+ Reply to Thread
Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 16 to 30 of 59
Reload Thread: WTF just happend?
  1. #16
    -BenBen-'s Avatar
    -BenBen- is offline TEAM FI
    Jun 2011
    Down South
    669
    14 Post(s)
    Re: WTF just happend?
    Quote Originally Posted by esmokah View Post
    any battery should work.. when we can start adding up what we have and subtracting the things we don't, we can figure out this problem. right now we just think our wiring is ok, assuming everything is supposed to work, yet it doesn't. i think everyone following here would agree.
    ok will do.. thanks guys
    Low & Loud Songs - Slowed By BenBen Vol 1: http://www.sendspace.com/file/328is7 -
    Low & Loud Songs - Slowed By BenBen Vol 2: http://www.sendspace.com/file/vq6pdx
    ***Current Setup***
    2006 Pontiac G6 Sedan
    Pioneer avh-p4300 Head Unit
    FI Sp4 15 (D1.27 ohm)
    3.5Cu Slot Ported Box tuned to 33 Hz (Designed By @dbeez )
    Sundown Audio Saz 3000D
  2. #17
    ssteele18's Avatar
    ssteele18 is offline CarAudio.com Elite
    Apr 2012
    St. Cloud, Fl
    961
    29 Post(s)
    S
    Quote Originally Posted by benbenondatrack View Post
    Have you by chance checked if your amp will support a 1 ohm load? From the sounds of it, you are not familiar with this amp. What he was doing(gathering all of the thoughts so far) was running 1 coil per channel, right? So each channel was getting a 2 ohm load...? When you wire in parallel down to 1 ohm and bridge, the amp may not be stable.. Check that out too.
    ssaudiosolutions@gmail.com
    www.facebook.com/SSAudioSolutions
    Whether you think you can or you think you can't, you're right..
  3. #18
    gckless's Avatar
    gckless is online now CarAudio.com Veteran
    Aug 2011
    San Antonio
    3,387
    23 Post(s)
    Quote Originally Posted by ssteele18 View Post
    S
    Or he was just running both coils to a monoblock. OP's got an SAZ I think, so he's got 4 terminals, but only one channel. Definitely 1 ohm stable. If that's the amp he's using. Doesn't really matter what the last dude was doing at this point IMO.
    Quote Originally Posted by ducatipaso View Post
    To say that 8inch, 10inch and even 12inch subs are for girls is just not true. 15inch subs can't play fast beats, they take more power and that taxes the vehicles electrical system. You will wake up and "hear" then see the light at the end of the tunnel and it will be 3 10's pounding so hard you wont even open your trunk or turn your system on because you 15's will sound sloppy & weak.
    stfu lesbo.why are you worried about me so much? you must want to date me ya little cookie monster but i dont even like sweets. your just a cup full of ice, dirt dead nasty azz ice...without the water.
  4. #19
    NASTY08IMPALA's Avatar
    NASTY08IMPALA is online now CarAudio.com Veteran
    Aug 2012
    LOUISVILLE, KENTUCKY
    2,947
    31 Post(s)
    yes his amp is a saz3000 ..u shouldnt have touched it it was already wired at 1 ohm he jus had each lead gojng to that amp..and there arent channels on that anp ..all inernally bridged
  5. #20
    Aug 2012
    2,947
    31 Post(s)
    wow i hate typing on this phone..lol...i hope u didnt fudge up a sub that wasnt urs ..u just got bad luck man
  6. #21
    ssteele18's Avatar
    Apr 2012
    St. Cloud, Fl
    961
    29 Post(s)
    Quote Originally Posted by NASTY08IMPALA View Post
    Quote Originally Posted by gckless View Post
    He makes it seem like they're separate channels... How do you have the dough to run a setup like this but not know how to wire! wish I had the money.
    Long story short then, by wiring each coil into each "channel" on your amp, you'll be at 1ohm.. I see many mono blocks nowadays running internal bridging.. Hook one coil to each and figure out why nothing is playing..
  7. #22
    jdawg's Avatar
    jdawg is offline CarAudio.com Veteran
    Jun 2006
    Maryland, United States
    8,608
    1 Post(s)
    monos with internal bridging?
    refs
    woc47, nigro013, defconx3, louisiana_crx, bld 25, supa_c, lancer1978, sxkicker89, 310w6, more, i forget
  8. #23
    ssteele18's Avatar
    Apr 2012
    St. Cloud, Fl
    961
    29 Post(s)
    Quote Originally Posted by jdawg View Post
    It's not the same as bridging a 2 channel amp. They just have the terminals wired in parallel so it make it easier to hook up 2 subs. You just run each sub(or in his case, coil) into each terminal and it wires in parallel.. Rather than wiring it all together before the amp.
