Maybe this is a self-troll thread?
Head Unit: Pioneer avh-4300dvd,
Front Stage: Ascendant Audio 6.75", Massive Audio 28mm tweeters
Rear Fill: Massive Audio CK6-3 6x9 Woofers
Amps: PPI Phantom P900.4, Sundown Audio SAZ-2500D
Sub: RE Audio XXX 12" 2.25^3 Tuned to 32
They sell Kicker at Wal-Mart now. That's saying a lot..
you sound like a dummy. it dont matter if it was 4 wires or 2, it was still running at 1 ohm. i would rather only have 2 sets of wires coming out of my box vs two if its going to give the same amount of power. less clutter and there is no need to use both terminals on the amp for 1 sub.
Low & Loud Songs - Slowed By BenBen Vol 1: http://www.sendspace.com/file/328is7 -
Low & Loud Songs - Slowed By BenBen Vol 2: http://www.sendspace.com/file/vq6pdx
***Current Setup***
2006 Pontiac G6 Sedan
Pioneer avh-p4300 Head Unit
FI Sp4 15 (D1.27 ohm)
3.5Cu Slot Ported Box tuned to 33 Hz (Designed By @dbeez )
Sundown Audio Saz 3000D
***Current Setup***
slugs dont just crack they need to be hit and chipped
I'm a dummy because each of the vcs on my sub are wired to their own port on my sundown amp. You can get 2 pair 12ga wire too, you know. I know you can do it your way for aesthetics, but doing it my way will get more power to the sub. But you don't know why, and that's the (well, one) difference between me and you. Oh, and my sub still works. I still think you wired it out of phase, causing **** to break. Prove me wrong, please.
You can't see any wires in my setup anyway :P
i do see what your saying. i actually wire my sub the same way. if i understand correctly. yes you can jump the wires on the inside but running all the wires out of the box with help the sub play better, if im not mistaken that is. i run the wires staight into the amp, no internal jumps
YOUTUBE SEARCH- *BGOWDY31 or BGWDY3131(<-new)* FOR ME & MY WIFEYS DAILY SYSTEMS
MY 95 CHEVY BLAZER~~~~WIFEYS 03 FORD FOCUS SE
1 SUNDOWN ZV3 18 D2(COMING SOON)~~~1 KICKER L7 15 D4
4.76 CUBE 1 8" AEROPORT 41HZ~~~5.6 CUBE L-PORT 42-ISH-HZ
CRESCENDO BC3500 @ 1 OHM~~~KICKER ZX1000.1 @ 2 OHM
DC 220A,4-0GA RUNS,2GA BIG 3,3 DEKAS 105AH EACH~~~STOCK ALT,1-8GA RUN,STOCK YELLOW TOP
147.6-MUSIC AVG 45 SEC(PREVIOUS AMP/SUB)~~~143.8-MUSIC AVG 45 SEC
146.8-LEGAL MUSIC AVG(PREVIOUS AMP/SUB)~~~143.1-LEGAL MUSIC AVG
one pair of wires for each VC wired straight to it's own terminal on the amp. it just sounds like good install practices to me![]()
good lord.....
New Car, New Build coming soon... will consist of:
RF 360.3&Apple iPad Mini
Tantric comps
Sundown subs and amps
Mechman HO alt
Deka batts
Knu Conceptz&Shok wire
Audio Technix deadening
gckless liked this post
okay, i'm not reading through all this but if you still need help. I'll take a look at it and wire it correctly for you next week. hit me up.
SPL-Lab REP
Want an SPL meter for a lot less than the cost of a Termlab, but just as accurate and has the same features? PM me.
he threw it in the trash
Consult this next time: Rockford Fosgate® - Woofer WiringWizard
No speaker, in the history of speakers, has ever been blown by too little power. Ever. I don't care what your friend told you, he's a dirty liar.
Bookmarks
