+ Reply to Thread
Page 4 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 46 to 60 of 77
Reload Thread: AP 1800 Louder then saz 3000d..Why?
  1. #46
    tc300's Avatar
    tc300 is offline CarAudio.com Veteran
    Mar 2007
    springfield,ill
    2,209
    2 Post(s)
    Re: AP 1800 Louder then saz 3000d..Why?
    Quote Originally Posted by itsblown View Post
    Rise does come into play if you are ussing a dmm. When you use a dmm you are looking for a set power output amount at a rated ohm level. Even if you wire the amp down to 1 ohm nominal it could be seeing impedance rise up to 2 ohms and if you use your dmm to set your amp to put out the amount of power its rated to do at 1 ohm without knowing about the impedance rise youre going to fry your amplifier
    Wouldn't a ddm atleast put you in the ball park of where u want the gain to be tho..??
    And is box rise less noticeable when using a sealed box..?? I would say no but I overheard it being talked about a local audio shop over the summer....
    MODS
  2. #47
    hispls's Avatar
    hispls is offline CarAudio.com Veteran
    Sep 2009
    Cape Cod, Massachusetts
    4,830
    15
    89 Post(s)
    Quote Originally Posted by benbenondatrack View Post
    they check em all. they said the fets are 10$ a piece and if they have to replace em all itll be high. like 160 plus 90$ labor. but only 2 were bad
    You threw away money on that "repair" if he did not replace ALL the MOSFETs. This is total half *** and will very likely fail even if you get your electrical system right I wouldn't trust it. Any alleged amp repair person who does not change out ALL MOSFETs from the same batch of replacement parts is either a scammer or completely incompetent. You were told when you asked who the reliable repair people were.
    Quote Originally Posted by Spooney View Post
    Sorry if I am late to the party and this was already covered but I saw the pics of the blown amp bro. If one power supply fet died they should have replaced em all. They are all connected across the same two terminals that your buddy swapped the power and ground on. I would take it back and get your money back and send it to db-r . Power supply may not be operating normally even if the amp "works" . Hell some shady places nip out the one or two shorted fets and send you back on your way.
    This dB-R or Ampmedics will do it right. May as well send the amp in to a competent repair person now before it blows beyond hope of repair.
    Quote Originally Posted by tc300 View Post
    Op that saz is gona need more electrical that what you have currently to get it running proper....
    I'd like to see 2 good size deep cycles in the trunk anyway to run that amp safely. HO alt as well if you can.
    Rise from 1 to 2 ohm.... I don't think you've ever looked at an impedance curve have you? Rising 4 to 10X DC resistance is highly possible. DMM is pretty pointless without a current clamp IMO. Use your ears and use your head and that'll do it if either works as it should.
    Possibly, possibly not. Too many factors, without a proper loudspeaker measureing tool or DMM and current clamp + tone generator you'll never know what's happening at any given frequency.
    This thread is a travesty. OP, please send your amp to a competent repair person and find a competent installer to install and set up your equipment.
  3. #48
    Julian's Avatar
    Julian is offline CarAudio.com Elite
    Aug 2010
    KC,MO
    805
    7 Post(s)
    Since when was the gain knob the volume knob? The position of the gain knob is to adjust your noise ceiling so you get less noise.
    Refs:
    sefugi x2, S.DeYoung, SteveMead, chillin, rebelfromva, Got160s?, JL Audio , mclerico83, and BIGJEFF64.
  4. #49
    IonRL205's Avatar
    IonRL205 is offline DJ h4z4rdes IonRL205 is a Supporting Member of the forum!
    Sep 2008
    Abilene, Texas
    2,316
    26 Post(s)
    Quote Originally Posted by hispls View Post
    It sounds more like ben didn't wanna pay the quoted price to replace all the mosfets, so he cheaped out and just got the 2 bad ones replaced. I don't think it's on the repairer since he quoted the OP a price for it. Whether or not the price is too high or not, the OP still had the chance to ask other people for quotes on the repair to get a better price.
    Headunit - Pioneer DEH-P8300UB
    Subs - Two Kicker Solo x 12s Walled
    Sub Amp - Shark Shkamp 2500d
    Front Stage - Polk Audio db651 Coaxial
    Front Amp - MB Quart ONX2.100 (coming soon)
    Quote Originally Posted by zako View Post
    Most properly done 15 inch subwoofers are not suited for car audio use simply due to box size requirements.
  5. #50
    ace_800's Avatar
    ace_800 is offline CarAudio.com Veteran
    May 2004
    tucson, az
    32
    4,990
    44 Post(s)
    I set with DMM and my gain is 3/4's up, voltage is 2.5 and no clipping.
    Current set up: 2010 Buick Enclave, 2 12" MMATS PROCASTS 2.5@35, MMATS D200HC
    Hertz 165XL comps in front door, Eclipse XA4000(switching to Alpine 1507)
    Pioneer Z150bt Nav, Audio Technix all around.
    66 Pontiac GTO, modified stock radio, Xtant 3150x, Trubass 8", Kicker KS6.5's in the front kicks.
    Feedback...http://www.caraudio.com/forum/showthread.php?t=287960&highlight=ace_800
  6. #51
    cdc351jeferson's Avatar
    cdc351jeferson is offline Premium Member cdc351jeferson is a Supporting Member of the forum!
