Page 5 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 61 to 75 of 77
Reload Thread: AP 1800 Louder then saz 3000d..Why?
  1. #61
    cdc351jeferson's Avatar
    cdc351jeferson is offline CarAudio.com Elite
    Jul 2012
    austin tx
    1,658
    693 Post(s)
    Re: AP 1800 Louder then saz 3000d..Why?
    Quote Originally Posted by benbenondatrack View Post
    ok guys i guess it was the gain, i turned it up to about maybe 60% and it started coming to life, and i mean loud. i need a way better box but it def. it alot better then the ap 1800 now
    with low voltage coming into amp from headunit youll need to have gain higher to match. you should have a real box builder build you a box . pm double 07!!! let him build you a box
    headunit : Sony xab-601bt
    fronts: infinity kappa 60.9's
    box : Bill Fitzmaurice Truck tuba DD 600series 10"
    amp: Kicker zx500.1
    REFS: Bradfordp2612 , Double 07 , NASTY08IMPALA , mzlady
  2. #62
    gckless's Avatar
    gckless is offline CarAudio.com Veteran
    Aug 2011
    San Antonio
    5,159
    6 Post(s)
    2218 Post(s)
    On the SAZ? Dude, I'm telling you, stop doing what you are doing without knowing exactly what's going on with your system. Buy some tools, set the gain properly unless you are positive you know what clipping sounds like, and make sure you get a voltage meter. If you are approaching clipping I'd be scared though. You don't have much current to push to that amp, if you dip too low on current you have a good chance to blow that amp again. Voltage can tell you a lot.
  3. #63
    Jul 2012
    austin tx
    1,658
    693 Post(s)
    yeah i would watch it man the dude im getting a saz4500 from didnt have good electrical and now its at dbr because of it
    amp: Kicker zx500.1
  4. #64
    itsblown's Avatar
    itsblown is offline why is there smoke?
    Sep 2011
    Toledo OH
    1,148
    366 Post(s)
    Quote Originally Posted by ace_800 View Post
    I set with DMM and my gain is 3/4's up, voltage is 2.5 and no clipping.
    How do you know there is no clipping without an O scope?
  5. #65
    TaylorFade's Avatar
    TaylorFade is offline I fail.
    Dec 2009
    Baton Rouge, La.
    3,019
    19 Post(s)
    1292 Post(s)
    This thread...
    SMH.
    Quote Originally Posted by eCrack View Post
    TaylorFail
    Quote Originally Posted by Suicide Bobb View Post
    Taylorfail, v.2
    Quote Originally Posted by Imtjnotu View Post
    tailorFail v.3
    Quote Originally Posted by brodeisel View Post
    TaylorFail v.4
    Quote Originally Posted by tat2bass View Post
    TaylorWin v.1?
  6. #66
    itsblown's Avatar
    Sep 2011
    Toledo OH
    1,148
    366 Post(s)
    Quote Originally Posted by goingdef View Post
    Well seeing as with most amps power drops as as the ohms rise I think you might want to look into this a little more, rise is only a need to know thing if your burping a tone and it has to be the same tone you tested with to find the rise so most find the tone that meters the highest then test for rise and make the appropriate adjustments.
    It does come into play, when you set the gains using a dmm you are setting the amplifier to put out a certain amount of volts of alternating current, you find the amount of volts, by looking at the amps rated power output at a certain impedance level. However once you start playing your sine wave to set the gain with the dmm you immediately have impedance rise. For example lets say you are setting the gain on an amp that puts out 1000 watts at 1 ohm that is hooked up to two dual 4 ohm subwoofers. Lets say the woofers are wired down to 1 ohm on the amp. 1x 1000 =1000 and the square root of 1000 is 31.6. So you should look for 31.6 volts of alternating current on your dmm for the amp to be putting out 1000 watts at 1 ohm like it is rated to do so. Once you start playing your sine wave your amplifier is going to be seeing above 1 ohm due to impedance rise, if you then turn the gain and set it so its putting out 31.6 volts of alternating current your amp is going to be far into clipping. Also you run into the problem of amps not doing what they are rated to do, and not knowing the supply voltage to the amplifier.
