Not trying to be an as*hat or anything but this statement is not accurate....it may be better to say that not many competitors use them. I know of a few that are an one more notiable one is my friend Todd Crowder owner of TC Audio who himself won 1st Place Expert Sound and Expert Install at the 2011 Spring Break Nationals and 1st place Xtreme SQ and Xtreme Q at the 2011 USACi World finals with his 10' Camaro SS using an MS-8 in his setup....
here's a link to his shop and magazine articules...
PASMAG | PERFORMANCE AUTO AND SOUND - First Light: 2010 Chevy Camaro SS/RS
TC Audio
Just when they though it couldn't get any worse, in came the Lord of Kaos, the Darkhart has arisen from his century long slumber..
____________
refs:
Type-S Texan ............Xtremebass5
NE14MX ........Grinder1989
NJack2AF .............Jameseypoo
Randyrsx ..........Bagdntagd
M3Transporter......Teggybwoy
RJ Sclafani...........Zeuslicious
Saltyreefguy........Qkassidyw
Qtrhorse..............Nismos14
Pistonsfan70........4nine
SlainNothing.........Orangelss
M3@Apex............Louisiana_CRX
SW9152..............DukeNut
You're right I should have been more specific. VERY few competitors use them. This year at Meca finals most of the first place winners were using Mosconi 6to8s and the Helix processors. Same goes to most of the other competition formats.
It is true however that the ms8 is not nearly as sonically pure as other processors.
PHD Audiophile Systems Dealer
Why not a Mini DSP 2x4? Much cheaper and filled with features.. You can stack 2 for 4x8 channels of processing
Refs:
sefugi x2, S.DeYoung, SteveMead, chillin, rebelfromva, Got160s?, JL Audio , mclerico83, and BIGJEFF64.
I'm just picking at ya cause it's Christmasas far as sonically pure, well the processor shouldn't add anything to the sound itself unless it was designed to do so and in saying that I will say this, I've listened to Todd's Camaro several times and just this past July I got a chance to listen to Scott's Altima as it sat right next to Todd's car and sonically both were incredible. I say this because everyone knows the level of car that Scott has and he's running a moded Audison Bit processor and Todd the MS-8, you could not hear ANTHING other than the music IMO as it was intended to be heard in both cars.....
____________
refs:
I highly doubt you could make a Mini DSP sound as good as a 6to8, Helix, PS8. Why? Because you are getting a generic DSP, yes the high end mini's have 24 bit dac's, but that doesn't mean much. I recently bought a $400 Denon receiver with a 24 bit generic dsp/dac and the sound was absolutely terrible through HDMI. Needless to say I sent it back to the store. I would love to a mini dsp for time alignment for subs, where a large amount of detail is not required. But even then you would have to try it out to see how it sounds. Have you used one? How did it sound?
The fact is, and it's somewhat unfortunate, that you get what you pay for. Also will all the processors, including the MS8 you still need a fair bit of experience (and some additional hardware or some serious tuning skills) to get the most out of any of the processors. You also end up paying more for the processors because they come with more polished software and often more tuning options.
One more thing, many of those processors are using the same boards and components, so in reality they are probably more similar than the manufacturers would like people to know. The differences boil down to the software and some baseline settings...
So I want my car to sound really good, but I'm not looking for award winning sound. Would you guys say that most people would be very happy with the sound you can get from the jbl ms8? Ive read a lot of reviews and most people say it sounds really good. I just dont want to be disappointed.
I just read the user manual and it seems very easy to install, so I'm just about ready to order one.
09 lancer
HU: Pioneer AVH-P8400bh
Amps: JL XD 400.4 / JBL 1201.1
Front stage: HAT Imagine I61-2V2 6.5''
Sub: JL 12w7,1.7 cu ft fibreglass box(sealed)
Winner of Virginia's IASCA Sound Quality Challenge - YouTube
This guy looks satisfied.
So many assholes... so few bullets.
My car sounds pretty **** good right now. I think you'll be happy with it. As simple as it is to set up though, you will definitely have to run the calibrations more than once and play with the xover points and slopes and then you can do a little fine tuning with the eq. Even playing around with head movement to get a good center image will take a bit of messing around with. It's still probably the easiest solution out there right now for setting up a good sounding system. The key is having a center channel though, it makes a big difference!
A center channel is definitely on the to do list. How did you go about doing the centre channel? How do you recommend I do it?
Right now I have a 4 channel amp to use for the mids and tweets up front, was thinking of running the stock rear speakers on the ms8. And centre channel on the ms8.
Or use the 4 channel amp for front mids and the rear coaxial mids. And run the front tweeters on the ms8 and the centre speaker on the ms8.
I am wondering how I hook up the output for the centre channel and the sub channel to a amp. The outputs are for a single rca hookup. If I found a small 2channel amp to use for the centre channel, would I just use a rca "y" splitter for input to the amp. And the same for the sub amp? I know some mono amps have the single rca hookup, but mine has 2 rca plugs(1 red and 1 white) just use a splitter?
09 lancer
hihi, thanks bác 1 cái nhé, anh em cùng ?ng h? na, chúc anh em vv
Bookmarks
