF? They all play together. You're running an active system that can take a lot of time to dial in.
    When I hooked up the cross over, I set the hpf for 6x9s at 80hz, and the tweets hpf at about 3.5khz. I turned the amps crossover to off. As i turned up the volume and the level at the crossover the speakers sounded blowed..... Gains on amp are all the way down.
  2. #17
    maylar's Avatar
    maylar is offline Electrical Weenie
    Jan 2002
    Connecticut
    61
    3,243
    8 Post(s)
    Seems you've set it up correctly. Unfortunately it's hard to diagnose from my keyboard. One thing I would try is to strip the system down to minimum - replace the Sony amp with the other 2 channels of the Alpine. It will take a 2 ohm load, but using just 1 set of 6x9s would simplify the install more. See if you can get a minimum configuration to work, then work up from that.
    BTW the Coustic crossovers get very high ratings in the reviews. Being 10 yrs old doesn't mean anything if it hasn't been abused.
    dave
    1999 Buick Park Ave Ultra
    Head Unit: JVC KWHDR720
    EQ: Audiocontrol EQL
    Front Stage: Hybrid Audio Technologies Imagine 5.25
    Sub Stage: In process (will be Boston G310)
    Amp: Boston Acoustics GTA-704 4 Ch
    Rear Fill: Boston SE953 6X9's
  3. #18
    calebkhill's Avatar
    Dec 2012
    387
    2 Post(s)
    Well i found a hpf on my HU so that eased the pain some.... I reeally dont think i need one now due to the HU having a hpf. Made a big difference.
    But seems like im running into more and more problems, im tired of asking questions lol. I said this in another thread somehwere but tuning my system is becoming a nightmare.... Just ***** because I know it has alot of potential, theres just alot of missing links i need to get it there...
  4. #19
    UnderFire's Avatar
    UnderFire is offline CarAudio.com Elite
    Apr 2011
    Dayton, OR, 97114
    1,750
    26 Post(s)
    If your HU has a built in Crossover there is no need for the crossover network, I found that out trying to tune a system that had a CDA-117 and a 2-way Active network, save some headache and ditch the crossover network. The crossovers were built for a time when you had to get really high end HU's to have multiple sets of Pre-outs and built in crossovers.
    97 4runner, 3RZ, 5 Speed
    Headunit: Pioneer DEH-P9800BT
    Mids: Lanzar 6m
    Tweets: Crescendo CCX
    Fronts Amp: Alpine PDX4.100
    Sub Amp:Hifonics BRZ1.1700D
    Substage: 18" SSA ZCON
    Electrical: 160 Amp Alt, Duralast Gold, C&D270FR, 2/0 Throughout
  5. #20
    calebkhill's Avatar
    Dec 2012
    387
    2 Post(s)
    Yea Im done with it for now.
+ Reply to Thread
  1. What do i hook up my REM wire to in my stock headunit?
    By udmm54 in forum General Discussion
    Last Post: 08-23-2009, 10:16 PM
  2. What wiring will I need to hook up my stuff?
    By pyoung9 in forum General Discussion
    Last Post: 07-07-2007, 10:05 PM
  3. where do i hook up my remote wire for my amp
    By audiobahnboy in forum Wiring, Electrical and Installation Help
    Last Post: 09-27-2004, 01:10 PM
  4. where can i hook up my constant power
    By jus_1982 in forum General Discussion
    Last Post: 06-07-2004, 05:13 PM
  5. Replies: 1
    Last Post: 04-17-2003, 11:43 AM