    The only sure way to set your gain is with an o scope
  7. #67
    -BenBen-'s Avatar
    -BenBen- is offline Team L.oud A.s F.u**
    Jun 2011
    Down South
    816
    488 Post(s)
    Quote Originally Posted by gckless View Post
    i will just unplug the amp until i get my new alt
    -My Current Setup-
    Head Unit - Pioneer AVH-P4300
    Sub - Audioque HDC4 15 - 4.0 Cu @33hz (Built By @DBeez ; )
    Amp - American Bass VFL 500.1 (.5 Ohm)
    Front Stage - Stock
    Electrical: 2/0, Big 3, 270 Amp DC Powered Alt. Batts: Coming Soon
    Tuned Low and need Fresh music ? >> http://www.datpiff.com/Team-LAF-Loud-As-Fu-Slowed-Low-Loud-Bangers-mixtape.514065.html <<
    >Team L.A.F.<
  8. #68
    -BenBen-'s Avatar
    Jun 2011
    Down South
    816
    488 Post(s)
    Quote Originally Posted by cdc351jeferson View Post
    trade my amp and cash for yours?
    -My Current Setup-
    Front Stage - Stock
    >Team L.A.F.<
  9. #69
    Jul 2012
    austin tx
    1,658
    693 Post(s)
    no my amp is partial trade for the saz
    amp: Kicker zx500.1
  10. #70
    dbeez's Avatar
    dbeez is offline CarAudio.com Veteran
    Nov 2008
    crestwood,ky
    9,436
    1 Post(s)
    915 Post(s)
    He means his saz for your saz
    2002 suburban
    Security System Code alarm
    Electrical Dc power sp270 7 deka 9A31's and lots of 1/0
    Headunit pioneer 880prs
    Amps 2 Sax125.2 front stage crossfire [email protected]
    Wiring lots of 1/0 stinger, tsunami
    Mids & Tweeters 2 sets cdt m6+ mids 2 sets cdt tw25 tweets
    Subs 2-18" nightshade v2's d2
    System DetailsDaily driver.
  11. #71
    Jul 2012
    austin tx
    1,658
    693 Post(s)
    Quote Originally Posted by dbeez View Post
    lol thats funny . his subs would cry on that power. yeah hes giving me 150$ plus the saz for my aq and ill be out like a 250-300$ repair bill
    amp: Kicker zx500.1
  12. #72
    dbeez's Avatar
    Nov 2008
    crestwood,ky
    9,436
    1 Post(s)
    915 Post(s)
    What he wants the saz4500 not the aq
    2002 suburban
  13. #73
    goingdef's Avatar
    goingdef is offline CarAudio.com Veteran
    Jan 2008
    Norfolk VA
    37
    2,834
    1 Post(s)
    864 Post(s)
    Quote Originally Posted by itsblown View Post
    That would make sense IF you are setting the gain with the subs hooked up(which you don't), an amp does not sense a rise in impedance with no load on it.
    Oh and as impedance rises ac voltage must rise too if not it will be seeing less then it's rms wattage so how do you figure it would be clipping. So once again with a decent amp that's known to do rated or better setting it with a dmm is fine, now I agree if you wanted to squeeze every last watt from an under rated amp a scope is the way to go.
    electrical: Optima yellow top X 2 big 3 in monster OFC 1/0g high output alt by maniac electrics
    HU: JVC AVX-77 touch screen
    Front stage: RE XXX 6.5" comps
    front stage amp: Rockford T600.2
    subs: 1 Sundown ZV4 12"
    sub amp: Rockford T2500.1BDCP
    Enclosure: ported (by JayDubb757 )
  14. #74
    Jul 2012
    austin tx
    1,658
    693 Post(s)
    my saz
    amp: Kicker zx500.1
  15. #75
    bgowdy's Avatar
    bgowdy is offline HE NEEDS SOME MILK
    Apr 2011
    Campbellsville, Ky
    7,837
    71
    2 Post(s)
    2487 Post(s)
    lol i thought it was his gain
    06 DODGE STRATUS SXT
    Subs: Sundown ZV4 15 D1 Rev1 Motor/Rev2 Softies
    Enclosure: 3.85 Cubes Net Tuned 36hz
    Amp: Soundstream Ta.3kw @ .5ohm
    Stock 120a Alt ~1 XS D3400 & 1 Kinetic HC1800 ~ Multiple runs of Bullz Audio 1/0
    Loudest Build Score ~ 148
    F.C.B.C. > 2010 450 Street 3rd Place Overall > 2011 450 Street Champion
    YOUTUBE SEARCH->bgowdy31 & bgowdy3131
  1. infinits basslink louder then my last setup :(
    By RumbleNTheTrunk in forum Subwoofers
    Last Post: 07-24-2006, 11:36 AM
  2. Will (4) L7 12's be ALOT louder then (1) MT 18?
    By Rodeo91 in forum Subwoofers
    Last Post: 07-09-2006, 12:36 PM
  3. sound better and louder then a 12-W7
    By jrouter76 in forum Subwoofers
    Last Post: 07-02-2006, 04:53 PM
  4. walled off louder then normal setup?
    By psych0ticnemes1 in forum General Discussion
    Last Post: 09-29-2005, 12:21 AM