    Jul 2012
    austin tx
    1,617
    12 Post(s)
    didnt see it stated what kinda wire and extra batts and such you got . whats your electrical like? also wtf why didnt you send it off to someone who knew how to fix an amp properly
    headunit : Sony xab-601bt
    fronts: infinity kappa 60.9's
    subs:
    box : ORIGINAL STARR MOUNTAIN SOUND NUTHUGGER
    sub amp:
    others: Mechman 240amp alt (for sale)
    REFS: Bradfordp2612 , Double 07 , NASTY08IMPALA
  7. #52
    -BenBen-'s Avatar
    -BenBen- is offline TEAM FI
    Jun 2011
    Down South
    671
    14 Post(s)
    Quote Originally Posted by Ronny View Post
    LOL. If you don't get it, just don't worry about it then.
    Benbenondatrack,
    Just giving you ****
    Although, IMO, your charging system did not suffice with the SAZ-3000D, perhaps if you have a good group 31 battery in the trunk though, then just the H/O alternator you have coming will be needed. But, the more the better of course. Did you check and see what exactly that battery in your trunk is yet? 1ohm as your nominal impedance will certainly cause for some decent current draw. If/when you have that AP amplifier tuned and producing as much clean power as you'll be able to obtain, undoubtedly the SA will be louder, ONCE it has the charging system it needs to produce some powah. Takes power to "make" power; even though the SA is going to be much more efficient than the AP, being that it is twice as powerful there is no way around that.
    There are a bunch of people not too far North of you, hell, send some members in Bloomington, IN some PMs (I'll look in my contacts list for the ones I used to talk to). You'll get a lesson and get what you need. And eventually you ought to grab yourself an O-scope if you plan on getting really far into mobile audio.
    Yea man ill appreciate that alot, thanks.
    Low & Loud Songs - Slowed By BenBen Vol 1: http://www.sendspace.com/file/328is7 -
    Low & Loud Songs - Slowed By BenBen Vol 2: http://www.sendspace.com/file/vq6pdx
    ***Current Setup***
    2006 Pontiac G6 Sedan
    Pioneer avh-p4300 Head Unit
    FI Sp4 15 (D1.27 ohm)
    3.5Cu Slot Ported Box tuned to 33 Hz (Designed By @dbeez )
    Sundown Audio Saz 3000D
  8. #53
    -BenBen-'s Avatar
    Jun 2011
    Down South
    671
    14 Post(s)
    Quote Originally Posted by IonRL205 View Post
    not true, snoopdan refered me to this guy, so i tried him out. he said more then likely all of the mosfets needed to be replaced, but when i got to the shop, he checked all of them and said only 2 were affected. thats why he only replaced 2. he checked em all
    ***Current Setup***
  9. #54
    Jul 2012
    austin tx
    1,617
    12 Post(s)
    whats your electrical like ben
    subs:
    sub amp:
  10. #55
    -BenBen-'s Avatar
    Jun 2011
    Down South
    671
    14 Post(s)
    Quote Originally Posted by cdc351jeferson View Post
    big 3, 0 guage from trunk to hood,(Monster) also ill have to look at the battery in my trunk but its big as hell. was a truck battery i believe
    ***Current Setup***
  11. #56
    Jul 2012
    austin tx
    1,617
    12 Post(s)
    that amps gonna draw alot of current . should have prolly big batts in the back
    subs:
    sub amp:
  12. #57
    -BenBen-'s Avatar
    Jun 2011
    Down South
    671
    14 Post(s)
    Im getting some soon
    ***Current Setup***
  13. #58
    Dirtrider4eva's Avatar
    Dirtrider4eva is offline √\_The CaUsE__
    Mar 2011
    Milwaukee, WI
    4,188
    16 Post(s)
    Find a cheap ac clamp and a dmm. Combine those to see wattages
    welcome to
    Where b-stock is the new a-stock
    TEAM WEST
  14. #59
    goingdef's Avatar
    goingdef is offline CarAudio.com Veteran
    Jan 2008
    Norfolk VA
    33
    2,825
    11 Post(s)
    Well seeing as with most amps power drops as as the ohms rise I think you might want to look into this a little more, rise is only a need to know thing if your burping a tone and it has to be the same tone you tested with to find the rise so most find the tone that meters the highest then test for rise and make the appropriate adjustments.
    electrical: Optima yellow top, big 3 in stinger 1/0g
    HU: JVC AVX-77 touch screen
    Front stage: RE XXX 6.5" comps
    front stage amp: Rockford T600.2
    subs: 2 Rockford T1 12's,
    sub amp: Rockford T1500.1BDCP
    Enclosure: center port(designed&built by JayDubb757)
  15. #60
    -BenBen-'s Avatar
    Jun 2011
    Down South
    671
    14 Post(s)
    ok guys i guess it was the gain, i turned it up to about maybe 60% and it started coming to life, and i mean loud. i need a way better box but it def. it alot better then the ap 1800 now
    ***Current Setup***
  16. Likes itsblown liked this post
+ Reply to Thread
  1. infinits basslink louder then my last setup :(
    By RumbleNTheTrunk in forum Subwoofers
    Last Post: 07-24-2006, 11:36 AM
  2. Will (4) L7 12's be ALOT louder then (1) MT 18?
    By Rodeo91 in forum Subwoofers
    Last Post: 07-09-2006, 12:36 PM
  3. sound better and louder then a 12-W7
    By jrouter76 in forum Subwoofers
    Last Post: 07-02-2006, 04:53 PM
  4. walled off louder then normal setup?
    By psych0ticnemes1 in forum General Discussion
    Last Post: 09-29-2005, 12:21 AM