  9. #24
    ThatChevyGuy's Avatar
    ThatChevyGuy is offline i heart Jager
    Jul 2006
    Arkansas
    11,799
    11 Post(s)
    Wtf r u doing with good equipment if you don't know wtf you are doing??
    REFS:
    Squeak9798, Kumbos310w6, BigBangTheory, Jmanpc, MillzThaYungin, WLDock, -Leister-, ThomasG, J31Rob (and a few more I have forgotten)
    Quote Originally Posted by Spider Monkey View Post
    eat my asshole you insignificant bastard child of a retarded dingleberry cunt wrinkle fuck toy
    Quote Originally Posted by subzero View Post
    her pussy better be that nicest pussy you ever ever ever had. she better suck, swallow, jack off, eat ass and snatch, make sammiwich, do yard work and fix the vehicals while nude. Because a bitch like that is definately gonna cause alot of stress in your life, even thou she keeps your wallet and your balls drained.
    Quote Originally Posted by 05fronty View Post
    bitch you better swallow and not make a mess
  10. Thanks Devil Tiger, 09civic thanked for this post
    Likes esmokah, Serpent710 liked this post
  11. #25
    Serpent710's Avatar
    Serpent710 is online now CarAudio.com Veteran
    Feb 2008
    Florida
    2,598
    22 Post(s)
    Subwoofer Wiring Diagrams
    2 second google search.
    Refs: mike11202, Tehgregzor, Twisted_0912, Goindef154, fasfocus00, got_focus?, Boswell59, 2lows10, skateguy92, Worstenemy453, Supergumby5000, gboo559, ryanm923, GetLikeMe, TaylorFade, Dacheatham, pickup1, jerseyboy, TWiZTiD859, Kangaroux, 09civic
    Sub: 2 12" Cerwin Vega Vmax
    Comps: Boston
    Enclosure: Birch Bitch
    Amp: JBL Crown BPx1100.1
    H/U: Pioneer Premier FH-p800bt
    Wiring: Stinger HPM
  12. #26
    gckless's Avatar
    Aug 2011
    San Antonio
    3,387
    23 Post(s)
    Yeah he does make it seem that way, but I'm not sure he actually knows.
  13. #27
    -BenBen-'s Avatar
    Jun 2011
    Down South
    669
    14 Post(s)
    I know. i just wanted it more convient having 1 set of wires vs 2. anyway the motor shifted so i threw it away. pissed me off, it was bad and i didnt know it, the motor was in terrible condition. so i now will be getting a new sub
    ***Current Setup***
  14. #28
    michaellane's Avatar
    michaellane is offline CarAudio.com Veteran
    Oct 2005
    virginia beach
    26
    8,611
    2 Post(s)
    First, please clear up your sentences..It's killin' me trying to understand.. You were saying there were how many wires total? And it's a DVC or QVC? I'm confused.
    Edit: Beat me to it... Cellphones... Smh
    he doesnt have time for that...he is a busy man
  15. #29
    gckless's Avatar
    Aug 2011
    San Antonio
    3,387
    23 Post(s)
    So was he using 2 channels or just 2 sets of wires to a single channel? And way to let us know that you figured out the problem.
  16. #30
    jdawg's Avatar
    Jun 2006
    8,608
    1 Post(s)
    i know what you meant, saying it like that though throws alot of people, my buddys cousin still swears the aq2200 my buddy bought needs bridged, he thinks its a 2 channel amp cause it has 2 sets of speaker terminals
    refs
+ Reply to Thread
  1. WTF just happend?
    By murderedtahoe in forum General Discussion
    Last Post: 11-24-2009, 02:35 AM
  2. WTF? just wondering why it does this
    By SplChoice- in forum Speakers
    Last Post: 07-08-2007, 12:31 PM
  3. WTF just happened (HIDs)
    By Raisedin305 in forum Car Interior/Exterior Enhancements
    Last Post: 03-26-2006, 06:43 PM
  4. whoa wtf just happened?
    By jmeifert893 in forum Wiring, Electrical and Installation Help
    Last Post: 09-13-2005, 07:14 PM
