Click "Reload" to fetch new posts without leaving the page.
Automatic thread refreshing has been stopped because you appear to be idle. Un-Idle
Reload -
Re: not the "normal" install.... would like opinions and some advice
Originally Posted by
campbell8402
thank i appreciate all the help......i always go by reviews online and obviously they are not always the best...
im not looking for amazing but i do want something nice
if i was to run the 6x9s in the back and components up front what would be my best way to wire it to the 4 channel (keeping sub)
You'll lose your fader ability but you can run your back and front speakers together, just wire them in parallel. Then bridge the sub on the other 2 channels.
- Pioneer 80PRS
- db6501's LOOKING for new
- 4 Gcon 12's
- Coustic 510DR Amp
- LOOKING FOR SUB AMP
- Knu 0g
- LOOKING FOR BATTERIES
ok so i have my my final decisions....
i stuck with the mb quart 4.80 for my amp (got it)
clarion eqs746 (on the way)
soundstream sc-6t components up front
soundstream pct .653 coaxials out back
i also found and now own a vented box that matches my sub requirements almost perfectly ($50
now i have a few questions just so i set things up correctly and get the best sound i can
#1 using the eq and my phone as my primary source should i set both my crossovers on my amp to full and control everything from my eq?
#2 for using ch3/4 four bridged for a sub the amp instructions (first NEW amp i have ever owned so i read em) say to use a mono source...
will just running both rcas from the eq's sub out work fine? or do i need to do something "special"
im still trying to do more research on my own but if anyone knows these answers off the top of their head.........i would appreciate any response
sorry to make another post right after this one but one more ?
im gonna use ch1/2 for my fronts and rears
front components are 80rms and the rears are 90 rms
amp puts out 160x4 at 2ohms ... if i wire them in parallel it should be just about the perfect match.....?
would it matter if i use 14awg speaker wire out back and the 16awg on the front?
i dont have enough of either to wire all the same.... but could buy more.... but is it nessacary?
By rosshimself13 in forum Speakers
Last Post: 06-13-2010, 09:33 PM
By nikegiant023 in forum Subwoofers
Last Post: 04-29-2010, 08:45 PM
By SKyleS in forum General Discussion
Last Post: 07-08-2006, 10:24 PM
By bdonkersgoed in forum Wiring, Electrical and Installation Help
Last Post: 05-03-2005, 03:37 AM
By knub in forum General Discussion
Last Post: 11-08-2002, 04:50 PM
- You may not post new threads
- You may post replies
- You may post attachments
- You may edit your posts
Forum Rules
Bookmarks
